24031060020
24031060020
    HARTING(浩亭)
    HA-VISECON3060BT-A-PP
24031060020 数据手册
Ha-VIS eCon 3000 Fast Ethernet Basic PoE / PoE+ 24 V DC/DC 5 to 8 Ethernet ports RJ45, FOC, PoE+, 24 V DC/DC transformer English Unmanaged Plug and Play Ethernet switches for DIN rail assembly in control cabinets Commercial temp.: 0 °C ... +55 °C / Industrial ­­ temp.: -40 °C ... +70 °C Energy Efficient Ethernet ■ Use of PoE+ with 24 V DC supply (galvanically isolated) ■ Energy supply of up to 4 terminal devices via PoE+ (137 watts) in accordance with IEEE 802.3at ■ Fast Ethernet Non-Blocking Switch architecture in accordance with IEEE 802.3 ■ Variants with industrial temperature range of -40 °C ... +70 °C ■ Surge protection and reverse polarity protection ■ Minimum energy consumption due to energy-efficient Ethernet ■ Optimised DIN rail bracket Target markets Machinery & Robotics Automation Industrial network infrastructures Wind Energy, Solar Energy Transportation Shipbuilding General description The Ha-VIS eCon 3000 Fast Ethernet PoE family of unmanaged Ethernet switches is equipped with up to 8 Fast Ethernet ports and allow for costefficient and quick expansion and/or reconstruction of network infrastructures. The switches work as power sourcing equipment (PSE) and are capable of simultaneously providing the full PoE output of 34.2 watts on up to four ports. Exceeding the PoE+ standard, the switches are equipped with an integrated, galvanically isolated DC/DC voltage transformer. The switches can be supplied with 24 VDC instead of the usually required 54 VDC. The selection includes various combinations of variants with RJ45 and fibre optic ports. Automatic detection of the transmission rate (auto-negotiation) and of the wiring of the twisted pair data cable (auto-polarity and auto-MDI(X)) allow for simple plug and play. All variants are available with the temperature ranges "Industrial" and "Commercial". Technical characteristics Switch Features Ethernet ports 10BASE-Te / 100BASE-TX Enclosure width 60 mm Type of connection RJ45 Number of ports 5, 6, 7, 8 Auto-negotiation Yes Yes Switching technology Store and Forward Auto-polarity Supported standards IEEE 802.3 Frame size Auto-MDI(X) 1522 bytes MAC table size Transfer conditions 1k entries Transfer speed 10 / 100 Mbit/s Transfer length 100 m (twisted pair, Cat 5) Packet buffer size 448 kbit Non-blocking Yes Quality of Service Yes Energy-efficient Ethernet Yes PROFINET-compatible Yes EthernetIP-compatible Yes Yes Twisted pair Ethernet ports100BASE-FX Type of fibre Multi-mode (MM) Type of connection Transfer conditions FOC Wavelength Power supply 1310 nm Transfer speed Nominal voltage 24 VDC Permissible voltage range 18 VDC ... 60 VDC Surge protection Yes Reverse polarity proof Yes Starting current 1.60 A Overcurrent protection at input Max. power consumption @ 24 VDC Conductor cross-section Type of connection Pinout Yes (10 A) See eCatalogue 0.08 mm² ... 2.5 mm² (28 AWG ... 12 AWG) 3-pole, pluggable screw type terminal block +/-/ Supply circuit (according to 60950) SELV (circuit breaker 10 A) Transfer length Output power Input sensitivity Service hotline: +49 5772 47-97100, Fax: +49 5772 47-495 Electric@HARTING.com, www.HARTING.com 100 Mbit/s 2 km 15 km -20 dBm ... -14 dBm -15 dBm ... -8 dBm ≤ -30 dBm ≤ -32 dBm Ambient conditions Commercial temperature range Industrial temperature range Storage temperature range 0 °C ... +55 °C -40 °C ... +70 °C -40 °C ... +85 °C Relative humidity (operation) 0% ... 95 % (non-condensing) Relative humidity (storage and transport) 0% ... 