SHV12-1A85-78D3K
SHV12-1A85-78D3K
    STANDEX-MEDER(斯丹麦德)
    RELAY_24.13X6.22MM_TM
    线圈电压12V.电流1A 切换电压1000V 耐压3KV
SHV12-1A85-78D3K 数据手册
A Global Leader in the Design, Development, and Manufacture of Sensor and Magnetic Components www.standexmeder.com Series Datasheet – SHV Reed Relays SHV Series Reed Relays  Features: Small Size High Voltage Relay, High Dielectric Strength up to 4 kVDC, Internal Magnetic Shield  Applications: Portable Test and Medical Equipment, Defibrillators, Cable and In-Circuit Tester & Others  Markets: Test and Measurement, Medical & Others SHV 00-1A85-78X0K Part Description: Nominal Voltage Contact QTY Contact Form Switch Model Pin Out Option Breakdown Voltage 05, 12 1 A 85 78 D, L 2K, 3K, 4K Customer Options Contact Data Switch Model Rated Power (max.) 100 W 1,000 V 1.0 A 2.5 A 150 mOhm 2/3/4 kVDC 1.1 ms 0.1 ms 1010 Ohm 0.5 pF 85 Any DC combination of V&A not to exceed their individual max.’s Switching Voltage (max.) DC or peak AC Switching Current (max.) DC or peak AC Carry Current (max.) DC or peak AC Contact Resistance (max.) @ 0.5V & 50mA Breakdown Voltage (min.) According to EN60255-5 Operating Time (max.) Incl. Bounce; Measured with w/ Nominal Voltage Release Time (max.) Measured with no Coil Excitation Insulation Resistance (typ.) Rh
SHV12-1A85-78D3K 价格&库存
很抱歉,暂时无法提供与“SHV12-1A85-78D3K”相匹配的价格&库存,您可以联系我们找货
