DLP-USB1232H
DLP-USB1232H
    DLPDESIGN
    MODULE USB-TO-UART/FIFO HS 18DIP
DLP-USB1232H 数据手册
DLPUSB1232H LEAD-FREE HIGH-SPEED USB ADAPTER The DLP-USB1232H is DLP Design’s premier USB-to-UART/FIFO interface module based on FTDI’s 5th generation USB 2.0 High Speed (480Mb/s) silicon. The DLPUSB1232H is available in a lead-free, RoHS-compliant, compact 18-pin, 0.1-inch spaced standard DIP footprint. FEATURES: The DLP-USB1232H has the capability of being configured in a variety of industry standard serial or parallel interfaces supporting these features: • Entire USB protocol handled on the module. No USB specific firmware programming required. • USB 2.0 High Speed (480Mbits/Second) and Full Speed (12Mbits/Second) compatible. • Multi-Protocol Synchronous Serial Engine (MPSSE) to simplify synchronous serial protocol (USB to JTAG, I2C, SPI or bit-bang) design. • RS232/RS422/RS485 UART Transfer Data Rate up to 12Mbaud. (RS232 Data Rate limited by external level shifter). • USB to parallel FIFO transfer data rate up to 8 Mbyte/Sec. • CPU-style FIFO interface mode simplifies CPU interface design. • FTDI’s royalty-free Virtual Com Port (VCP) and Direct (D2XX) drivers eliminate the requirement for USB driver development in most cases. • Adjustable receive buffer timeout. • Transmit and receive LED drive signals. • FT245B-style FIFO interface option with bidirectional data bus and simple 4 wire handshake interface. • Asynchronous serial UART interface option with full hardware handshaking and modem interface signals. • Fully assisted hardware or X-On / X-Off software handshaking. • UART Interface supports 7/8 bit data, 1/2 stop bits, and Odd/Even/Mark/Space/No Parity. • Auto-transmit enable control for RS485 serial applications using TXDEN pin. • Operational configuration mode and USB Description strings configurable in on-boardl EEPROM over the USB interface. • Configurable I/O drive strength (4, 8, 12 or 16mA) and slew rate. • Low operating and USB suspend current. • Supports bus powered, self powered and high-power bus powered USB configurations. • UHCI/OHCI/EHCI host controller compatible. • USB Bulk data transfer mode (512 byte packets in High Speed mode). • +3.3V I/O interfacing (+5V Tolerant). • Extended -40°C to 85°C industrial operating temperature range. Rev. 1.3 (December 2009) 1 © DLP Design, Inc. APPLICATION AREAS: • Upgrading legacy peripherals to USB • Interfacing MCU/PLD/FPGA-based designs to USB • USB to UART (RS232, RS422 or RS485) • USB to FIFO • USB to JTAG • USB to SPI • USB to I2C • USB to Bit-Bang • USB to CPU target interface (as memory) • PDA to USB data transfer • USB Smart Card Readers • USB Instrumentation • USB Industrial Control • USB MP3 Player Interface • USB FLASH Card Reader / Writers • Set Top Box PC - USB interface • USB Digital Camera Interface • USB Bar Code Readers • USB audio and low-bandwidth video data transfer • USB hardware modems • USB wireless modems DRIVER SUPPORT: Royalty-Free Virtual COM Port (VCP) Drivers for: • Windows 2000, Server 2003, Server 2008 • Windows XP and XP 64-bit • Windows Vista and Vista 64-bit • Windows XP Embedded • Windows CE 4.2, 5.0, 5.2 and 6.0 • Mac OS-X • Linux 2.6.9 or later Royalty-Free D2XX Direct Drivers (USB Drivers + DLL S/W Interface) for: • Windows 2000, Server 2003, Server 2008 • Windows XP and XP 64-bit • Windows Vista and Vista 64-bit • Windows XP Embedded • Windows CE 4.2, 5.0, 5.2 and 6.0 • Linux 2.4 or later and Linux x86_64 The drivers listed above are all available for free download from the DLP Design website www.dlpdesign.com and FTDI website www.ftdichip.com. Various third-party drivers are also available for other operating systems; see the FTDI website www.ftdichip.com for details. Rev. 1.3 (December 2009) 2 © DLP Design, Inc. ABSOLUTE MAXIMUM RATINGS • Storage Temperature • Ambient Temperature (Power Applied) • VCC Supply Voltage • DC Input Voltage: Inputs • DC Input Voltage: High-Impedance Bidirectionals • DC Output Current: