DIP12-1A72-12D
DIP12-1A72-12D
    STANDEX-MEDER(斯丹麦德)
    插件
    Reed Relay SPST-NO (1 Form A) Through Hole
DIP12-1A72-12D 数据手册
A Global Leader in the Design, Development, and Manufacture of Sensor and Magnetic Components www.standexmeder.com Series Datasheet – DIP Reed Relays DIP Series Reed Relays  Features: Dual In-Line IC Compatible Relay, Available with Dielectric Strength 4.25VDC  Applications: General Purpose, Measuring and Testing Devices & Others  Markets: Telecommunications, Test and Measurement, Security & Others DIP 00-0X00-00X Part Description: Nominal Voltage Contact QTY Contact Form Switch Model Pin Out 05, 12, 15, 24 1, 2 A, B, C 72, 75, 90 10, 11, 12, 13, 19, 21, 51 Option () Version with Magnetic Shield A, B, C, L(M), D(Q), E(R), F(S) Customer Options Contact Data 72 75 90 Rated Power (max.) 10 10 10 W 200 500 175 V 0.5 0.5 0.5 A 1.0 1.0 1.2 A 100 200 150 mOhm 0.25 0.6 0.2 kVDC 0.5 0.5 0.7 ms 0.1 0.1 1.5 ms 1010 1010 109 GOhm 0.3 0.4 1.0 pF Switch Model Any DC combination of V&A not to exceed their individual max.’s Switching Voltage (max.) DC or peak AC Switching Current (max.) DC or peak AC Carry Current (max.) DC or peak AC Contact Resistance (max.) @ 0.5V & 50mA Breakdown Voltage (min.) According to EN60255-5 Operating Time (max.) Incl. Bounce; Measured with w/ Nominal Voltage Release Time (max.) Measured with no Coil Excitation Insulation Resistance (typ.) Rh
DIP12-1A72-12D 价格&库存
很抱歉,暂时无法提供与“DIP12-1A72-12D”相匹配的价格&库存,您可以联系我们找货
