24035060020
24035060020
    HARTING(浩亭)
    HA-VISECON3060GBT-A-PP
24035060020 数据手册
Ha-VIS eCon 3000 Full Gigabit Ethernet Basic PoE+ 24 V DC/DC 5 to 7 Ethernet ports RJ45, FOC, PoE+, 24 V DC/DC transformer English Unmanaged Plug and Play Ethernet switches for DIN rail assembly in control cabinets Commercial temp.: 0 °C ... +55 °C / Industrial ­­ temp.: -40 °C ... +70 °C Energy Efficient Ethernet ■ Use of PoE+ with 24 VDC supply (galvanically isolated) ■ Energy supply of up to 4 terminal devices via PoE+ (137 watts) in accordance with IEEE 802.3at ■ Full Gigabit Ethernet non-blocking switch architecture according to IEEE 802.3 ■ Support of jumbo frames (10 kB) ■ Variants with industrial temperature range of -40 °C ... +70 °C ■ Surge protection and reverse polarity protection ■ Energy-efficient Ethernet according to 802.3az ■ Optimised DIN rail bracket Target markets Machinery & Robotics Automation Industrial network infrastructures Wind Energy, Solar Energy Transportation Shipbuilding General description The Ha-VIS eCon 3000 Full Gigabit family of unmanaged Ethernet switches is equipped with up to 7 gigabit Ethernet ports and allows for cost-efficient and quick expansion and/or reconstruction of network infrastructures with high bandwidth requirements. In this, all variants support extra-long Ethernet frames (jumbo frames). The switches work as power sourcing equipment (PSE) and are capable of simultaneously providing the full PoE output of 34.2 watts on up to four ports. Exceeding the PoE+ standard, the switches are equipped with an integrated, galvanically isolated DC/DC voltage transformer. The switches can be supplied with 24 VDC instead of the usually required 54 VDC. The selection includes various combinations of variants with RJ45 and fibre optic cables. Automatic detection of the transmission rate (auto-negotiation) and of the wiring of the twisted pair data cable (auto-polarity and auto-MDI(X)) allow for simple plug and play. All variants are available with the temperature ranges "Industrial" and "Commercial". Technical characteristics Switch Features Ethernet ports 10BASE-Te / 100BASE-TX EEE / 1000BASE-TX EEE Enclosure width 60 mm Type of connection RJ45 Number of ports 5, 6, 7 Auto-negotiation Yes Yes Switching technology Store and Forward Auto-polarity Supported standards IEEE 802.3 Frame size Auto-MDI(X) 10 kBytes MAC table size Transfer conditions 8k entries Transfer speed 10 / 100 / 1000 Mbit/s Transfer length 100 m (Twisted Pair, Cat 5) Packet buffer size 1 Mbit Non-blocking Yes Quality of Service Yes Energy-efficient Ethernet Yes PROFINET-compatible Yes EthernetIP-compatible Yes Yes Twisted pair Ethernet ports 1000BASE-SX / 1000BASE-FX Type of fibre Multi-mode (MM) Type of connection Transfer conditions Wavelength Power supply FOC 850 nm Transfer speed Nominal voltage 24 VDC Permissible voltage range 18 VDC ... 60 VDC Surge protection Yes Reverse polarity proof Yes Starting current 1.60 A Overcurrent protection at input Max. power consumption @ 24 VDC Conductor cross-section Type of connection Pinout Yes (10 A) See eCatalogue 0.08 mm² ... 2.5 mm² (28 AWG ... 12 AWG) 3-pole, pluggable screw type terminal block +/-/ Supply circuit (according to 60950) SELV (circuit breaker 10 A) HARTING Technology Group P.O.Box 1473, D-32325 Espelkamp Wilhelm-Harting-Straße 1, D-32325 Espelkamp, Germany Service hotline: +49 5772 47-97100, Fax: +49 5772 47-495 Electric@HARTING.com, www.HARTING.com Transfer length Output power Input sensitivity Single-mode (SM) SC Duplex 1310 nm 1000 Mbit/s 0.55 km 10 km -9,5 dBm ... -4 dBm -9,5 dBm ... -3 dBm ≤ -17 dBm ≤ -21 dBm SFP ports Transfer standard Depending on used SFP Type of connection Depending on used SFP, RJ45 or LC Transfer conditions Depending on used SFP, TP or FOC Transfer speed Transfer length Depending on used SFP, 100 or 1000 Mbit/s Depending on used SFP Note: We reserve the right to make technical changes to the products and to the content of this document at any time without prior notification. The HARTING Technologiegruppe does not accept any responsibility for possible errors or incompletions in this document. We reserve all the rights to this document and