70RCK4R
70RCK4R
    GRAYHILLINC.
    I/O Module Rack 4 Channel
70RCK4R 数据手册
System 50 RACKS 4 Channel FEATURES • Use for Isolating and Coverting Signal Types to Standard Logic Voltages • Terminal Block Connection for Input and Output • Available for Standard and G5 I/O Modules • Panel and DIN Rail Mount Versions • UL, CSA Certified 4 CHANNEL RACK: Standard Part No. 70RCK4 Dimensions are shown in inches (and millimeters). All tolerances are ± 0.010 (0,25) unless otherwise specified. STANDOFF I.D. 0.15 ( 3,8),DIA. (4 PLACES) CLEARANCE FOR #6 SCREW 9 POSITION TERMINAL STRIP FOR GROUND AND LOGIC SIGNALS MODULE SHOWN FOR REFERENCE ONLY 9 8 7 6 5 4 3 2 1 AC INPUT B AC OUTPUT Y STATUS LED 3.00 (76,2) 3.3K RESISTOR 9 8 7 6 5 4 3 2 1 DC OUTPUT 5 AMP FUSE R W DC INPUT NOTE: MAXIMUM TERMINAL SCREW TORQUE NOT TO EXCEED 5 IN-LBS. 0.25 (6,4) 0.25 (6,4) TERMINAL STRIP FOR FIELD WIRING 3.50 (88,9) 4.00 (101,6) 4.50 (114,3) 2.20 (55,9) MAX. 0.75 (19,1) System 50 4 CHANNEL RACK: G5 Part No. 70GRCK4 Dimensions are shown in inches (and millimeters). All tolerances are ± 0.010 (0,25) unless otherwise specified. 3.25 (82,55) .25 (6,35) 2.75 (69,85) 5 4 3 2 1 Panel Mount 6 DIN-RAIL CARRIER 7 9 POSITION TERMINAL STRIP FOR CONTROL LOGIC 8 4.00 (101,6) 2.75 (69,85) 4.70 (119,38) Y AC INTPUT W DC INTPUT .75 (19,05) .76 (19,30) 4.27 (108,46) B AC OUTPUT R DC OUTPUT 3.36 5,34) SWAGED STANDOFF THRU HOLE .15 (3,81) DIA. (4 PLACES) (CLEARANCE FOR #6 SCREW) 9 9 POSITION TERMINAL STRIP FOR FIELD WIRING 1 2 3 4 5 6 7 8 9 NOTE: MAXIMUM TERMINAL SCREW TORQUE NOT TO EXCEED 5 IN-LBS. DIN-Rail Mount Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com System 50 4 System 50 SCHEMATICS: Part No. 70RCK4 70RCK4 For Negative True Logic Only 1 2 3 4 5 6 7 8 70RCK4R For Negative or Positive True Logic 9 1 FIELD WIRING TERMINAL STRIP N/C 0 1 2 3 4 5 6 7 8 9 FIELD WIRING TERMINAL STRIP FUSE 5A 1 2 3 4 5 2 N/C FUSE 5A 1 2 3 4 5 3 MODULE POSITION 0 1 2 3 MODULE POSITION 3.3K 3.3K TERMINAL STRIP FOR LOGIC AND GROUND SIGNALS GND LOGIC GND LOGIC GND LOGIC GND LOGIC 1 2 3 4 5 6 7 8 9 LOGIC 9 +VCC 8 LOGIC 7 +VCC 6 LOGIC 5 +VCC 4 LOGIC 3 +VCC 2 GND 1 +VCC TERMINAL STRIP FOR LOGIC AND GROUND SIGNALS SCHEMATICS: Part No. 70GRCK4 70GRCK4 and 70GRCK4-DIN For Negative True Logic Only 1 NC NC 70GRCK4R and 70GRCK4R-DIN For Negative or Postive True Logic 2 1 2 3 4 5 3 4 5 6 7 8 9 1 BARRIER STRIP FOR FIELD WIRING OF MODULE INPUT/OUTPUT 0 1 2 3 2 3 4 5 6 7 8 9 BARRIER STRIP FOR FIELD WIRING OF MODULE 1 2 3 4 5 MODULE LOCATION PULL-UP RESISTOR 3.3 K: 0 1 2 3 MODULE LOCATION PULL-UP RESISTOR 3.3 K: System 50 GND LOGIC 3 4 5 6 7 8 9 LOGIC LOGIC 4 4 4 4 4 4 2 +VCC GND 70RCK4 70RCK4R 70GRCK4 70GRCK4R 70GRCK4-DIN 70GRCK4R-DIN I/O 1 LOGIC LOGIC Part Number 9 +VCC GND ORDERING INFORMATION 8 LOGIC 7 +VCC 6 LOGIC 5 +VCC 4 CONTROL BARRIER STRIP GROUND 3 LOGIC 2 GND 1 +VCC CONTROL BARRIER STRIP (modules ordered separately) Description UL CSA Style Negative true logic Positive or negative true logic* Negative true logic Positive or negative true logic* Negative true logic–DIN rail mount Positive or negative true logic*– DIN rail mount X X X X X X X X X X X X Standard Standard G5 G5 G5 G5 . Available from your local Grayhill Distributor. For prices and discounts, contact a local Sales Office, an authorized local Distributor, or Grayhill. *Note: Positive True Logic applies to output modules only. System 50 5 Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com
70RCK4R 价格&库存
很抱歉,暂时无法提供与“70RCK4R”相匹配的价格&库存,您可以联系我们找货
