84145041
84145041
    CROUZET(高诺斯)
    Module
    OUTPUT MODULE AC 20MA 24VDC
84145041 数据手册
SIMM Series Output Modules * 6.2 mm wide and 65 mm deep * DIN Rail mounted * LED input status indicator * Bridges enable quick linking of common voltage * Identification zone on front face * IP20 Part numbers 84145041 84145042 84145043 84145046 24Vdc 19.2-30Vdc 20 mA 24Vac/dc 19.2-30Vac/dc 20 mA 110Vac/dc 95-125Vac/dc 5 mA 230Vac 195-253Vac/dc 6 1-250Vac/dc 6A See Table 1-250Vac/dc 6A See Table 1-250Vac/dc 6A See Table 1-250Vac/dc 6A See Table -25 to 60°C -40 to 80°C 8 ms 10 ms 10 Hz > 10 x 106 6 x 106 1.23 oz -25 to 60°C -25 to 60°C -40 to 80°C -40 to 80°C 8 ms 8 ms 10 ms 10 ms 10 Hz 10 Hz > 10 x 106 > 10 x 106 6 6 x 10 6 x 106 1.23 oz 1.23 oz AgSnO2 SPDT SPDT -25 to 60°C -40 to 80°C 8 ms 10 ms 10 Hz > 10 x 106 6 x 106 1.23 oz Input Characteristics (at ambient 25 C°) Nominal voltage Operating voltage range Max input current Output Characteristics (at ambient 25 C°) Operating voltage range Max current General Characteristics Operating temperature range Storage temperature range Turn-On time Turn-Off time Switching frequency Mechanical Life (operations) Electrical Life (number of operation) Weight Contact Material Contact Arrangement SPDT Dimensions: Wiring Diagram and Thermal Curves: Relay Output: 84145041 / 042 / 043 / 046 Accessories SPDT Switching Capabilities 84145050 84145052 Front Panel marker ( 88 per bag ) 10 postion jumper - Blue 84145051 84145053 2 Pole "Common" Jumper 10 postion jumper - Red AC DC 24V 6A 1A 110V 6A 0.2 A 230V 6A 0.1 A Products and specifications subject to change without notice. Consult factory for applications. www.crouzet-usa.com
84145041 价格&库存
很抱歉,暂时无法提供与“84145041”相匹配的价格&库存,您可以联系我们找货