95 % (non-condensing) Air pressure HARTING Technology Group P.O.Box 1473, D-32325 Espelkamp Wilhelm-Harting-Straße 1, D-32325 Espelkamp, Germany Single-mode (SM) SC Duplex 2000 m (795 hPa) Note: We reserve the right to make technical changes to the products and to the content of this document at any time without prior notification. The HARTING Technologiegruppe does not accept any responsibility for possible errors or incompletions in this document. We reserve all the rights to this document and the topics and illustrations contained within it. Copying, disclosure to third parties or use of its content - even partially - is forbidden without the prior written consent of the HARTING Technologiegruppe. PoE Enclosures Number of PoE ports 4 Standard IEEE 802.3af / IEEE 802.3at PoE type PSE Supported mode Alternative A Power supply PSE 24 VDC Maximum power consumption PSE 2380 mA Maximum current Maximum output power PSE 638 mA (PoE) 15.4 W per port 61.6 W total (PoE+) 34.2 W per port 136.8 W total See 802.3at, section 33.1.4 PoE pinout Alternative A, MDI-X (1/2 = V-, 3/6 = V+) Status and diagnostic displays Power ("Pwr") illuminated green Supply voltage is applied Link/Activity ("L/A") off No link Link/Activity ("L/A") illuminated green Link/Activity ("L/A") flashes green 60 mm 142 mm x 60 mm x 107.5 mm Weight 375 mA Supported cabling Enclosure width Dimensions H x W x D (without pluggable screw type terminal block and holding bracket) Link is active Link is active and data is transferred Link speed ("Spd") off 10 Mbit/s Link speed ("Spd") illuminated yellow 100 Mbit/s PoE status off PoE status illuminated blue Voltage in PoE+ range PoE status illuminated red Fault PoE is inactive / low voltage 430 g ... 445 g Type of installation 35 mm DIN rail acc. to EN 60 715 Material enclosures Anodised aluminium / powder-coated steel sheet Protection class (with plugged screw type terminal block) IP30 Protection class III Approvals CE EMC and environmental conditions EMC interference immunity (EN 61000-6-1, 61 000-6-2 55024) Electrostatic discharge (ESD) EN 61 000-4-2 Electromagnetic field EN 61 000-4-3 Rapid transients (burst) EN 61 000-4-4 Surge voltages EN 61 000-4-5 Conducted interference voltages EN 61 000-4-6 EMC interference emission (EN 61000-6-4, EN 55 022, FCC CFR 47 Part 15) Mechanical stability (EN 60721-3) IEC 60068-2-6 Vibration IEC 60068-2-6 Resonance search IEC 60068-2-27 Shock test Included in delivery ■ Pluggable screw type terminal block for power supply ■ Installation instructions Drawings Technical characteristics / order information Ports / order information RJ45 SFP SC Enclosure width Power consumption @ 24 VDC without PoE Commercial temp.: 0 °C ... +55 °C MTBF in million h Switch Part no. Industrial temp.: -40 °C ... +70 °C Switch Part no. 4 - 1x MM (2 km) 60 mm 5.81 0.82 Ha-VIS eCon 3041B-AD-PP 24 03 104 1130 Ha-VIS eCon 3041BT-AD-PP 24 03 104 1120 4 - 1x SM (15 km) 60 mm 5.81 0.82 Ha-VIS eCon 3041B-AF-PP 24 03 104 1230 Ha-VIS eCon 3041BT-AF-PP 24 03 104 1220 4 - 2x MM (2 km) 60 mm 5.84 0.81 Ha-VIS eCon 3042B-AD-PP 24 03 104 2130 Ha-VIS eCon 3042BT-AD-PP 24 03 104 2120 4 - 2x SM (15 km) 60 mm 5.84 0.81 Ha-VIS eCon 3042B-AF-PP 24 03 104 2230 Ha-VIS eCon 3042BT-AF-PP 24 03 104 2220 6 - - 60 mm 5.77 0.85 Ha-VIS eCon 3060B-A-PP 24 03 106 0030 Ha-VIS eCon 3060BT-A-PP 24 03 106 0020 6 - 1x MM (2 km) 60 mm 5.82 0.80 Ha-VIS eCon 3061B-AD-PP 24 03 106 1130 Ha-VIS eCon 3061BT-AD-PP 24 03 106 1120 6 - 1x SM (15 km) 60 mm 5.82 0.80 Ha-VIS eCon 3061B-AF-PP 24 03 106 1230 Ha-VIS eCon 3061BT-AF-PP 24 03 106 1220 8 - - 60 mm 5.78 0.83 Ha-VIS eCon 3080B-A-PP 24 03 108 0030 Ha-VIS eCon 3080BT-A-PP 24 03 108 0020 Copyright© 2014 HARTING Technology Group Date of issue 08.2015 All rights reserved ICPN Datasheet 0846/02
24031060020 价格&库存
很抱歉,暂时无法提供与“24031060020”相匹配的价格&库存,您可以联系我们找货
