BP72V28-3UNAFTA
BP72V28-3UNAFTA
    TRIPPLITE
    BATTERY PACK FOR UPS 72V
BP72V28-3UNAFTA 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States External Battery Pack for UPS System - NAFTA assembled version of BP72V28RT-3U Highlights ● Extends the runtime of select compatible Tripp Lite UPS systems with 72VDC external battery connector ● Simple installation; 3U rackmount, tower and stack adaptable ● 2-year warranty MODEL NUMBER: BP72V28-3UNAFTA Package Includes ● BP72V28-3UNAFTA external battery pack ● Mounting hardware ● Warranty information ● Instruction manual Description BP72V28-3UNAFTA rack/tower external battery pack offers extended battery runtime when used in conjunction with compatible Tripp Lite systems. Multi-use form factor supports configuration in rackmount or stacking applications using only 3 rack spaces (3U). Upright tower configuration supported with optional 2-9USTAND accessory. Includes heavy gauge cabling with high current DC connector for simple installation. Additional DC connector enables the daisy-chaining of multiple external battery packs for longer extended run capability. COMPATIBLE UPS SYSTEMS - SU3000RMNAFTA, SU3000XLNAFTA, and other Tripp Lite UPS systems that specify the use of this battery pack. Features ● Offers extended-run UPS operation when used in conjunction with compatible Tripp Lite UPS systems ● Supports stacking or rackmount installation using only 3 rack spaces (3U) ● Supports upright tower installation with optional 2-9USTAND accessory (holds 3 battery packs in tower configuration) ● Includes heavy gauge cabling with high current DC connectors for simple installation ● 2 year warranty Specifications BATTERY Expandable Runtime Yes Expandable Runtime Description Yes, DC connector accepts daisy-chaining of multiple external battery packs for extended runtime operation DC System Voltage (VDC) 72 UPS Connection Black 3-point battery connector Typical Battery Lifespan 4-6 years typical 1/2 1000 Eaton Boulevard Cleveland, OH 44122 United States PHYSICAL Material of Construction Steel Form Factors Supported 3U rack/tower Unit Dimensions (hwd / in.) 5.250 x 17.500 x 25.000 Unit Dimensions (hwd / cm) 13.33 x 44.45 x 63.5 Unit Weight (lbs.) 166.45 Unit Weight (kg) 75.50 © 2023 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 2/2
BP72V28-3UNAFTA 价格&库存
很抱歉,暂时无法提供与“BP72V28-3UNAFTA”相匹配的价格&库存,您可以联系我们找货