Outputs -65°C to +150°C -40 to +85°C -0.5V to +6.00V -0.5V to VCC + 0.5V -0.5V to VCC + 0.5V 16mA D.C. CHARACTERISTICS (AMBIENT TEMPERATURE: -40 TO 85°C) • VCC Operating-Supply Voltage • VCCIO Digital IO Voltage • Operating Supply Current • Operating Supply Current 4.0 - 5.5V 3.3V 75mA (Normal Operation) 500uA USB Suspend 1.0 GENERAL DESCRIPTION The DLP-USB1232H USB 2.0 High Speed (480Mb/s) to UART/FIFO uses FTDI’s 5th generation USB silicon. It has the capability of being configured in a variety of industry standard serial or parallel interfaces. The DLP-USB1232H can be configured for UART, FIFO, JTAG, SPI, I2C or bit-bang mode. In addition to these, the DLP-USB1232H supports a CPU interface FIFO mode. Refer to the FT2232H datasheet for additional detail on how to set up and use the supported modes. Rev. 1.3 (December 2009) 3 © DLP Design, Inc. 2.0 PIN DESCRIPTIONS This section describes the operation of the DLP-USB1232H pins. The function of the I/O pins is determined by the configuration that is stored in the EEPROM connected to the FT2232H USB IC. The following table details the function of each pin for the specified mode. Note that the convention used throughout this document for active low signals is the signal name followed by a #. Pins marked ** default to tri-stated inputs with an internal 75K Ohm (approx) pull up resistor to VCCIO (3.3V). DLP-USB1232H Pin Pin Functions For Each Supported Mode ASYNC Pin # Pin Name Serial 245 FIFO (RS232) ASYNC SYNC Bit-bang Bit-bang MPSSE CPU Target Channel A 18 ADBUS0 TXD D0 D0 D0 TCK/SK D0 16 ADBUS1 RXD D1 D1 D1 TDI/DO D1 2 ADBUS2 RTS# D2 D2 D2 TDO/DI D2 5 ADBUS3 CTS# D3 D3 D3 TMS/CS D3 17 ADBUS4 DTR# D4 D4 D4 GPIOL0 D4 4 ADBUS5 DSR# D5 D5 D5 GPIOL1 D5 13 ADBUS6 DCD# D6 D6 D6 GPIOL2 D6 3 ADBUS7 RI# D7 D7 D7 GPIOL3 D7 15 ACBUS0 TXDEN RXF# ** ** GPIOH0 CS# 14 ACBUS1 TXE# WRSTB# WRSTB# GPIOH1 A0 11 ACBUS2 RD# RDSTB# RDSTB# GPIOH2 RD# 12 ACBUS3 TXLED# WR# ** ** GPIOH3 WR# 7 ACBUS4 RXLED# SIWUA SIWUA SIWUA GPIOH4 SIWUA Rev. 1.3 (December 2009) 4 © DLP Design, Inc. 2.0 TIMING DIAGRAMS - 245 FIFO MODE T6 T5 RXF# T1 T2 RD# T3 T4 D D[7..0] Description Min Max Unit TIME T1 T2 T3 T4 T5 T6 Valid data DESCRIPTION RD# Active Pulse Width RD# to RD# Pre-Charge RD# Active to Valid Data* Valid Data Hold Time from RD# Inactive* RD# Inactive to RXF# output active RXF# Inactive After RD Cycle *Load = 30pF MIN 50 T5 + T6 20 0 0 33 MAX 50 25 67 UNIT nS nS nS nS nS nS MAX 25 84 UNIT nS nS nS nS nS nS T12 T11 TXE# T7 T8 WR T10 T9 D[7 ..0] TIME T7 T8 T9 T10 T11 T12 Valid data DESCRIPTION WR Active Pulse Width WR to WR Pre-Charge Time Valid Data Setup to WR Falling Edge* Valid Data Hold Time from WR Inactive* WR Inactive to TXE# TXE# Inactive After WR Cycle MIN 10 50 20 10 10 49 *Load = 30pF Rev. 1.3 (December 2009) 5 © DLP Design, Inc. 3.0 APPLICATION NOTES USB devices transfer data in packets. If data is to be sent from the PC, a packet is built up by the application program and is sent via the device driver to the USB scheduler. This scheduler adds a request to the list of tasks that the USB host controller will perform. This will typically take at least 1 millisecond to execute because it will not pick up the new request until the next USB frame (the frame period is 1 millisecond). There is, therefore, sizeable overhead (depending upon your required throughput) associated with moving data from the application to the USB device. If data is sent one byte at a time by an application, this will severely limit the overall throughput of the system. It must be stressed that in order to achieve maximum throughput, application programs should send or receive data using buffers and not individual characters. 