84145004
84145004
    CROUZET(高诺斯)
    Module
    OUTPUT MODULE DC 7MA 110VAC/DC
84145004 数据手册
SIMM Series Output Modules * 6.2 mm wide and 65 mm deep * DIN Rail mounted * LED input status indicator * Bridges enable quick linking of common voltage * Identification zone on front face * IP20 Part numbers 84145001 84145004 84145005 84145010 84145011 84145015 24Vdc 10-44Vdc 6 mA 5Vdc 110Vac/dc 70-130Vac/dc 7 mA 30Vac/dc 230Vac 90-230Vac 8.5 mA 40Vac 5Vdc 4-5.5Vdc 6 mA 2Vdc 24Vdc 10-44Vdc 6 mA 3Vdc 230Vac 90-230Vac 7mA 40Vac 5-48Vdc 0.5A Transistor 5-48Vdc 0.5A Transistor 5-48Vdc 0.5A Transistor 5-48Vdc 2A Transistor 5-48Vdc 2A Transistor 5-48Vdc 2A Transistor -20 to 60°C -40 to 80°C 20 us 100 us 1k Hz 1.13 oz -20 to 60°C -40 to 80°C 30 ms 20 ms 10 Hz 1.13 oz -20 to 60°C -40 to 80°C 45 ms 15 ms 10 Hz 1.13 oz -20 to 60°C -40 to 80°C 1 ms 5 ms 10 Hz 1.06 oz -20 to 60°C -40 to 80°C 1 ms 5 ms 10 Hz 1.06 oz -20 to 60°C -40 to 80°C 1 ms 10 ms 10 Hz 1.06 oz 84145020 84145021 84145024 84145025 84145031 5Vdc 4-6.2Vdc 6mA 2Vdc 24Vdc 10-44Vdc 6mA 3Vdc 110Vac/dc 70-130Vac/dc 6mA 35Vac/dc 230Vac 140-250Vac 7mA 80Vac 24Vdc 10-44Vdc 6 mA 3Vdc 24-250Vac 0.5A Triac 24-250Vac 0.5A Triac 24-250Vac 0.5A Triac 24-250Vac 0.5A Triac 24-250Vac 1A Triac -20 to 60°C -40 to 80°C 10 ms 10 ms 20 Hz 1.13 oz -20 to 60°C -40 to 80°C 10 ms 10 ms 20 Hz 1.13 oz -20 to 60°C -40 to 80°C 10 ms 10 ms 20 Hz 1.13 oz -20 to 60°C -40 to 80°C 10 ms 10 ms 20 Hz 1.13 oz -20 to 60°C -40 to 80°C 8.33 ms 8.33 ms 20 Hz .95 oz Input Characteristics (at ambient 25 C°) Nominal voltage Operating voltage range Max input current Drop out voltage Output Characteristics (at ambient 25 C°) Operating voltage range Max current Output Type General Characteristics Operating temperature range Storage temperature range Turn-On time Turn-Off time Switching frequency Weight Part numbers Input Characteristics (at ambient 25 C°) Nominal voltage Operating voltage range Max input current Drop out voltage Output Characteristics (at ambient 25 C°) Operating voltage range Max current Output Type General Characteristics Operating temperature range Storage temperature range Turn-On time Turn-Off time Switching frequency Weight Derating Curves: Dimensions: 84145001 / 004 / 005 84145010 / 011 / 015 84145001 / 004 / 005 84145020 / 021 / 024 / 025 84145010 / 011 / 015 84145020 / 021 / 024 / 025 Solid State Output: 84145031 84145031 Products and specifications subject to change without notice. Consult factory for applications. www.crouzet-usa.com
84145004
物料型号包括: - 84145001, 84145004, 84145005, 84145010, 84145011, 84145015, 84145020, 84145021, 84145024, 84145025, 84145031
器件简介: - Crouzet SIMM系列输出模块,6.2mm宽,65mm深,DIN导轨安装,LED输入状态指示器,桥接快速连接公共电压,前面板识别区域,IP20防护等级。
引脚分配封装信息未在文档中明确列出。
参数特性: - 工作电压范围:5-48Vdc, 24Vdc, 230Vac等 - 最大输入电流:6mA, 7mA - 掉电电压:2Vdc, 3Vdc, 35Vac/dc, 80Vac - 输出类型:晶体管型 - 工作温度范围:-20至60°C - 存储温度范围:-40至80°C - 导通时间:20us至30ms - 关断时间:100us至20ms - 开关频率:1kHz至10Hz - 重量:1.13oz至1.95oz
功能详解: - 模块具有不同的输入电压和输出电流规格,适用于不同的应用场景。
- 模块设计用于快速链接和状态指示,具有多种电压和电流选项。
应用信息: - 适用于需要快速链接和状态指示的自动化控制系统。
更多详细信息和应用指导,请访问Crouzet官方网站。
84145004 价格&库存
很抱歉,暂时无法提供与“84145004”相匹配的价格&库存,您可以联系我们找货
