70MRCK16-EC
70MRCK16-EC
    GRAYHILLINC.
    I/O MOUNTING BOARD MINI 16POS
70MRCK16-EC 数据手册
System 50 RACKS 16 Channel FEATURES • For use with System 50 Style Controllers • Available for Standard, Miniature, G5 and OpenLine® Modules • Panel and DIN Rail Mount Versions • UL, CSA Certified 16 CHANNEL RACK: Standard Part No. 70RCK16 Dimensions are shown in inches (and millimeters). All tolerances are ± 0.010 (0,25) unless otherwise specified. NOTE: MAXIMUM TERMINAL SCREW TORQUE NOT TO EXCEED 5 IN-LBS. 14.05 (356,9) 0.25 (6,4) 13.55 (344,2) 50 PIN EDGE CARD OR HEADER CONNECTOR FOR LOGIC SIGNALS (SEE NOTES) 0.40 (10,2) 5A FUSE FIELD WIRING TERMINAL STRIP LOGIC SUPPLY TERMINAL STRIP 0.45 (11,4) 32 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 +– 3.50 (88,9) 2.60 (66,0) 3.00 (76,2) Y B W R AC INPUT AC OUTPUT DC INPUT DC OUTPUT 0 System 50 KEY SLOT PINS 11/13 1 2 3 4 5 6 7 8 PIN 1 USER INSTALLABLE JUMPER FOR +VCC (2 PLACES) STATUS LED 9 10 11 12 13 14 STANDOFF I.D. 0.15 (3,8) DIA. (4 PLACES) CLEARANCE FOR #6 SCREWS 15 0.25 (6,4) 2.20 (55,9) MAX. 0.75 (19,1) System 50 11 Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com System 50 16 CHANNEL RACK: Miniature Part No. 70MRCK16 Dimensions are shown in inches (and millimeters). All tolerances are ± 0.010 (0,25) unless otherwise specified. NOTE: MAXIMUM TERMINAL SCREW TORQUE NOT TO EXCEED 5 IN-LBS. 10.00 (254,0) 0.40 (10,2) .45 1,4) + 5A FUSE – 32 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 .60 6,0) 0.2 (5,1) 9.35 (237,5) FIELD WIRING TERMINAL STRIP LOGIC SUPPLY TERMINAL STRIP KEY SLOT PINS 11/13 3.50 3.00 (88,9) (76,2) PIN 1 Y AC INPUT B AC OUTPUT W DC INPUT R DC OUTPUT 0 1 2 3 4 5 6 7 USER INSTALLABLE JUMPER FOR +VCC (2 PLACES) 8 9 10 11 12 13 14 15 STATUS LED CARD EDGE OR HEADER CONNECTOR FOR LOGIC SIGNALS (SEE NOTES) MODULE HOLD DOWN STRIP WITH THUMB SCREWS 0.25 (6,4) STANDOFF I.D 0.15 (3,8) DIA. (4 PLACES) CLEARANCE FOR #6 SCRE 2.20 (55,9) MAX. 0.75 (19,1) 16 CHANNEL RACK: G5 Part No. 70GRCK16 Dimensions are shown in inches (and millimeters). All tolerances are ± 0.010 (0,25) unless otherwise specified. NOTE: MAXIMUM TERMINAL SCREW TORQUE NOT TO EXCEED 5 IN-LBS. 10.00 (254,0) 9.125 (231,8) FIELD WIRING TERMINAL STRIP LOGIC SUPPLY TERMINAL STRIP System 50 +– 0.2 (5,1) 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 3.25 2.75 (82,6) (69,9) PIN 1 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 STANDOFF I.D. 0.15 (3,8) DIA. (4 PLACES) CLEARANCE FOR #6 SCREW 0.25 (6,4) STATUS LED ON THE MODULE 3.39 (86,1) MAX. .093 (2,36) REF. 0.75 (19,1) Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com System 50 12 System 50 16 CHANNEL RACK: G5 Control and Field Connection Terminal Blocks Part No. 70GRCK16T Dimensions are shown in inches (and millimeters). All tolerances are ± 0.010 (0,25) unless otherwise specified. NOTE: MAXIMUM TERMINAL SCREW TORQUE NOT TO EXCEED 5 IN-LBS. 9.500 (241,3) 9.000 (228,6) .250 (6,35) 32 POSITION TERMINAL STRIP FOR FIELD WIRING .250 (6,35) 32 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 