BP480V40C
BP480V40C
    TRIPPLITE
    EXT BATTERY PACK W/ INT DISCONN
BP480V40C 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States External Battery Pack for select Tripp Lite 3Phase UPS Systems (BP480V40C) Highlights ● Extends runtime of compatible Tripp Lite UPS Systems using special "+/-" 240VDC configuration ● Hardwire installation MODEL NUMBER: BP480V40C Package Includes ● BP480V40C external battery pack ● Warranty information ● Owner's Manual Description Tripp Lite's BP480V40C External Battery Pack offers extended battery runtime when used in conjunction with compatible Tripp Lite UPS systems. Includes internal disconnect for battery isolation. Compatible UPS Systems: SU40K, SU60K, SU80K, SU20KX, SU40KX, SU60KX, SU80KX and other Tripp Lite UPS systems specifying the use of this battery pack. Features ● Offers extended-run UPS operation when used in conjunction with compatible Tripp Lite UPS systems ● Multiple battery packs can be daisy-chained to the UPS for even longer extended run operation Specifications OVERVIEW UPC Code 037332141514 INPUT Input Phase 3-Phase BATTERY Expandable Runtime Yes DC System Voltage (VDC) +/- 240VDC UPS Connection Hardwire (contractor supplies wiring - see Owner's Manual for gauge recommendations) Typical Battery Lifespan 3-5 years typical (North America) 1/2 1000 Eaton Boulevard Cleveland, OH 44122 United States PHYSICAL Material of Construction Steel External Battery Pack Form Factor Tower Installation Form Factors Supported with Included Accessories Tower Shipping Dimensions (hwd / in.) 76.00 x 28.50 x 45.00 Shipping Dimensions (hwd / cm) 193.04 x 72.39 x 114.30 Shipping Weight (lbs.) 1780.00 Shipping Weight (kg) 807.39 Unit Dimensions (hwd / in.) 66.900 x 20.500 x 33.700 Unit Dimensions (hwd / cm) 169.9 x 52.1 x 85.6 Unit Weight (lbs.) 1603 Unit Weight (kg) 727.11 WARRANTY & SUPPORT Product Warranty Period (Worldwide) 1-year limited warranty © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 2/2
BP480V40C 价格&库存
很抱歉,暂时无法提供与“BP480V40C”相匹配的价格&库存,您可以联系我们找货
