DIL05-2C90-63L
DIL05-2C90-63L
    STANDEX-MEDER(斯丹麦德)
    插件,10.4x20.3mm
    Reed Relay DPDT (2 Form C) Through Hole
DIL05-2C90-63L 数据手册
A Global Leader in the Design, Development, and Manufacture of Sensor and Magnetic Components www.standexmeder.com Series Datasheet – DIL Reed Relays DIL Series Reed Relays  Features Compatible with 14 pin DIL socket, High resistance coil up to 11 kOhm available  Available with Dielectric Strength 4.25kVDC, Diode, Magnetic Shield & Others  Markets: General purposes, Telecommunications, Test and Measurement & Others DIL 00-0X00-00X Part Description: Nominal Voltage Contact QTY Contact Form Switch Model Pin Out 05, 12, 24 1, 2, 4 A, C 66, 75, 88, 90 13, 15, 21, 51, 62, 63 Option () Version with Magnetic Shield L(M), D(Q), E(R), F(S) Customer Options Contact Data 66 75 88 90 Rated Power (max.) 10 10 50 10 W 200 500 500 175 V 0.5 0.5 2 0.5 A 1.0 1.0 2 1.0 A 150 200 80 150 mOhm 0.225 1.5 1.5 0.2 kVDC 0.5 0.5 1.2 0.7 ms 0.1 0.1 1.0 1.5 ms 1010 1010 1011 109 GOhm 0.2 0.4 0.3 1.0 pF Switch Model Any DC combination of V&A not to exceed their individual max.’s Switching Voltage (max.) DC or peak AC Switching Current (max.) DC or peak AC Carry Current (max.) DC or peak AC Contact Resistance (max.) @ 0.5V & 50mA Breakdown Voltage (min.) According to EN60255-5 Operating Time (max.) Incl. Bounce; Measured with w/ Nominal Voltage Release Time (max.) Measured with no Coil Excitation Insulation Resistance (typ.) Rh
DIL05-2C90-63L 价格&库存
很抱歉,暂时无法提供与“DIL05-2C90-63L”相匹配的价格&库存,您可以联系我们找货
DIL05-2C90-63L
  • 1+178.29531
  • 100+175.59812
  • 250+171.29721
  • 500+166.10070
库存:53
