84145071
84145071
    CROUZET(高诺斯)
    Module
    INPUT MODULE DC 20MA
84145071 数据手册
SIMM Series Input Modules * 6.2 mm wide and 65 mm deep * DIN Rail mounted * LED input status indicator * Bridges enable quick linking of common voltage * Identification zone on front face * IP20 Part numbers 84145061 84145062 84145064 84145066 84145071 24Vdc 19.2-30Vdc 20 mA 24Vac/dc 19.2-30Vac/dc 20 mA 120 95-121Vac/dc 5 mA 240 195-253Vac/dc 5 mA 24Vdc 19.2-30Vdc 20 mA 30Vac/36Vdc 50 mA 30Vac/36Vdc 50 mA 30Vac/36Vdc 50 mA 30Vac/36Vdc 50 mA 30Vac/36Vdc 50 mA -25 to 60°C -40 to 80°C 8 ms 10 ms 10 Hz > 10 x 106 6 x 106 1.23 oz -25 to 60°C -40 to 80°C 8 ms 10 ms 10 Hz > 10 x 106 6 x 106 1.23 oz SPDT SPDT Input Characteristics (at ambient 25 C°) Nominal voltage Operating voltage range Max input current Output characteristics (at ambient 25 C°) Max Voltage Max current General characteristics Operating temperature range Storage temperature range Turn-On time Turn-Off time Switching frequency Mechanical Life (operations) Electrical Life (number of operation) Weight Contact Material Contact Arrangement -25 to 60°C -25 to 60°C -40 to 80°C -40 to 80°C 8 ms 8 ms 10 ms 10 ms 10 Hz 10 Hz > 10 x 106 > 10 x 106 6 x 106 6 x 106 1.23 oz 1.23 oz AgSnO2 gold plated SPDT SPDT -25 to 60°C -40 to 80°C 8 ms 10 ms 10 Hz > 10 x 106 6 x 106 1.23 oz SPST (N.O.) Note: Exceeding the value given for the output relay current will remove the gold plating from the contacts and therefore we cannot guarantee correct operation at low currents. Dimensions: SPDT SPST Wiring Diagram and Thermal Curves: Accessories 84145061 / 062 / 064 / 066 84145050 84145052 Front Panel marker ( 88 per bag ) 10 postion jumper - Blue 84145051 2 Pole "Common" Jumper 84145053 10 postion jumper - Red 84145071 Products and specifications subject to change without notice. Consult factory for applications assistance. www.crouzet-usa.com
84145071 价格&库存
很抱歉,暂时无法提供与“84145071”相匹配的价格&库存,您可以联系我们找货
