70M-ODC5
70M-ODC5
    GRAYHILLINC.
    Module
70M-ODC5 数据手册
DC Output Modules FEATURES • Transient Protection: Meets the requirements of IEEE 472, "Surge Withstanding Capability Test" • SPST, Normally Open • UL, CSA, CE, TÜV Certified • Optical Isolation • OpenLine® and G5 Modules Provide Replaceable 5x20mm Glass Fuses • Built-in Status LED • Lifetime Warranty 70L-ODC DIMENSIONS LOAD CURRENT (AMPS) 4 For complete dimensional drawings, see pages L-4 or L-5. FUSES G5 Fuses are 5 Amp Littelfuse part number 217005 or equivalent. OpenLine® fuses are 3.15 Amp Littelfuse part number 2173.15. Fuse kits available, see page L-104. 3 2 1 MINIATURE PACKAGE OPENLINE PACKAGE/CH 70M-ODC 200 VDC STYLE -40˚ -20˚ 0 20˚ 40˚ 60˚ 80˚ AMBIENT TEMPERATURE (˚C) 100˚ Figure 1 OpenLine ® Standard, Mini, G5 LOAD VOLTAGE SPIKE PROTECTION LOAD GND 5 Vcc 6 CHANNEL A A 2 CH. A CONTROL 7 OPTICAL ISOLATION DRIVER CIRCUIT DRIVER CIRCUIT OPTICAL ISOLATION – 1 1 LOAD 2 2 DC SUPPLY 3 3 DC SUPPLY 4 4 LOAD DRIVER CIRCUIT CHANNEL B CH. B 8 CONTROL Rx 3 – 2.15K I/O Modules DC CONTROL – + + B + I/O MODULE PIN # TYPICAL WIRING FOR MODULE 0 1 VDC – 70-ODC Maximum Current Versus Ambient Temperature The chart indicates continuous current to limit the junction temperatures to 115°C. Information is based on steady state heat transfer in a 2 cubic foot sealed enclosure. STANDARD, G5 PACKAGES CIRCUITRY + 70G-ODC MODULE ID 9 4 BASE OR RACK Fuse and status LED in G5 and OpenLine modules only. TERMINAL BLOCK # SPECIFICATIONS: By Package Style Package Style Specifications Load Current Range Surge Current for 1 Sec. Maximum Reverse Logic Voltage Isolation Voltage2 Vibration3 Mechanical Shock4 Storage Temp. Range Operating Temp. Range Warranty 2 3 4 Mini (70M-) G5 (70G-) OL (70L-) 0.02-3.5 5 -5 4000 MIL-STD-202 MIL-STD-202 -40 to 125 -40 to 100 Lifetime 0.02-3.0 5 -5 4000 MIL-STD-202 MIL-STD-202 -40 to 125 -40 to 100 Lifetime 0.02-3.5 5 -5 4000 MIL-STD-202 MIL-STD-202 -40 to 125 -40 to 100 Lifetime 0.02-2.0/CH 5 -5 2500 IEC68-2-6 IEC68-2-27 -40 to 100 -40 to 85 Lifetime Units 1 1 Std (70-) A A Vdc Vrms °C °C See Figure 1 for derating. Field to logic and channel-to-channel if Grayhill racks are used. MIL-STD-202, Method 204, 20 G, 10-2000 Hz or IEC68-2-6, 0.15 mm/sec2, 10-150 Hz. MIL-STD-202, Method 213, Condition F, 1500 G or IEC68-2-27, 11 mS, 15g. I/O 8 Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com DC Output Modules SPECIFICATIONS: By Part Number Standard and Miniature Modules Type/Function Grayhill Part Number Miniature, Normally Open Standard, Normally Open 70M-ODC5 70M-ODC5A 70M-ODC5B 70M-ODC15 70-ODC5 70-ODC5A 70-ODC5B 70-ODC15 70M-ODC15B 70-ODC15B 70M-ODC24 70M-ODC24B 70-ODC24 70-ODC24B Specifications Units Maximum Line Voltage Load Voltage Range Max. Off-State Leakage @ Max. Line Maximum Turn-On Time Maximum Turn-Off Time Typ. Power Dissipation Clamping Voltage Nominal Logic Voltage (Vcc) Logic Voltage Range Maximum Logic Supply Current @ Nominal Vcc Nominal Input Resistance (Rx) Minimum Drop Out Voltage Vdc Vdc mA µSec µSec W/A Vdc Vdc Vdc 60 3-60 1.5 20 50 1 80 5 2.5-10 200 4-200 0.01 75 750 1.5 360 5 2.5-9 60 3-60 0.01 75 500 1 80 5 2.5-10 60 3-60 1.5 20 50 1 80 15 10-18 60 3-60 0.01 75 500 1 80 15 10-18 60 3-60 1.5 20 50 1 80 24 15-30 60 3-60 0.01 75 500 1 80 24 15-30 mA Ω Vdc 14 300 1 18 220 1 14 300 1 9 1800 1 9 1800 1 9 2700 1 9 2700 1 G5 and OpenLine® Modules Grayhill Part Number Type/Function Fusible, Normally Open Specifications 70G-ODC5 70G-ODC5A 70G-ODC5B 70G-ODC15 70G-ODC15B 70G-ODC24 70G-ODC24B Units Maximum Line Voltage Load Voltage Range Max. Off-State Leakage @ Max. Line Maximum Turn-On Time Maximum Turn-Off Time Typ. Power Dissipation Clamping Voltage Nominal Logic Voltage (Vcc) Logic Voltage Range Maximum Logic Supply Current @ Nominal Vcc Nominal Input Resistance (Rx) Minimum Drop Out Voltage Vdc Vdc mA µSec µSec W/A Vdc Vdc Vdc 60 3-60 1.5 20 50 1 80 5 4-6 200 4-200 0.01 75 750 1.5 360 5 4-6 60 3-60 0.01 75 500 1 80 5 4-6 60 3-60 1.5 20 50 1 80 15 10-20 60 3-60 0.01 75 500 1 80 15 10-20 60 3-60 1.5 20 50 1 80 24 18-32 60 3-60 0.01 75 500 1 80 24 18-32 mA Ω Vdc 13 150 1 13 150 1 13 150 1 9 1500 1 9 1500 1 9 2700 1 9 2700 1 OpenLine® Modules Type/Function Grayhill Part Number 70L-ODC 70L-ODCA 70L-ODCB Specifications Units Maximum Line Voltage Load Voltage Range Max. Off-State Leakage @ Max. Line Maximum Turn-On Time Maximum Turn-Off Time Typ. Power Dissipation Clamping Voltage Nominal Logic Voltage (Vcc) Logic Voltage Range Maximum Logic Supply Current @ Nominal Vcc Module ID Resistance to Logic Ground Minimum Drop Out Voltage Vdc Vdc mA µSec µSec WA Vdc Vdc Vdc 60 3-60 1.5 20 50 1 80 5 4.5-28 200 4-200 .01 75 750 1.5 360 5 4.5-28 60 3-60 .01 75 500 1 80 5 4.5-28 mA 7/CH 7/CH 7/CH Ω Vdc 2.15K 1 2.15K 1 2.15K 1 Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com I/O 9 I/O Modules Dual, Fusible, Normally Open Available from your local Grayhill Distributor. For prices and discounts, contact a local Sales Office, an authorized local Distributor or Grayhill.
70M-ODC5 价格&库存
很抱歉,暂时无法提供与“70M-ODC5”相匹配的价格&库存,您可以联系我们找货
