70-IDC15NP
70-IDC15NP
    GRAYHILLINC.
    Module
70-IDC15NP 数据手册
AC/DC Input Modules FEATURES • Transient Protection: Meets the requirements of IEEE 472, “Surge Withstanding Capability Test”* • Non-Polarized Types Provide Inputs For AC or DC • UL, CSA, CE , TÜV Certified (TÜV not available on OpenLine) • Optical Isolation • OpenLine® and G5 Modules have Built-in Status LED 70L-IDC 70G-IDC 70-IDC 70M-IDC CIRCUITRY OpenLine® Standard, Mini, G5 + I/O MODULE PIN # Rx 1 TYPICAL WIRING FOR MODULE 0 VDC 2 INPUT DEVICE 1 1 FILTER OPTICAL ISOLATION +/- +VCC 3 INPUT VOLTAGE HYST. CIRC. INPUT DEVICE CURRENT REGULATING OUTPUT DC SUPPLY 2 2 3 3 TERMINAL BLOCK # Vcc 7 CH. A STATUS 5 GND OPTICAL ISOLATION 8 CH. B STATUS 9 MODULE ID HYSTERESIS 4 4 5 B FILTER +/- 4 GROUND HYSTERESIS +/- * 6 A +/- BASE OR RACK 0Ω MODULE * Separate supplies may also be used. Status LED in G5 modules only. SPECIFICATIONS: By Package Style Package Style I/O Modules 1 2 3 Specifications Units Output Current Range Min. Output Breakdown Voltage Isolation Voltage 1 Vibration2 Mechanical Shock3 Storage Temp. Range Operating Temp. Range Warranty mA Vdc Vrms °C °C Std (70-) Mini (70M-) G5 (70G-) OL (70L-) 1-50 50 4000 MIL-STD-202 MIL-STD-202 -40 to +125 -40 to +100 Lifetime 1-50 50 4000 MIL-STD-202 MIL-STD-202 -40 to +125 -40 to +100 Lifetime 1-50 50 4000 MIL-STD-202 MIL-STD-202 -40 to +125 -40 to +100 Lifetime 1-50 50 2500 IEC68-2-6 IEC68-2-27 -40 to +100 -40 to +85 Lifetime Field to logic and channel-to-channel if Grayhill racks are used. MIL-STD-202, Method 204, 20 G, 10-2000 Hz or IEC68-2-6, 0.15 mm/sec2, 10-150 Hz. MIL-STD-202, Method 213, Condition F, 1500 G or IEC68-2-27, 11 mS, 15g. I/O 16 Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com f 02761&7.'5 SPECIFICATIONS: By Part Number Standard and Miniature Modules Type/Function Grayhill Part Number Miniature, Non-Polarized Standard, Non-Polarized Specifications 70M-IDC5G 70-IDC5G 70M-IDC5NP 70-IDC5NP 70M-IDCI5NP 70-IDC15NP 70-IDC24NP Units Maximum Input Voltage Input Voltage Range1 Input Current @ Max. Input Voltage Maximum Turn-on Time Maximum Turn-off Time Nominal Input Resistance (Rx) Maximum Pick Up Voltage (Output Low) Minimum Drop Out Voltage (Output High) Nominal Logic Voltage (Vcc) Logic Voltage Range Max. Logic Supply Current @ Nominal Vcc Vac/Vdc Vac/Vdc mA mSec mSec W Vac/Vdc Vac/Vdc Vdc Vdc 60 35-60 6 10 10 10K 35 9 5 3-6 32 15-32/10-32 18 5 5 1.8K 15/10 3 5 3-6 32 15-32/10-32 18 5 5 1.8K 15/10 3 15 8-18 32 15-32/10-32 18 5 5 1.8K 15/10 3 24 15-30 mA 10 10 10 10 G5 Modules Type/Function Grayhill Part Number G5, Non-Polarized, Status LED Specifications Maximum Input Voltage Input Voltage Range1 Input Current @ Max. Input Voltage Maximum Turn-on Time Maximum Turn-off Time Nominal Input Resistance (Rx) Maximum Pick Up Voltage (Output Low) Minimum Drop Out Voltage (Output High) Nominal Logic Voltage (Vcc) Logic Voltage Range: Std & Mini Max. Logic Supply Current @ Nominal Vcc 70G-IDC5G Units 70G-IDC5NP 70G-IDC15NP Vac/Vdc Vac/Vdc mA mSec mSec W Vac/Vdc Vac/Vdc Vdc Vdc 60 35-60 6 10 10 10K 35 9 5 4.5-6 32 15-32/10-32 18 5 5 1.8K 15/10 3 5 4.5-6 32 15-32/10-32 18 5 5 1.8K 15/10 3 15 10-18 mA 10 10 10 OpenLine® Modules Grayhill Part Number Dual, Non-Polarized, Status LED Specifications Maximum Input Voltage Input Voltage Range1 Input Current @ Max. Input Voltage Maximum Turn-on Time Maximum Turn-off Time Nominal Input Resistance (Rx) Maximum Pick Up Voltage (Output Low) Minimum Drop Out Voltage (Output High) Nominal Logic Voltage (Vcc) Logic Voltage Range Max. Logic Supply Current @ Nominal Vcc Module ID Resistance to Logic Ground 1 70L-IDCNP Units Vac/Vdc Vac/Vdc mA mSec mSec W Vac/Vdc Vac/Vdc Vdc Vdc 32 15-32/10-32 17 5 5 1.9K 5/10 3 5 4.5-28 mA W 6/CH 0 For input voltages in the range of 90 to 140 Vdc, use AC input modules 70-IAC5, 70M-IAC5, 70G-IAC5 or 70L-IAC. For input voltages in the range of 180 to 280 Vdc, use AC input modules 70-IAC5A, 70M-IAC5A, 70G-IAC5A or 70L-IACA. 4#;*+..X 0%T ˜ IJE +..)418' 8'07' ˜ # 4#0)'X ..+01+5  JNIFIgIMMK ˜  ˜ *10'U KNLgGIHgENHN ˜ #:U KNLgGIHgFLFN ˜ 999T)4#;*+..T%1/ I/O 17 I/O Modules Type/Function Available from your local Grayhill Distributor. For prices and discounts, contact a local Sales Office, an authorized local Distributor or Grayhill.
70-IDC15NP 价格&库存
很抱歉,暂时无法提供与“70-IDC15NP”相匹配的价格&库存,您可以联系我们找货
70-IDC15NP
    • 1+339.16320
    • 200+135.33480
    • 500+130.80960
    • 1000+128.57400