4.0 DRIVER SOFTWARE FTDI's VCP (Virtual COM Port) USB driver files are provided royalty free on the condition that they are only used with designs incorporating an FTDI device (i.e. the FT2232H and DLPUSB1232H). The latest version of the drivers can be downloaded from either www.dlpdesign.com or www.ftdichip.com. The CDM driver download file is a combined set of drivers for the Windows operating system and contains both the VCP and D2XX driver versions. To download, simply unzip the file to a folder on your PC. (The drivers can coexist on the same floppy disk or folder since the INF files determine which set of drivers to load for each operating-system version.) Once loaded, the VCP drivers will allow your application software—running on the host PC—to communicate with the DLP-USB1232H as though it were connected to a COM (RS-232) port. In addition to VCP drivers, FTDI's D2XX direct drivers for Windows offer an alternative solution to the VCP drivers that allow application software to interface with the FT2232H device using a DLL instead of a Virtual COM Port. The architecture of the D2XX drivers consists of a Windows WDM driver that communicates with the FT2232H device via the Windows USB stack and a DLL that interfaces with the application software (written in VC++, C++ Builder, Delphi, VB, etc.) to the WDM driver. The D2XX direct drivers add support for simultaneous access and control of multiple DLPUSB1232H devices. The extended open function (FT_OpenEx) allows the device to be opened either by its product description or serial number, both of which can be programmed to be unique. The list devices function (FT_ListDevices) allows the application software to determine which devices are currently available for use, again by either product description or serial number. Download FTDI Application Notes AN_103 and AN_104 for detailed instructions on how to install the drivers on XP and Vista platforms. Rev. 1.3 (December 2009) 6 © DLP Design, Inc. 5.0 EEPROM WRITE UTILITY The DLP-USB1232H has the option to accept manufacturer-specific information that is written into EEPROM memory. Parameters that can be programmed include the VID and the PID identifiers, the manufacturer's product string and a serial number. MPROG is the latest EEPROM programming utility for the FT2232H device. You must install the latest release of the CDM drivers in order to run this application. If you have CDM drivers installed on the PC that is to perform the EEPROM write process, you can run MPROG and update the EEPROM contents with either mode (VCP or D2XX) active. 6.0 QUICK START GUIDE This guide requires the use of a Windows XP/Vista PC that is equipped with a USB port. 1. Download the latest CDM device drivers from either www.dlpdesign.com or www.ftdichip.com. Unzip the drivers into a folder on the hard drive. 2. Connect the DLP-USB1232H module to the PC via a USB ‘A’ to mini-B cable. This action initiates the loading of the USB drivers. When prompted, select the folder where the device drivers were stored in Step 1. Windows will then complete the installation of the device drivers for the DLP-USB1232H module. The next time the DLP-USB1232H module is attached, the host PC will immediately load the correct drivers without any prompting. Reboot the PC if prompted to do so. At this point, the DLP-USB1232H is ready for use. Note that if the DLP-USB1232H is configured for 245 FIFO mode that it will appear non-responsive if data sent from the host PC is not read by an attached microcontroller, microprocessor, DSP, FPGA, ASIC, etc. 7.0 PINOUT DESCRIPTION Pin 18 Pin 1 USB Pin 10 Pin 9 Top View (Interface Headers on bottom of PCB) Rev. 1.3 (December 2009) 7 © DLP Design, Inc. PIN # 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 PARALLEL SIGNAL USAGE DESCRIPTION GROUND DB2 - FIFO Data Bus Bit 2 DB7 - FIFO Data Bus Bit 7 DB5 - FIFO Data Bus Bit 5 DB3 - FIFO Data Bus Bit 3 PWREN - Active low power-enable output. PWREN# = 0: Normal operation. PWREN# = 1: USB SUSPEND mode or device has not been configured. This can be used by external circuitry to power down logic when device is in USB suspend or has not been configured. SIWUA -The Send Immediate / WakeUp signal combines two functions on a single pin. If USB is in