70LRCK24-HL
70LRCK24-HL
    GRAYHILLINC.
    I/O MOUNTING BRD OPENLINE 24POS
70LRCK24-HL 数据手册
System 50 RACKS 24 Channel (In-Line) s. co m FEATURES • For use with System 50 Style Controllers • Available for Standard, Miniature, G5 and OpenLine® Modules • UL, CSA Certified nt 24 CHANNEL RACK: Standard po ne Part No. 70RCK24 Dimensions are shown in inches (and millimeters). Tolerances are ± 0.010 (0,25) unless indicated otherwise. 18.75 (476,3) om 16.50 (419,1) 11.00 (279,4) STANDOFF I.D. 0.15 (3,8) DIA. (8 PLACES) CLEARANCE FOR #6 SCREWS 28 27 26 25 24 23 22 21 20 19 ec 18 17 16 15 14 13 12 11 10 9 8 lin 29 7 6 5 4 3 2 1 on 30 14 31 13 15 32 12 33 11 16 34 10 35 9 17 36 8 37 7 18 38 6 39 5 19 40 4 41 3 42 2 – + 20 43 0.25 (6,4) 1 21 22 System 50 0 44 4.00 (101,6) 1.12 (28,4) 45 4.50 (114,3) 5.50 (139,7) 46 FIELD WIRING TERMINAL STRIP 47 5A FUSE 48 NOTE: MAXIMUM TERMINAL SCREW TORQUE NOT TO EXCEED 5 IN-LBS. 23 Y AC INPUT B AC OUTPUT W DC INPUT R DC OUTPUT 1A FUSE SOCKETS FOR OPTIONAL 1A FUSE LOGIC SUPPLY TERMINAL STRIP 0.40 (10,2) KEY SLOT PINS 23/25 2.60 (66,0) 50 PIN EDGE CARD OR HEADER CONNECTOR FOR LOGIC SIGNALS (SEE NOTES) 8.08 (205,2) 1.00 (25.4) (2 PLACES) 2.20 (55,9) MAX. 0.75 (19,1) Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com System 50 18 System 50 24 CHANNEL RACK: Miniature Part No. 70MRCK24 Dimensions are shown in inches (and millimeters). All tolerances are ± 0.010 (0,25) unless otherwise specified. 13.45 (341,6) 12.00 (304,8) NOTE: MAXIMUM TERMINAL SCREW TORQUE NOT TO EXCEED 5 IN-LBS. FIELD WIRING TERMINAL STRIPS (3 PLACES) 8.00 (203,2) 5A FUSE 0.35 (8,9) 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 4.00 (101,6) 0.73 (18,5) 3.75 (95,3) 3.05 (77,5) STATUS LED 3 – 4 5 6 7 8 9 10 11 12 13 14 15 16 + SOCKETS FOR OPTIONAL 1A FUSE LOGIC SUPPLY TERMINAL STRIP PIN 1 KEY SLOT PINS 23/25 1A FUSE 17 18 19 m 2 Y B W R 20 21 AC INPUT AC OUTPUT DC INPUT DC OUTPUT co 1 0.40 (10,2) 50 PIN EDGE CARD OR HEADER CONNECTOR FOR LOGIC SIGNALS (SEE NOTE) s. 0 2.60 (66,0) 5.42 (137,7) 23 STANDOFF I.D. 0.15 (3,8) DIA. (8 PLACES) CLEARANCE FOR #6 SCREWS nt MODULE HOLD DOWN STRIP WITH THUMB SCREWS 22 ne 2.20 (55,9) MAX. om po 0.75 (19,1) 24 CHANNEL RACK: OpenLine® ec Part No. 70LRCK24 Dimensions are shown in inches (and millimeters). All tolerances are ± 0.010 (0,25) unless otherwise specified. 7.500 (190,5) 7.000 (177,8) 4.270 (108,5) 50 49 M0 A M1 M2 M3 M4 M5 M6 M7 M8 M9 M10 M11 B 50-PIN STRAIGHT HEADER CONNECTOR 3.800 (96,5) REMOVABLE JUMPER CONNECTS GND TO EARTH GROUND PIN 1 2 1 System 50 on lin 0.250 (6,3) 5A FUSE 0.238 (6,0) STANDOFF I.D. (3,81) DIA. (4 PLACES) CLEARANCE FOR #6 SCREW +5 +5 FIELD WIRING TERMINAL STRIP 1 3 5 7 9 11 13 15 17 19 21 23 25 27 29 31 33 35 37 39 41 43 45 47 2 4 6 8 10 12 14 16 18 20 22 24 26 28 30 32 34 36 38 40 42 44 46 48 LOGIC SUPPLY TERMINAL