70G-IAC15
70G-IAC15
    GRAYHILLINC.
    Module
    INPUT MODULE AC 8MA 15VDC
70G-IAC15 数据手册
AC Input Modules FEATURES • Transient Protection: Meets the requirements of IEEE 472, “Surge Withstanding Capability Test” • UL, CSA, CE, TÜV Certified (TÜV not available on OpenLine) • Optical Isolation • OpenLine® and G5 Modules have Built-in Status LED • Lifetime Warranty 70L-IAC 70G-IAC 70-IAC 70M-IAC CIRCUITRY OpenLine® Standard, Mini, G5 + I/O MODULE PIN # Rx TYPICAL WIRING FOR MODULE 70 1 VDC 6 Vcc 7 CH. A STATUS 5 GND 8 CH. B STATUS 9 MODULE ID A INPUT DEVICE 2 1 1 FILTER OPTICAL ISOLATION +VCC 3 INPUT VOLTAGE HYST. CIRC. INPUT DEVICE CURRENT REGULATING OUTPUT 2 2 3 3 OPTICAL ISOLATION 4 4 GROUND TERMINAL BLOCK # 5 B FILTER * HYSTERESIS HYSTERESIS 4 BASE OR RACK Status LED in G5 modules only. 0Ω MODULE * Separate supplies may also be used. SPECIFICATIONS: By Package Style I/O Modules Package Style 1 2 3 Specifications Units Output Current Range Minimum Output Breakdown Voltage Maximum Turn-On Time Maximum Turn-Off Time Isolation Voltage 1 Vibration2 Mechanical Shock3 Storage Temp. Range Operating Temp. Range Warranty mA Vdc mS mS Vrms °C °C Std (70-) Mini (70M-) G5 (70G-) OL (70L-) 1-50 50 20 20 4000 MIL-STD-202 MIL-STD-202 -40 to +125 -40 to +100 Lifetime 1-50 50 20 20 4000 MIL-STD-202 MIL-STD-202 -40 to +125 -40 to +100 Lifetime 1-50 50 20 20 4000 MIL-STD-202 MIL-STD-202 -40 to +125 -40 to +100 Lifetime 1-50 50 20 20 2500 IEC68-2-6 IEC68-2-27 -40 to +100 -40 to +85 Lifetime Field to logic and channel-to-channel if Grayhill racks are used. MIL-STD-202, Method 204, 20 G, 10-2000 Hz or IEC68-2-6, 0.15 mm/sec2, 10-150 Hz. MIL-STD-202, Method 213, Condition F, 1500 G or IEC68-2-27, 11 mS, 15g. I/O 14 Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com  02761&7.'5 SPECIFICATIONS: By Part Number Standard and Miniature Modules Type/Function Grayhill Part Number Miniature Standard Specifications 70M-IAC5 70-IAC5 70M-IAC5A 70-IAC5A 120 90-140 8 22K 90 25 5 3-6 10 240 180-280 6 60K 180 50 5 3-6 10 70M-IAC15 70M-IAC15A 70-IAC15A 70M-IAC24 70-IAC24 70M-IAC24A 70-IAC24A Units Nominal Input Voltage Input Voltage Range1 Input Current @ Maximum Input Voltage Nominal Input Resistance (Rx) Maximum Pick-Up Voltage (Output Low) Minimum Drop-Out Voltage (Output High) Nominal Logic Voltage (Vcc) Logic Voltage Range Max. Logic Supply Current @ Nominal Vcc Vac Vac/Vdc mA, rms W Vac Vac Vdc Vdc mA 120 90-140 8 22K 90 25 15 8-18 10 240 180-280 6 60K 180 50 15 8-18 10 120 90-140 8 22K 90 25 24 15-30 10 240 180-280 6 60K 180 50 24 15-30 10 G5 Modules Type/Function Grayhill Part Number G5, Status LED Specifications 70G-IAC5 70G-IAC5A 120 90-140 8 22K 90 25 5 4.5-6 10 240 180-280 6 60K 180 50 5 4.5-6 10 70G-IAC15 70G-IAC15A 70G-IAC24 70G-IAC24A 120 90-140 8 22K 90 25 15 10-18 10 240 180-280 6 60K 180 50 15 10-18 10 120 90-140 8 22K 90 25 24 17-30 10 240 180-280 6 60K 180 50 24 17-30 10 Units Nominal Input Voltage Input Voltage Range1 Input Current @ Maximum Input Voltage Nominal Input Resistance (Rx) Maximum Pick-Up Voltage (Output Low) Minimum Drop-Out Voltage (Output High) Nominal Logic Voltage (Vcc) Logic Voltage Range Max. Logic Supply Current @ Nominal Vcc Vac Vac/Vdc mA, rms W Vac Vac Vdc Vdc mA OpenLine® Modules Grayhill Part Number Type/Function Dual, Status LED Specifications 1 70L-IACA 120 0-140 8 22K 90 25 5 4.5-28 6/CH 0 240 0-280 6 64K 180 50 5 4.5-28 6/CH 0 Units Vac Vac/Vdc mA, rms W Vac Vac Vdc Vdc mA W I/O Modules Nominal Input Voltage Input Voltage Range1 Input Current @ Max. Input Voltage Nominal Input Resistance (Rx) Max. Pick-Up Voltage (Output Low) Min. Drop-Out Voltage (Output High) Nominal Logic Voltage (Vcc) Logic Voltage Range Max. Logic Supply Current @ Nominal Vcc Module ID Resistance to Logic Ground 70L-IAC Available from your local Grayhill Distributor. For prices and discounts, contact a local Sales Office, an authorized local Distributor or Grayhill. For input voltages in the range of 15-32 Vac, or 35-60 Vac, see DC input Modules with the NP or G suffix. 4#;*+..X 0%T ˜ IJE +..)418' 8'07' ˜ # 4#0)'X ..+01+5  JNIFIgIMMK ˜  ˜ *10'U KNLgGIHgENHN ˜ #:U KNLgGIHgFLFN ˜ 999T)4#;*+..T%1/ I/O 15
70G-IAC15 价格&库存
很抱歉,暂时无法提供与“70G-IAC15”相匹配的价格&库存,您可以联系我们找货
