70GRCK16-HL
70GRCK16-HL
    GRAYHILLINC.
    I/O MOUNTING BOARD G5 16POS
70GRCK16-HL 数据手册
System 50 RACKS 16 Channel FEATURES • For use with System 50 Style Controllers • Available for Standard, Miniature, G5 and OpenLine® Modules (See p. L-4) • Panel and DIN Rail Mount Versions • UL, CSA Certified (see Engineering Information, p. L-3) 16 CHANNEL RACK: Standard Part No. 70RCK16 Dimensions are shown in inches (and millimeters). All tolerances are ± 0.010 (0,25) unless otherwise specified. 14.05 (356,9) 0.25 (6,4) 13.55 (344,2) 50 PIN EDGE CARD OR HEADER CONNECTOR FOR LOGIC SIGNALS (SEE NOTES) 0.40 (10,2) 5A FUSE FIELD WIRING TERMINAL STRIP LOGIC SUPPLY TERMINAL STRIP 0.45 (11,4) 32 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 +– 3.50 (88,9) 2.60 (66,0) 3.00 (76,2) Y B W R AC INPUT AC OUTPUT DC INPUT DC OUTPUT System 50 0 KEY SLOT PINS 11/13 1 2 3 4 5 6 7 8 PIN 1 USER INSTALLABLE JUMPER FOR +VCC (2 PLACES) STATUS LED 9 10 11 12 13 14 STANDOFF I.D. 0.15 (3,8) DIA. (4 PLACES) CLEARANCE FOR #6 SCREWS 15 0.25 (6,4) 2.20 (55,9) MAX. 0.75 (19,1) L-77 Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com System 50 16 CHANNEL RACK: Miniature Part No. 70MRCK16 Dimensions are shown in inches (and millimeters). All tolerances are ± 0.010 (0,25) unless otherwise specified. 0.40 (10,2) 10.00 (254,0) 0.45 (11,4) + 5A FUSE – 32 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 2.60 (66,0) 0.2 (5,1) 9.35 (237,5) FIELD WIRING TERMINAL STRIP LOGIC SUPPLY TERMINAL STRIP KEY SLOT PINS 11/13 PIN 1 3.50 3.00 (88,9) (76,2) Y B W R AC INPUT AC OUTPUT DC INPUT DC OUTPUT 0 1 2 3 4 5 6 7 USER INSTALLABLE JUMPER FOR +VCC (2 PLACES) 8 9 10 11 12 13 14 15 STATUS LED CARD EDGE OR HEADER CONNECTOR FOR LOGIC SIGNALS (SEE NOTES) MODULE HOLD DOWN STRIP WITH THUMB SCREWS 0.25 (6,4) STANDOFF I.D. 0.15 (3,8) DIA. (4 PLACES) CLEARANCE FOR #6 SCREW 2.20 (55,9) MAX. 0.75 (19,1) 16 CHANNEL RACK: G5 Part No. 70GRCK16 Dimensions are shown in inches (and millimeters). All tolerances are ± 0.010 (0,25) unless otherwise specified. 10.00 (254,0) 9.125 (231,8) FIELD WIRING TERMINAL STRIP LOGIC SUPPLY TERMINAL STRIP +– 0.2 (5,1) 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 System 50 3.25 2.75 (82,6) (69,9) PIN 1 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 STANDOFF I.D. 0.15 (3,8) DIA. (4 PLACES) CLEARANCE FOR #6 SCREW 0.25 (6,4) STATUS LED ON THE MODULE 3.39 (86,1) MAX. .093 (2,36) REF. 0.75 (19,1) Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com L-78 System 50 16 CHANNEL RACK: G5 Control and Field Connection Terminal Blocks Part No. 70GRCK16T Dimensions are shown in inches (and millimeters). All tolerances are ± 0.010 (0,25) unless otherwise specified. 