suspend mode (PWREN# = 1) and remote wakeup is enabled in the EEPROM, strobing this pin low will cause the device to request a resume on the USB Bus. Normally, this can be used to wake up the Host PC. During normal operation (PWREN# = 0), if this pin is strobed low any data in the device TX buffer will be sent out over USB on the next Bulk-IN request from the drivers regardless of the pending packet size. This can be used to optimize USB transfer speed for some applications. Tie this pin to VCCIO if not used. EXTVCC - Use for applying main power (4.5 to 5.25 volts) to the module. Connect to PORTVCC (Pin 9) if the module is to be powered by the USB port (typical configuration). PORTVCC - Power from the USB port. Connect to EXTVCC (Pin 8) if the module is to be powered by the USB port (typical configuration). 500mA is the maximum current available to the USB adapter and target electronics if the USB device is configured for high power. GROUND RD# - When pulled low, RD# takes the 8 data lines from a high-impedance state to the current byte in the FIFO’s buffer. Taking RD# high returns the data pins to a highimpedance state and prepares the next byte (if available) in the FIFO to be read. WR - When taken from a high to a low state, WR reads the 8 data lines and writes the byte into the FIFO’s transmit buffer. Data written to the transmit buffer is sent to the host PC within the TX buffer timeout value (default 16mS) and placed in the buffer that was created when the USB port was opened. The FT245R allows the TX buffer timeout value to be reprogrammed to a value between 1 and 255mS. DB6 - FIFO Data Bus Bit 6 TXE# - When high, do not write data into the FIFO. When low, data can be written into the FIFO by strobing WR high, then low. During reset this signal pin is tri-state. Data is latched into the FIFO on the falling edge of the WR pin. RXF# - When low, at least 1 byte is present in the FIFO’s receive buffer and is ready to be read with RD#. RXF# goes high when the receive buffer is empty. During reset this signal pin is tri-state. If the Remote Wakeup option is enabled in the internal EEPROM, during USB Suspend Mode (PWREN#=1) RXF# becomes an input. This can be used to wake up the USB host from Suspend Mode by strobing this pin low for a minimum of 20ms which will cause the device to request a resume on the USB bus. DB1 - FIFO Data Bus Bit 1 DB4 - FIFO Data Bus Bit 4 DB0 - FIFO Data Bus Bit 0 Rev. 1.3 (December 2009) 8 © DLP Design, Inc. PIN # 1 2 3 4 5 6 7 SERIAL SIGNAL USAGE DESCRIPTION GROUND RTS - Request to Send Control Output/Handshake Signal RI - Ring Indicator Control Input. When remote wake-up is enabled in the internal EEPROM taking RI# low (20ms active low pulse), this can be used to resume the PC USB host controller from Suspend. DSR - Data Set Ready Control Input/Handshake Signal CTS - Clear To Send Control Input/Handshake Signal PWREN - Active low power-enable output. PWREN# = 0: Normal operation. PWREN# = 1: USB SUSPEND mode or device has not been configured. This can be used by external circuitry to power down logic when device is in USB suspend or has not been configured. RXLED - Receive signaling output. Pulses low when receiving data via USB. This should be connected to an LED. 10 11 12 EXTVCC - Use for applying main power (4.5 to 5.25 volts) to the module. Connect to PORTVCC (Pin 9) if the module is to be powered by the USB port (typical configuration). PORTVCC - Power from the USB port. Connect to EXTVCC (Pin 8) if the module is to be powered by the USB port (typical configuration). 