70MRCK8-EC
70MRCK8-EC
    GRAYHILLINC.
    I/O MOUNTING BOARD MINI 8POS
70MRCK8-EC 数据手册
System 50 RACKS 8 Channel FEATURES • For use with System 50 Style Controllers • Available for Standard Miniature and OpenLine® Modules • Panel and DIN Rail Mount Versions • UL, CSA Certified 8 CHANNEL RACK: Standard Part No. 70RCK8 Dimensions are shown in inches (and millimeters). All tolerances are ± 0.010 (0,25) unless otherwise specified. NOTE: MAXIMUM TERMINAL SCREW TORQUE NOT TO EXCEED 5 IN-LBS. 8.00 (203,2) TERMINAL STRIP FOR LOGIC SUPPLY 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 KEY SLOT PINS 5/7 1 + AC INPUT AC OUTPUT DC INPUT DC OUTPUT 3.00 (76,2) 0 1 2 USER INSTALLABLE JUMPERS FOR +VCC (3 PLACES) 3 4 5 6 7 0.25 (6,4) System 50 0.40 (10,2) 3.50 (88,9) Y B W R 1 0.30 (7,6) PIN 1 + 2.60 (66,0) 16 + 1.40 (35,6) TERMINAL STRIP FOR FIELD WIRING - + 25/49 0.45 (11,4) STANDOFF I.D. 0.15 (3,8) DIA. (4 PLACES) CLEARANCE FOR #6 SCREW 7.50 (190,5) CARD EDGE OR HEADER CONNECTOR FOR LOGIC SIGNALS. (SEE NOTES) 0.25 (6,4) 2.20 (55,9) MAX. 0.75 (19,1) Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com System 50 6 System 50 8 CHANNEL RACK: DIN Rail Mount Part No. 70LRCK8-DIN Dimensions are shown in inches (and millimeters). All tolerances are ± 0.010 (0,25) unless otherwise specified. DIN CARRIER 3.7 (92.96) PCB 3.5 (89.15) 50-PIN STRAIGHT HEADER CONNECTOR DIN CARRIER 4.7 (119.13) PCB 4.3 (108.46) 50 49 M0 A M1 M2 M3 B REMOVABLE JUMPER CONNNECTS GND TO PLATED HOLE FOR GROUNDING 3.15A FUSE 2 1 PIN 1 FIELD WIRING TERMINAL STRIP NOTE: MAXIMUM TERMINAL SCREW TORQUE NOT TO EXCEED 5 IN-LBS. +5 +5 1 3 2 5 4 7 6 9 8 11 10 13 12 3.8 (95.81) REF 15 14 16 2.2 (56.49) System 50 LOGIC SUPPLY TERMINAL STRIP TOP ROW: + LOGIC SUPPLY BOTTOM ROW: GND System 50 Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com 7 System 50 8 CHANNEL RACK: Miniature Part No. 70MRCK8 Dimensions are shown in inches (and millimeters). All tolerances are ± 0.010 (0,25) unless otherwise specified. 6.00 (152,4) 0.40 (10,2) 5.20 (132,1) 0.45 (11,4) LOGIC SUPPLY TERMINAL STRIP 2.60 66,0) 1.40 (35,6) NOTE: MAXIMUM TERMINAL SCREW TORQUE NOT TO EXCEED 5 IN-LBS 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 +– 0.25 (6,35) FIELD WIRING TERMINAL STRIP KEY SLOT PINS 5/7 3.50 (88,9) 3.00 (76,2) Y B W R PIN 1 AC INPUT AC OUTPUT DC INPUT DC OUTPUT 0 1 2 3 4 5 6 7 STANDOFF I.D. 0.15 (3,8) DIA. (4 PLACES) CLEARANCE FOR #6 SCREW 5A FUSE CARD EDGE OR HEADER CONNECTOR FOR LOGIC SIGNALS (SEE NOTES) STATUS LED MODULE HOLD DOWN STRIP WITH THUMB SCREWS 2.20 (55,9) MAX. 0.75 (19,1) 8 CHANNEL RACK: G5 Part No. 70GRCK8 Dimensions are shown in inches (and millimeters). All tolerances are ± 0.010 (0,25) unless otherwise specified. NOTE: MAXIMUM TERMINAL SCREW TORQUE NOT TO EXCEED 5 IN-LBS. 6.00 (152,4) .620 (15,75) 5.125 (130,18) LOGIC SUPPLY TERMINAL STRIP .250 (6,35) +– 2.750 (69,85) System 50 HOLES FOR USER INSTALLED JUMPER (22 AWG) COPPER WIRE 3.250 (82,55) PIN 1 50 PIN STRAIGHT HEADER CONNECTOR STATUS LED ON THE MODULE FUSE PULLER STANDOFF I.D. 0.15 (3,8) DIA. (4 PLACES) CLEARANCE FOR #6 SCREW 3.40 (86,4) MAX. .75 (19,1) .093 (2,36) REF. Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com System 50 8 System 50 8 CHANNEL RACK: OpenLine® System 50 Part No. 70LRCK8 Dimensions are shown in inches (and millimeters). All tolerances are ± 0.010 (0,25) unless otherwise specified. 3.5 (88.90) .24 (6.05) .25 (6.35) 3.0 (76.20) M0 4.3 (108.46) 50 49 50-PIN STRAIGHT HEADER CONNECTOR A M1 M2 M3 B REMOVABLE JUMPER CONNNECTS GND TO PLATED HOLE FOR GROUNDING 3.8 (96.52) 3.15A FUSE 2 1 PIN 1 FIELD WIRING TERMINAL STRIP NOTE: MAXIMUM TERMINAL SCREW TORQUE NOT TO EXCEED 5 IN-LBS. STANDOFF I.D. 0.15 (3.81) DIA. (4 PLACES) CLEARANCE FOR #6 SCREW 3.4 (85.93) MAX LOGIC SUPPLY TERMINAL STRIP TOP ROW: + LOGIC SUPPLY BOTTOM ROW: GND +5 +5 1 3 2 5 4 7 6 9 8 11 10 13 12 15 14 .75 (19.05) REF 16 SCHEMATIC: Part Nos. 70RCK8, 70MRCK8 System 50 LOGIC SUPPLY TERMINAL STRIP – • • • 26 24 22 20 18 16 14 12 10 8 6 4 2 25 23 21 19 17 15 13 11 9 7 N/C 5 N/C 3 N/C 1 26-PIN EDGE CONNECTOR FOR LOGIC SIGNALS 50 48 46 44 42 40 38 36 34 32 30 28 26 24 22 20 18 16 14 12 10 8 6 4 2 1 2 1 2 3 4 5 0 3 4 5 6 7 8 9 10 11 12 13 14 15 16 + 49 47 45 43 41 39 37 35 33 31 29 27 25 23 21 19 17 15 13 11 9 7 5 3 1 FIELD WIRING TERMINAL STRIP 5A FUSE 1 2 3 4 5 6 7 MODULE POSITION N/C N/C N/C N/C N/C N/C N/C N/C N/C N/C N/C N/C N/C N/C 50-PIN EDGE OR HEADER CONNECTOR FOR LOGIC SIGNALS 3.3K USER INSTALLABLE JUMPERS FOR +VCC (3 PLACES) System 50 Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com 9 System 50 SCHEMATIC: Part No. 70GRCK8 LOGIC SUPPLY TERMINAL STRIP – + USER INSTALLABLE JUMPER FOR +VCC 50 48 46 44 42 40 38 36 34 32 30 28 26 24 22 20 18 16 14 12 10 8 6 4 2 49 47 45 43 41 39 37 35 33 31 29 27 25 23 21 19 17 15 13 11 9 7 5 3 1 1 2 1 2 3 4 5 0 3 4 5 6 1 7 8 2 9 10 11 12 13 14 15 16 3 4 5 6 FIELD WIRING TERMINAL STRIP 7 MODULE POSITION N/C N/C N/C N/C N/C N/C N/C N/C N/C N/C N/C N/C N/C N/C N/C N/C 3.3K 50 PIN HEADER CONNECTOR FOR LOGIC SIGNALS SCHEMATIC: Part No. 70LRCK8 – LOGIC – SUPPLY TERMINAL + STRIP + 1 3 2 5 4 7 6 9 8 11 10 13 12 15 14 16 FIELD WIRING TERMINAL STRIP 1 2 3 4 M0 M1 M2 M3 MODULE LOCATION ORDERING INFORMATION 49 47 45 43 41 39 37 35 33 31 29 27 25 23 21 19 17 15 13 11 9 7 5 3 1 5 6 7 8 9 N/C N/C N/C N/C N/C N/C N/C N/C N/C N/C N/C N/C N/C N/C N/C N/C System 50 50 48 46 44 42 40 38 36 34 32 30 28 26 24 22 20 18 16 14 12 10 8 6 4 2 PULL-UP RESISTOR NETWORK 10K OHM (modules ordered separately) Part Number I/O Description 70RCK8 70RCK8-HL 70MRCK8-EC 70MRCK8-HL 70GRCK8-HL 70LRCK8-HL 70LRCK8-DIN 8 8 8 8 8 8 8 Card edge 50-pin header Card edge 50-pin header 50-pin header 50-pin header 50-pin header with ejector levers with ejector levers with ejector levers with ejector levers with DIN rail mount UL CSA Style X X X X X Pend Pend X X X X X Pend Pend Standard Standard Mini Mini G5 OpenLine® OpenLine® Available from your local Grayhill Distributor. For prices and discounts, contact a local Sales Office, an authorized local Distributor or Grayhill. Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com System 50 10
70MRCK8-EC 价格&库存
很抱歉,暂时无法提供与“70MRCK8-EC”相匹配的价格&库存,您可以联系我们找货