9.500 (241,3) 9.000 (228,6) .250 (6,35) 32 POSITION TERMINAL STRIP FOR FIELD WIRING .250 (6,35) 32 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 FIELD SWAGED STANDOFF THRU HOLE .15 (3,81) DIA. (4 PLACES) (CLEARANCE FOR #6 SCREW) 3.250 (82,55) SPARE FUSE CONTROL 2.750 (69,85) 2 POSITION TERMINAL STRIP FOR CONTROL LOGIC +VCC – 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 32 POS. TERMINAL STRIP FOR CONTROL LOGIC STRIP KNURL FASTENER (16 PLACES) RES. 3.3 KΩ/.25W (2 PLACES) 3.392 (86,16) REF. .750 (19,05) REF. 1.687 (42,85) 16 CHANNEL RACK: G5 Channel-to-Channel Isolation DIN CARRIER 9.160 ± .020 (232,66 ± 0,51) Part No. 70GRCK16I and 70GRCK16I-DIN Dimensions are shown in inches (and millimeters). All tolerances are ± 0.010 (0,25) unless otherwise specified. PANEL MOUNT 9.000 ± .010 (228,6 ± 0,25) 8.500 ± .010 (215,9 ± 0,25) 32 POSITION TERMINAL STRIP FOR FIELD WIRING 9 8 7 6 5 4 3 2 1 FIELD 32 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 System 50 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 RES. 3.3 KΩ/.25W (16 PLACES) KNURL FASTENER (16 PLACES) DIN CARRIER 4.800 ± .020 (121,92 ± 0,51) GND CONTROL 3.500 ± .010 (88,9 ± 0,25) PANEL MOUNT 4.270 ± .010 (108,46 ± 0,25) 32 POS. TERMINAL STRIP FOR CONTROL LOGIC STRIP 4.00 (101,6) REF. 2.125 (53,98) L-79 Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com System 50 16 CHANNEL RACK: OpenLine® for System 50 Part No. 70LRCK16-HL Dimensions are shown in inches (and millimeters). All tolerances are ± 0.010 (0,25) unless otherwise specified. 5.5 (139.70) .24 (6.05) .25 (6.35) 5.0 (127.00) M0 50 49 50-PIN STRAIGHT HEADER CONNECTOR A M1 M2 M3 M4 M5 M6 M7 B REMOVABLE JUMPER CONNNECTS GND TO PLATED HOLE FOR GROUNDING 3.8 (96.52) 5A FUSE 4.3 (108.46) 2 1 PIN 1 FIELD WIRING TERMINAL STRIP STANDOFF I.D. 0.15 (3.81) DIA. (4 PLACES) CLEARANCE FOR #6 SCREW LOGIC SUPPLY TERMINAL STRIP TOP ROW: + LOGIC SUPPLY BOTTOM ROW: GND +5 +5 1 3 2 5 4 7 6 9 8 11 10 13 12 15 14 17 16 19 18 21 20 23 22 25 24 27 26 29 28 .75 (19.05) REF 31 30 3.4 (85.93) MAX 32 16 CHANNEL RACK: OpenLine® w/ DIN Rail Mount for System 50 Part No. 70LRCK16-DIN Dimensions are shown in inches (and millimeters). All tolerances are ± 0.010 (0,25) unless otherwise specified. DIN CARRIER 5.7 (143.76) PCB 5.5 (139.70) 50 49 M0 50-PIN STRAIGHT HEADER CONNECTOR A M1 M2 M3 M4 M5 M6 M7 B REMOVABLE JUMPER CONNNECTS GND TO PLATED HOLE FOR GROUNDING 5A FUSE PIN 1 FIELD WIRING TERMINAL STRIP 2 1 PCB 4.3 (108.46) LOGIC SUPPLY TERMINAL STRIP TOP ROW: + LOGIC SUPPLY BOTTOM ROW: GND +5 +5 1 3 2 5 4 7 6 9 8 11 10 13 12 15 14 17 16 19 18 21 20 23 22 25 24 27 26 29 28 3.8 (95.81) REF 31 30 32 2.2 (56.49) Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com L-80 System 50 DIN CARRIER 4.7 (119.13) System 50 SCHEMATIC: Part No. 70GRCK16 LOGIC SUPPLY TERMINAL STRIP – + 1 A FUSE USER INSTALLABLE JUMPER FOR +VCC 50 48 46 44 42 40 38 36 34 32 30 28 26 24 22 20 18 16 14 12 10 8 6 4 2 49 47 45 43 41 39 37 35 33 31 29 27 25 23 21 19 17 15 13 11 9 7 5 3 1 1 2 1 2 3 4 5 0 3 4 5 6 1 7 2 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 FIELD WIRING TERMINAL STRIP 3 4 5 6 7 8 9 10 11 12 13 14 15 MODULE POSITION N/C N/C N/C N/C N/C N/C N/C 3.3K 50 PIN HEADER CONNECTOR FOR LOGIC SIGNALS SCHEMATIC: Part No. 70GRCK16T 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 BARRIER STRIP FOR FIELD WIRING OF MODULE 1 2 3 4 5 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 