3 2 1 FIELD SWAGED STANDOFF THRU HOLE .15 (3,81) DIA. (4 PLACES) (CLEARANCE FOR #6 SCREW) 3.250 (82,55) SPARE FUSE CONTROL 2.750 (69,85) 2 POSITION TERMINAL STRIP FOR CONTROL LOGIC +VCC – 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 KNURL FASTENER (16 PLACES) RES. 3.3 KΩ/.25W (2 PLACES) 32 POS. TERMINAL STRIP FOR CONTROL LOGIC STRIP 3.392 (86,16) REF. .750 (19,05) REF. 1.687 (42,85) 16 CHANNEL RACK: G5 Channel-to-Channel Isolation Part No. 70GRCK16I and 70GRCK16I-DIN Dimensions are shown in inches (and millimeters). All tolerances are ± 0.010 (0,25) unless otherwise specified. DIN CARRIER 9.160 ± .020 (232,66 ± 0,51) PANEL MOUNT 9.000 ± .010 (228,6 ± 0,25) 8.500 ± .010 (215,9 ± 0,25) 32 POSITION TERMINAL STRIP FOR FIELD WIRING 9 8 7 6 5 4 3 2 1 FIELD 32 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 System 50 3.500 ± .010 (88,9 ± 0,25) 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 RES. 3.3 KΩ/.25W (16 PLACES) KNURL FASTENER (16 PLACES) DIN CARRIER 4.800 ± .020 (121,92 ± 0,51) GND CONTROL NOTE: MAXIMUM TERMINAL SCREW TORQUE NOT TO EXCEED 5 IN-LBS. PANEL MOUNT 4.270 ± .010 (108,46 ± 0,25) 32 POS. TERMINAL STRIP FOR CONTROL LOGIC STRIP 4.00 (101,6) REF. 2.125 (53,98) System 50 13 Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com System 50 16 CHANNEL RACK: OpenLine® for System 50 Part No. 70LRCK16-HL Dimensions are shown in inches (and millimeters). All tolerances are ± 0.010 (0,25) unless otherwise specified. 5.5 (139.70) .24 (6.05) .25 (6.35) 5.0 (127.00) M0 50 49 50-PIN STRAIGHT HEADER CONNECTOR A M1 M2 M3 M4 M5 M6 M7 B REMOVABLE JUMPER CONNNECTS GND TO PLATED HOLE FOR GROUNDING 3.8 (96.52) 5A FUSE 4.3 (108.46) 2 1 PIN 1 FIELD WIRING TERMINAL STRIP NOTE: MAXIMUM TERMINAL SCREW TORQUE NOT TO EXCEED 5 IN-LBS. STANDOFF I.D. 0.15 (3.81) DIA. (4 PLACES) CLEARANCE FOR #6 SCREW LOGIC SUPPLY TERMINAL STRIP TOP ROW: + LOGIC SUPPLY BOTTOM ROW: GND +5 +5 1 3 2 5 4 7 6 9 8 11 10 13 12 15 14 17 16 19 21 18 20 23 22 25 24 27 26 29 28 .75 (19.05) REF 31 30 32 3.4 (85.93) MAX 16 CHANNEL RACK: OpenLine® w/ DIN Rail Mount for System 50 Part No. 70LRCK16-DIN Dimensions are shown in inches (and millimeters). All tolerances are ± 0.010 (0,25) unless otherwise specified. DIN CARRIER 5.7 (143.76) PCB 5.5 (139.70) 50 49 M0 A M1 M2 M3 M4 M5 M6 M7 B DIN CARRIER 4.7 (119.13) REMOVABLE JUMPER CONNNECTS GND TO PLATED HOLE FOR GROUNDING 5A FUSE PIN 1 FIELD WIRING TERMINAL STRIP 2 1 PCB 4.3 (108.46) System 50 50-PIN STRAIGHT HEADER CONNECTOR NOTE: MAXIMUM TERMINAL SCREW TORQUE NOT TO EXCEED 5 IN-LBS. LOGIC SUPPLY TERMINAL STRIP TOP ROW: + LOGIC SUPPLY BOTTOM ROW: GND +5 +5 1 3 2 5 4 7 6 9 8 11 10 13 12 15 14 17 16 19 18 21 20 23 22 25 24 27 26 29 28 3.8 (95.81) REF 31 30 32 2.2 (56.49) Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com System 50 14 System 50 SCHEMATIC: Part No. 70GRCK16 LOGIC SUPPLY TERMINAL STRIP – + 1 A FUSE USER INSTALLABLE JUMPER FOR +VCC 49 47 45 43 41 39 37 35 33 31 29 27 25 23 21 19 17 15 13 11 9 7 5 3 1 50 48 46 44 42 40 38 36 34 32 30 28 26 