the topics and illustrations contained within it. Copying, disclosure to third parties or use of its content - even partially - is forbidden without the prior written consent of the HARTING Technologiegruppe. PoE Enclosures Number of PoE ports 4 Standard IEEE 802.3af / IEEE 802.3at PoE type PSE Supported mode Alternative A Enclosure width Dimensions H x W x D (without pluggable screw type terminal block and holding bracket) 60 mm 142 mm x 60 mm x 107.5 mm Power supply PSE 24 VDC Maximum power consumption PSE Weight 2380 mA Type of installation 35 mm DIN rail acc. to EN 60 715 Material enclosures Anodised aluminium / Powder-coated steel sheet Maximum current Maximum output power PSE 375 mA 638 mA (PoE) 15.4 W per port 61.6 W total (PoE+) 34.2 W per port 136.8 W total Supported cabling See 802.3at, section 33.1.4 PoE pinout Alternative A, MDI-X (1/2 = V-, 3/6 = V+) Status and diagnostic displays Power ("Pwr") illuminated green Supply voltage is applied Link/Activity ("L/A") off No link Link/Activity ("L/A") illuminated green Link is active Link/Activity ("L/A") flashes green Link is active and data is transferred Link speed ("Spd") off 10 Mbit/s Link speed ("Spd") illuminated yellow 100 Mbit/s Link speed ("Spd") illuminated green 1000 Mbit/s off PoE status illuminated blue Voltage in PoE+ range PoE status illuminated red Fault PoE is inactive / low voltage Ambient conditions IP30 Protection class III Approvals CE EMC and environmental conditions EMC interference immunity (EN 61000-6-1, 61 000-6-2 55024) Electrostatic discharge (ESD) EN 61 000-4-2 Electromagnetic field EN 61 000-4-3 Rapid transients (burst) EN 61 000-4-4 Surge voltages EN 61 000-4-5 Conducted interference voltages EN 61 000-4-6 Industrial temperature range -40 °C ... +70 °C Storage temperature range -40 °C ... +85 °C Mechanical stability (EN 60721-3) IEC 60068-2-6 Vibration IEC 60068-2-6 Resonance search IEC 60068-2-27 Shock test Included in delivery ■ Pluggable screw type terminal block for power supply ■ Installation instructions 0 °C ... +55 °C Relative humidity (operation) 0 % ... 95 % (non-condensing) Relative humidity (storage and transport) 0 % ... 95 % (non-condensing) Air pressure Protection class (with pluggable screw type terminal block) EMC interference emission (EN 61000-6-4, EN 55 022, FCC CFR 47 Part 15) PoE status Commercial temperature range See eCatalogue 2000 m (795 hPa) Drawings Technical characteristics / order information Ports / order information Commercial temp.: 0 °C ... +55 °C Industrial temp.: -40 °C ... +70 °C Power consumption @ 24 VDC without PoE MTBF in million h Switch Part no. Switch Part no. RJ45 SFP SC Enclosure width 4 - 1x MM (0.55 km) 60 mm 5.88 0.82 Ha-VIS eCon 3041GB-AD-PP 24 03 504 1130 Ha-VIS eCon 3041GBT-AD-PP 24 03 504 1120 4 - 1x SM (10 km) 60 mm 5.88 0.80 Ha-VIS eCon 3041GB-AF-PP 24 03 504 1230 Ha-VIS eCon 3041GBT-AF-PP 24 03 504 1220 4 - 2x MM (0.55 km) 60 mm 5.90 0.81 Ha-VIS eCon 3042GB-AD-PP 24 03 504 2130 Ha-VIS eCon 3042GBT-AD-PP 24 03 504 2120 4 - 2x SM (10 km) 60 mm 5.90 0.81 Ha-VIS eCon 3042GB-AF-PP 24 03 504 2230 Ha-VIS eCon 3042GBT-AF-PP 24 03 504 2220 4 3 - 60 mm 5.90 0.57 Ha-VIS eCon 3043GB-AC-PP 24 03 504 3330 Ha-VIS eCon 3043GBT-AC-PP 24 03 504 3320 5 - - 60 mm 5.88 0.80 Ha-VIS eCon 3050GB-A-PP 24 03 505 0030 Ha-VIS eCon 3050GBT-A-PP 24 03 505 0020 5 - 1x MM (0.55 km) 60 mm 5.90 0.79 Ha-VIS eCon 3051GB-AD-PP 24 03 505 1130 Ha-VIS eCon 3051GBT-AD-PP 24 03 5051120 5 - 1x SM (10 km) 60 mm 5.90 0.79 Ha-VIS eCon 3051GB-AF-PP 24 03 505 1230 Ha-VIS eCon 3051GBT-AF-PP 24 03 505 1220 5 2 - 60 mm 5.90 0.55 Ha-VIS eCon 3052GB-AC-PP 24 03 505 2330 Ha-VIS eCon 3052GBT-AC-PP 24 03 505 2320 6 - - 60 mm 5.90 0.76 Ha-VIS eCon 3060GB-A-PP 24 03 5060030 Ha-VIS eCon 3060GBT-A-PP 24 03 506 0020 6 1 - 60 mm 5.90 0.53 Ha-VIS eCon 3061GB-AC-PP 24 03 506 1330 Ha-VIS eCon 3061GBT-AC-PP 24 03 506 1320 7 - - 60 mm 5.90 0.52 Ha-VIS eCon 3070GB-A-PP 24 03 507 0030 Ha-VIS eCon 3070GBT-A-PP 24 03 507 0020 Copyright© 2014 HARTING Technology Group All rights reserved Date of issue 08.2015 ICPN Datasheet 0852/02
24035060020 价格&库存
很抱歉,暂时无法提供与“24035060020”相匹配的价格&库存,您可以联系我们找货
库存:3
24035060020
  • 1+15835.243311+2058.10417
库存:3