MODULE LOCATION 15 28 29 30 GND 26 27 31 32 LOGIC GND 24 25 29 30 LOGIC 23 28 GND 21 22 26 27 LOGIC 24 25 LOGIC 19 20 23 CONTROL BARRIER STRIP SCHEMATIC: Part Nos. 70GRCK16I AND 70GRCK16I-DIN 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 31 32 BARRIER STRIP FOR FIELD WIRING OF MODULE 1 2 3 4 5 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 MODULE LOCATION 15 L-81 29 30 31 32 33 LOGIC +VCC LOGIC LOGIC GND +VCC 28 +VCC 26 27 LOGIC +VCC 24 25 +VCC LOGIC 23 LOGIC +VCC 21 22 +VCC 19 20 LOGIC 18 +VCC 17 LOGIC 15 16 LOGIC 13 14 +VCC 11 12 LOGIC LOGIC 10 +VCC +VCC 9 +VCC 8 LOGIC 7 +VCC 6 LOGIC 5 +VCC 4 LOGIC 3 +VCC 2 LOGIC 1 LOGIC PULL-UP RESISTOR 3.3 KΩ +VCC System 50 18 21 22 GND 19 20 GND 18 LOGIC 17 GND GND 15 16 LOGIC GND LOGIC 13 14 LOGIC GND LOGIC 11 12 GND GND LOGIC 10 GND 9 LOGIC 8 GND 7 LOGIC 6 LOGIC 5 GND 4 GND 3 LOGIC 2 LOGIC 1 GND + – VCC LOGIC PULL-UP RESISTOR 3.3 KΩ CONTROL BARRIER STRIP Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com System 50 SCHEMATIC: Part No. 70LRCK16-HL, -DIN 1 3 2 – LOGIC SUPPLY – TERMINAL + STRIP + 5 4 7 6 9 8 11 10 13 12 15 14 17 16 19 18 21 20 23 22 25 24 27 26 29 28 31 30 32 FIELD WIRING TERMINAL STRIP 1 2 3 4 M0 M1 M2 M3 M4 M5 M6 M7 MODULE LOCATION 50 48 46 44 42 40 38 36 34 32 30 28 26 24 22 20 18 16 14 12 10 8 6 4 2 49 47 45 43 41 39 37 35 33 31 29 27 25 23 21 19 17 15 13 11 9 7 5 3 1 5 6 7 8 9 N/C N/C N/C N/C N/C N/C N/C N/C SCHEMATIC: Part Nos. 70RCK16 and 70MRCK16 – + LOGIC SUPPLY TERMINAL STRIP USER INSTALLABLE JUMPER FOR +VCC (2 PLACES) 49 47 45 43 41 39 37 35 33 31 29 27 25 23 21 19 17 15 13 11 9 7 5 3 1 2 1 2 3 4 5 0 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 FIELD WIRING TERMINAL STRIP 5A FUSE 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 MODULE POSITION N/C N/C N/C N/C N/C N/C N/C System 50 50 PIN EDGE OR HEADER CONNECTOR FOR LOGIC SIGNALS 50 48 46 44 42 40 38 36 34 32 30 28 26 24 22 20 18 16 14 12 10 8 6 4 2 1 3.3K Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com L-82 System 50 ORDERING INFORMATION (modules ordered separately) Part Number I/O Description UL CSA Style 70RCK16 70RCK16-HL 70MRCK16-EC 70MRCK16-HL 70GRCK16-HL 70LRCK16-HL 70LRCK16-DIN 70GRCK16I 16 16 16 16 16 16 16 16 X X X X X X X X X X X X X X Standard Standard Mini Mini G5 OpenLine® OpenLine® X X G5 70GRCK16I-DIN 16 70GRCK16T 16 Card edge 50-pin header with ejector levers Card edge 50-pin header with ejector levers 50-pin header with ejector levers 50-pin header with ejector levers 50-pin header with DIN rail mnt. Positive or negative true logic* –Panel Mount Positive or negative true logic* –DIN rail mount Negative true logic*–Panel Mount X X X X G5 G5 SYSTEM 50 RACKS OVERVIEW See page L-69. Available from your local Grayhill Distributor. For prices and discounts, contact a local Sales Office, an authorized local Distributor, or Grayhill. * Positive true logic applies to output modules only. System 50 L-83 Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com
70GRCK16-HL 价格&库存
很抱歉,暂时无法提供与“70GRCK16-HL”相匹配的价格&库存,您可以联系我们找货
70GRCK16-HL
    库存:10
