SUBF2030
SUBF2030
    TRIPPLITE
    EXTERNAL BATTERY FRAME SELECT
SUBF2030 数据手册
External Battery Frame for Extended Runtime for select SmartOnline 20kVA & 30kVA 3-Phase UPS Systems MODEL NUMBER: SUBF2030 Highlights ● External Battery Frame holds up to four SURBC2030 Internal Battery Packs (available separately from Tripp Lite) to extend runtime ● High current DC connector attaches to select Tripp Lite SmartOnline 20kVA and 30kVA 3-Phase UPS Systems ● Simple installation and hotswappable battery replacement supported Package Includes Description SUBF2030 is an External Battery Frame for use with select Tripp Lite SmartOnline 20kVA and 30kVA UPS Systems (SU20K3/3, SU20K3/3XR5, SU30K3/3 and SU30K3/3XR5). External Battery Frame supports the installation of up to four SURBC2030 Internal Battery Packs (available separately from Tripp Lite). Modular DC connector enables daisychaining of multiple SUBF2030 External Battery Frames for extended runtime. Features ● SUBF2030 External Battery Frame allows users to extend battery runtime for select Tripp Lite SmartOnline 20kVA and 30kVA 3-Phase UPS Systems ● Each SUBF2030 supports up to four SURBC2030 Internal Battery Packs (available separately from Tripp Lite) ● Simple internal battery connections make battery installation and replacement fast and simple ● Internal Battery Packs that are designed for the SUBF2030 are separately fused. This removes shorted Battery Packs from the DC bus and maintains output from remaining Battery Packs Specifications OVERVIEW UPC Code 037332137548 Accessory Type Battery Frame INPUT Input Phase 3-Phase BATTERY 1/2 ● SUBF2030 External Battery Frame ● Instruction and installation manual DC System Voltage (VDC) 240 PHYSICAL External Battery Pack Form Factor Tower Shipping Dimensions (hwd / in.) 23.00 x 24.00 x 39.00 Shipping Dimensions (hwd / cm) 58.42 x 60.96 x 99.06 Shipping Weight (lbs.) 113.00 Shipping Weight (kg) 51.26 Unit Dimensions (hwd / in.) 17.500 x 19.500 x 31.700 Unit Dimensions (hwd / cm) 44.5 x 49.53 x 80.5 Unit Weight (lbs.) 71 Unit Weight (kg) 32.21 WARRANTY Product Warranty Period (Worldwide) 2-year limited warranty © 2022 Tripp Lite. All rights reserved. All product and company names are trademarks or registered trademarks of their respective holders. Use of them does not imply any affiliation with or endorsement by them. Tripp Lite has a policy of continuous improvement. Specifications are subject to change without notice. Tripp Lite uses primary and third-party agencies to test its products for compliance with standards. See a list of Tripp Lite's testing agencies: https://www.tripplite.com/products/product-certification-agencies 2/2
SUBF2030 价格&库存
很抱歉,暂时无法提供与“SUBF2030”相匹配的价格&库存,您可以联系我们找货