STRIP TOP ROW: + LOGIC SUPPLY BOTTOM ROW: GROUND NOTE: MAXIMUM TERMINAL SCREW TORQUE NOT TO EXCEED 5 IN-LBS. 3.383 (85,9) MAX. 0.750 (19,0) REF. System 50 Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com 19 System 50 24 CHANNEL RACK: OpenLine® DIN Rail Mount for System 50 Part No. 70LRCK24-DIN Dimensions are shown in inches (and millimeters). All tolerances are ± 0.010 (0,25) unless otherwise specified. DIN CARRIER 7.7 (194.56) PCB 7.5 (190.50) M0 M2 M3 M4 M5 M6 M7 M8 M9 M10 M11 B m PCB 4.3 (108.46) A M1 PIN 1 REMOVABLE JUMPER CONNECTS GND TO PLATED HOLE FOR GROUNDING s. 2 1 co DIN CARRIER 4.7 (119.13) 50 49 50-PIN STRAIGHT HEADER CONNECTOR LOGIC SUPPLY TERMINAL STRIP TOP ROW: + LOGIC SUPPLY BOTTOM ROW: GND +5 1 3 po +5 ne nt 5A FUSE NOTE: MAXIMUM TERMINAL SCREW TORQUE NOT TO EXCEED 5 IN-LBS. 4 7 6 9 8 11 10 13 12 15 14 17 16 19 18 21 20 23 22 25 24 27 26 29 28 31 30 33 32 35 34 37 36 39 38 41 40 43 42 45 44 3.8 (95.81) REF 47 46 48 2.2 (56.49) om 2 5 FIELD WIRING TERMINAL STRIP LOGIC SUPPLY TERMINAL STRIP – + 1 2 50 48 46 44 42 40 38 36 34 32 30 28 26 24 22 20 18 16 14 12 10 8 6 4 2 49 47 45 43 41 39 37 35 33 31 29 27 25 23 21 19 17 15 13 11 9 7 5 3 1 50 PIN EDGE CARD OR HEADER CONNECTOR FOR LOGIC SIGNALS 4 5 1 2 3 4 5 0 1 6 2 7 8 3 FIELD 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 WIRING 4 TERMINAL STRIP 5A 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 MODULE POSITION 3.3K Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com System 50 20 System 50 OPTIONAL 1A FUSE 3 on 1A lin ec SCHEMATIC: Part Nos. 70RCK24 and 70MRCK24 System 50 SCHEMATIC: Part No. 70LRCK24 1 MOUNTING POST FOR EARTH GROUND CONNECTION LOGIC SUPPLY TERMINAL STRIP – – + + M0 5 4 7 6 9 8 11 10 13 12 15 14 17 16 19 18 1 2 3 4 M1 M2 M3 M4 21 20 23 22 M5 25 24 M6 27 26 29 28 M7 31 30 33 32 35 34 M8 37 36 M9 39 38 41 40 43 42 45 44 47 46 FIELD 48 WIRING TERMINAL STRIP M10 M11 MODULE LOCATION 5 6 7 8 9 m 49 47 45 43 41 39 37 35 33 31 29 27 25 23 21 19 17 15 13 11 9 7 5 3 1 co 50 48 46 44 42 40 38 36 34 32 30 28 26 24 22 20 18 16 14 12 10 8 6 4 2 3 2 (modules ordered separately) I/O Description UL 70RCK24 70RCK24-HL 70MRCK24-EC 70MRCK24-HL 70LRCK24-HL 70LRCK24-DIN 24 24 24 24 24 24 Card edge 50-pin header with Card edge 50-pin header with 50-pin header with 50-pin header, DIN ejector levers om Part Number po ORDERING INFORMATION ne nt s. PULL-UP RESISTOR NETWORK 10K OHM (3 PLACES) Style X X X X X X Standard Standard Mini Mini OpenLine ® OpenLine® Available from your local Grayhill Distributor. For prices and discounts, contact a local Sales Office, an authorized local Distributor, or Grayhill. System 50 on lin ec ejector levers ejector levers rail mount X X X X X X CSA System 50 21 Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com
70LRCK24-HL 价格&库存
很抱歉,暂时无法提供与“70LRCK24-HL”相匹配的价格&库存,您可以联系我们找货
