DC Output Modules
FEATURES
• Transient Protection: Meets the
requirements of IEEE 472, "Surge
Withstanding Capability Test"
• SPST, Normally Open
• UL, CSA, CE, TÜV Certified
• Optical Isolation
• OpenLine® and G5 Modules
Provide Replaceable 5x20mm
Glass Fuses
• Built-in Status LED
• Lifetime Warranty
TUV R h e i n l a n d
70L-ODC
70G-ODC
70-ODC
70M-ODC
4
LOAD CURRENT (AMPS)
Maximum Current Versus
Ambient Temperature
The chart indicates continuous current to limit
the junction temperatures to 115°C. Information
is based on steady state heat transfer in a 2
cubic foot sealed enclosure.
3
2
1
DIMENSIONS
STANDARD, G5 PACKAGES
For complete dimensional drawings, see pages
L-4 or L-5.
MINIATURE PACKAGE
OPENLINE PACKAGE/CH
FUSES
G5 Fuses are 5 Amp Littelfuse part number
217005 or equivalent. OpenLine® fuses are
3.15 Amp Littelfuse part number 2173.15.
200 VDC STYLE
-40˚
-20˚
20˚
40˚
60˚
80˚
AMBIENT TEMPERATURE (˚C)
OpenLine ®
Standard, Mini, G5
LOAD
VOLTAGE
SPIKE
PROTECTION
LOAD
GND 5
Vcc 6
CHANNEL A
A
2
CH. A
CONTROL 7
OPTICAL
ISOLATION
DRIVER
CIRCUIT
DRIVER
CIRCUIT
OPTICAL
ISOLATION
1
1
LOAD
2
2
DC
SUPPLY
3
3
DC
SUPPLY
4
4
LOAD
DRIVER
CIRCUIT
CHANNEL B
CH. B
8
CONTROL
Rx
3
2.15K
I/O Modules
DC CONTROL
B
I/O MODULE
PIN #
TYPICAL WIRING FOR MODULE 0
1
VDC
Fuse kits available, see page L-104.
Figure 1
CIRCUITRY
100˚
MODULE ID 9
4
BASE
OR
RACK
Fuse and status LED in G5 and OpenLine modules only.
TERMINAL
BLOCK #
SPECIFICATIONS: By Package Style
Package Style
Specifications
Load Current Range
Surge Current for 1 Sec.
Maximum Reverse Logic Voltage
Isolation Voltage2
Vibration3
Mechanical Shock4
Storage Temp. Range
Operating Temp. Range
Warranty
2
3
4
Mini (70M-)
G5 (70G-)
OL (70L-)
0.02-3.5
5
-5
4000
MIL-STD-202
MIL-STD-202
-40 to 125
-40 to 100
Lifetime
0.02-3.0
5
-5
4000
MIL-STD-202
MIL-STD-202
-40 to 125
-40 to 100
Lifetime
0.02-3.5
5
-5
4000
MIL-STD-202
MIL-STD-202
-40 to 125
-40 to 100
Lifetime
0.02-2.0/CH
5
-5
2500
IEC68-2-6
IEC68-2-27
-40 to 100
-40 to 85
Lifetime
Units
1
1
Std (70-)
A
A
Vdc
Vrms
°C
°C
See Figure 1 for derating.
Field to logic and channel-to-channel if Grayhill racks are used.
MIL-STD-202, Method 204, 20 G, 10-2000 Hz or IEC68-2-6, 0.15 mm/sec2, 10-150 Hz.
MIL-STD-202, Method 213, Condition F, 1500 G or IEC68-2-27, 11 mS, 15g.
L-9
Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com
DC Output Modules
SPECIFICATIONS: By Part Number
Standard and Miniature Modules
Type/Function
Grayhill Part Number
Miniature, Normally Open
Standard, Normally Open
70M-ODC5 70M-ODC5A 70M-ODC5B 70M-ODC15
70-ODC5
70-ODC5A
70-ODC5B
70-ODC15
70M-ODC15B
70-ODC15B
70M-ODC24 70M-ODC24B
70-ODC24
70-ODC24B
Specifications
Units
Maximum Line Voltage
Load Voltage Range
Max. Off-State Leakage @ Max. Line
Maximum Turn-On Time
Maximum Turn-Off Time
Typ. Power Dissipation
Clamping Voltage
Nominal Logic Voltage (Vcc)
Logic Voltage Range
Maximum Logic Supply Current
@ Nominal Vcc
Nominal Input Resistance (Rx)
Minimum Drop Out Voltage
Vdc
Vdc
mA
µSec
µSec
W/A
Vdc
Vdc
Vdc
60
3-60
1.5
1
80
5
2.5-10
200
4-200
0.01
75
750
1.5
360
5
2.5-9
60
3-60
0.01
75
500
1
80
5
2.5-10
60
3-60
1.5
1
80
15
10-18
60
3-60
0.01
75
500
1
80
15
10-18
60
3-60
1.5
1
80
24
15-30
60
3-60
0.01
75
500
1
80
24
15-30
mA
Ω
Vdc
14
300
1
18
220
1
14
300
1
9
1800
1
9
1800
1
9
2700
1
9
2700
1
G5 and OpenLine® Modules
Type/Function
Fusible, Normally Open
Specifications
70G-ODC5
70G-ODC5A
70G-ODC5B
70G-ODC15
70G-ODC15B
70G-ODC24
70G-ODC24B
Units
Load Voltage Range
Clamping Voltage
Logic Voltage Range
@ Nominal Vcc
Vdc
Vdc
mA
µSec
µSec
W/A
Vdc
Vdc
Vdc
60
3-60
1.5
1
80
5
4-6
200
4-200
0.01
75
750
1.5
360
5
4-6
60
3-60
0.01
75
500
1
80
5
4-6
60
3-60
1.5
1
80
15
10-20
60
3-60
0.01
75
500
1
80
15
10-20
60
3-60
1.5
1
80
24
18-32
60
3-60
0.01
75
500
1
80
24
18-32
mA
Ω
Vdc
13
150
1
13
150
1
13
150
1
9
1500
1
9
1500
1
9
2700
1
9
2700
1
OpenLine® Modules
Type/Function
70L-ODC
70L-ODCA
70L-ODCB
Specifications
Units
Load Voltage Range
Clamping Voltage
Logic Voltage Range
@ Nominal Vcc
Module ID Resistance to Logic
Ground
Vdc
Vdc
mA
µSec
µSec
WA
Vdc
Vdc
Vdc
60
3-60
1.5
1
80
5
4.5-28
200
4-200
.01
75
750
1.5
360
5
4.5-28
60
3-60
.01
75
500
1
80
5
4.5-28
mA
7/CH
7/CH
7/CH
Ω
Vdc
2.15K
1
2.15K
1
2.15K
1
L-10
I/O Modules
Dual, Fusible, Normally Open
Available from your local Grayhill Distributor.
For prices and discounts, contact a local Sales
Office, an authorized local Distributor or Grayhill.
很抱歉,暂时无法提供与“70L-ODC5R”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+773.766171+100.12942
- 10+689.0771310+89.17021
- 25+657.9452725+85.14159
- 50+635.3225050+82.21408
- 100+613.46024100+79.38499