24 22 20 18 16 14 12 10 8 6 4 2 1 2 1 2 3 4 5 0 3 4 5 6 1 7 2 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 FIELD WIRING TERMINAL STRIP 3 4 5 6 7 8 9 10 11 12 13 14 15 MODULE POSITION N/C N/C N/C N/C N/C N/C N/C 3.3K 50 PIN HEADER CONNECTOR FOR LOGIC SIGNALS SCHEMATIC: Part No. 70GRCK16T 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 BARRIER STRIP FOR FIELD WIRING OF MODULE 1 2 3 4 5 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 MODULE LOCATION 15 System 50 15 29 30 31 32 33 +VCC LOGIC LOGIC LOGIC LOGIC GND +VCC 28 +VCC 26 27 +VCC 24 25 +VCC 23 LOGIC +VCC 21 22 LOGIC LOGIC 19 20 +VCC LOGIC 18 LOGIC LOGIC 17 +VCC 15 16 LOGIC 13 14 +VCC 11 12 +VCC 10 +VCC 9 +VCC 8 LOGIC 7 +VCC 6 LOGIC 5 +VCC 4 LOGIC 3 +VCC 2 LOGIC 1 +VCC PULL-UP RESISTOR 3.3 K: LOGIC System 50 SCHEMATIC: Part Nos. 70GRCK16I AND 70GRCK16I-DIN CONTROL BARRIER STRIP Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com System 50 SCHEMATIC: Part No. 70LRCK16-HL, -DIN 1 3 2 – LOGIC SUPPLY – TERMINAL + STRIP + 5 7 4 6 9 8 11 10 13 12 15 14 17 16 19 18 21 20 23 22 25 24 27 26 29 28 31 30 32 FIELD WIRING TERMINAL STRIP 1 2 3 4 M0 M1 M2 M3 M4 M5 M6 M7 MODULE LOCATION 50 48 46 44 42 40 38 36 34 32 30 28 26 24 22 20 18 16 14 12 10 8 6 4 2 49 47 45 43 41 39 37 35 33 31 29 27 25 23 21 19 17 15 13 11 9 7 5 3 1 5 6 7 8 9 N/C N/C N/C N/C N/C N/C N/C N/C SCHEMATIC: Part Nos. 70RCK16 and 70MRCK16 – + LOGIC SUPPLY TERMINAL STRIP USER INSTALLABLE JUMPER FOR +VCC (2 PLACES) 49 47 45 43 41 39 37 35 33 31 29 27 25 23 21 19 17 15 13 11 9 7 5 3 1 2 1 2 3 4 5 0 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 FIELD WIRING TERMINAL STRIP 5A FUSE 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 MODULE POSITION System 50 50 PIN EDGE OR HEADER CONNECTOR FOR LOGIC SIGNALS 50 48 46 44 42 40 38 36 34 32 30 28 26 24 22 20 18 16 14 12 10 8 6 4 2 1 N/C N/C N/C N/C N/C N/C N/C 3.3K Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com System 50 16 System 50 ORDERING INFORMATION (modules ordered separately) Part Number I/O Description UL 70RCK16 70RCK16-HL 70MRCK16-EC 70MRCK16-HL 70GRCK16-HL 70LRCK16-HL 70LRCK16-DIN 70GRCK16I 16 16 16 16 16 16 16 16 X X X X X X X X X X X X X X Standard Standard Mini Mini G5 OpenLine® OpenLine® X X G5 70GRCK16I-DIN 16 70GRCK16T 16 Card edge 50-pin header with ejector levers Card edge 50-pin header with ejector levers 50-pin header with ejector levers 50-pin header with ejector levers 50-pin header with DIN rail mnt. Positive or negative true logic* –Panel Mount Positive or negative true logic* –DIN rail mount Negative true logic*–Panel Mount CSA Style X X X X G5 G5 Available from your local Grayhill Distributor. For prices and discounts, contact a local Sales Office, an authorized local Distributor, or Grayhill. * Positive true logic applies to output modules only. System 50 System 50 Grayhill, Inc. • 561 Hillgrove Avenue • LaGrange, Illinois 60525-5997 • USA • Phone: 708-354-1040 • Fax: 708-354-2820 • www.grayhill.com 17
70MRCK16-EC 价格&库存
很抱歉,暂时无法提供与“70MRCK16-EC”相匹配的价格&库存,您可以联系我们找货
