UMS05-1A80-75L
UMS05-1A80-75L
    STANDEX-MEDER(斯丹麦德)
    SIP,3.6x6.9mm
    RELAY REED SPST 500MA 5V
UMS05-1A80-75L 数据手册
A Global Leader in the Design, Development, and Manufacture of Sensor and Magnetic Components www.standexmeder.com Series Datasheet – UMS Reed Relays UMS Series Reed Relays  Features: Ultraminiature Single-In Line Relay  Applications: PCB Test Systems, Automated Test Systems, Closely Stacked Matrices & Others  Markets: Test and Measurement, Telecommunication, Security & Others UMS 05-1A80-75X Part Description: Nominal Voltage Contact QTY Contact Form Switch Model Pin Out Option 05 1 A 80 75 L, D Customer Options Contact Data Switch Model Rated Power (max.) 10 W 170 V 0.5 A 0.5 A 200 mOhm 0.210 kVDC 0.2 ms 0.1 ms 1011 GOhm 0.2 pF 80 Any DC combination of V&A not to exceed their individual max.’s Switching Voltage (max.) DC or peak AC Switching Current (max.) DC or peak AC Carry Current (max.) DC or peak AC Contact Resistance (max.) @ 0.5V & 50mA Breakdown Voltage (min.) According to EN60255-5 Operating Time (max.) Incl. Bounce; Measured with w/ Nominal Voltage Release Time (max.) Measured with no Coil Excitation Insulation Resistance (typ.) Rh
UMS05-1A80-75L 价格&库存
很抱歉,暂时无法提供与“UMS05-1A80-75L”相匹配的价格&库存,您可以联系我们找货