500mA is the maximum current available to the USB adapter and target electronics if the USB device is configured for high power. GROUND RDSTB# TXLED# - Transmit signaling output. Pulses low when transmitting data via USB. This should be 13 14 15 16 17 18 DCD# - Data Carrier Detect Control Input WRSTB# TXDEN - (TTL level). For use with RS485 level converters. RXD - Receiving Asynchronous Data Input DTR# - Data Terminal Ready Control Output/Handshake Signal TXD - Transmit Asynchronous Data Output 8 9 connected to an LED. Rev. 1.3 (December 2009) 9 © DLP Design, Inc. 8.0 DEVICE CONFIGURATION EXAMPLES USB Bus-Powered and Self-Powered Configurations 7 8 9 Figure 1. Bus-Powered 5V System The figure above illustrates a typical USB bus-powered configuration. A USB bus-powered device gets its power from the USB bus. 5.0V 7 8 9 Figure 2. Self-Powered 5V System Figure 2 illustrates a typical USB self-powered configuration. A USB self-powered device gets its power from its own power supply and does not draw current from the USB bus. 3.3 - 5V Microcontroller 8 Data Lines Figure 3. 7 8 9 RXF# RD# TXE# WR Bus-Powered 5V System with 3.3V Logic Interface Figure 3 shows how to configure the DLP-USB1232H to interface with a microcontroller via the parallel 245 FIFO interface mode. In this example, the target electronics can operate at from 3.3 - 5 volts since the DLP-USB1232H interface I/O pins are 5 volt tolerant. Rev. 1.3 (December 2009) 10 © DLP Design, Inc. 3.3V TXD RXD Figure 4. 7 8 9 Bus-Powered 5V System with 3.3 Volt Logic Interface Figure 4 shows how to configure the DLP-USB1232H to interface with a 3.3V logic device via the ASYNC serial mode. In this example, the target electronics provide the 3.3 volts to power the microcontroller. 9.0 BUS-POWERED CIRCUIT WITH POWER CONTROL USB bus-powered circuits need to be able to power down in USB Suspend Mode in order to meet the Suspend current requirement (including external logic): P-Channel Power MOSFET S D G .1uF 10K 1K Microcontroller VCC Figure 4. PWREN# 7 8 9 Power Controlled by PWREN# Figure 4 shows how to use a discrete P-Channel MOSFET to control the power to external logic circuits. This “soft-start” circuit accommodates designs that draw more than 100mA at power up. Rev. 1.3 (December 2009) 11 © DLP Design, Inc. 10.0 MECHANICAL DRAWINGS (PRELIMINARY) INCHES (MILLIMETERS) UNLESS OTHERWISE NOTED 0.22 typ (5.6 typ) 0.21 typ (5.3 typ) Side View 0.23 typ (5.8 typ) 0.43 typ (10.9 typ) 0.37 typ (9.4 typ) 0.10 typ (2.5 typ) 0.09 typ (2.3 typ) 0.60 typ (15.2 typ) 0.025 typ (0.64 typ) (square post) 1.26 typ (32.1 typ) 0.30 typ (7.6 typ) 11.0 DISCLAIMER © DLP Design, Inc., 2009 Neither the whole nor any part of the information contained herein nor the product described in this manual may be adapted or reproduced in any material or electronic form without the prior written consent of the copyright holder. This product and its documentation are supplied on an as-is basis, and no warranty as to their suitability for any particular purpose is either made or implied. DLP Design, Inc. will not accept any claim for damages whatsoever arising as a result of the use or failure of this product. Your statutory rights are not affected. This product or any variant of it is not intended for use in any Rev. 1.3 (December 2009) 12 © DLP Design, Inc. medical appliance, device or system in which the failure of the product might reasonably be expected to result in personal injury. This document provides preliminary information that may be subject to change without notice. 12.0 CONTACT INFORMATION DLP Design, Inc. 1605 Roma Lane Allen, TX 75013 Phone: 469-964-8027 Fax: 415-901-4859 Email Sales: sales@dlpdesign.com Email Support: support@dlpdesign.com Website URL: http://www.dlpdesign.com Rev. 1.3 (December 2009) 13 © DLP Design, Inc. D 5 1 6 3 U2 NCP605-3.3V VIN VOUT VIN EN SENSE GND P3V3 C7 .1uF 4 5 P3V3 2 C8 EECS EESK EEDATA C12 4 C11 4.7uF .1uF C13 C10 .1uF R4 12K R5 10K P3V3 Y1 12MHz VPLL VPHY TEST 3 P3V3 ADBUS0/TXD/D0/TCK SK ADBUS1/RXD/D1/TDI DO ADBUS2/RTS#/D2/TDO DI ADBUS3/CTS#/D3/TMS CS ADBUS4/DTR#/D4/GPIOL0 ADBUS5/DSR#/D5/GPIOL1 ADBUS6/DCD#/D6/GPIOL2 ADBUS7/RI#/D7/GPIOL3 ACBUS0/TXDEN/RXF#/GPIOH0 ACBUS1/WRSTB#/TXE#/GPIOH1 ACBUS2/RDSTB#/RD#/GPIOH2 ACBUS3/TXLED#/WR#/GPIOH3 ACBUS4/RXLED#/SIWUA/GPIOH4 ACBUS5/-/CLKOUT/GPIOH5 ACBUS6/-/OE#/GPIOH6 ACBUS7/-/-/GPIOH7 BDBUS0/TXD/DO/TCK SK BDBUS1/RXD/D1/TDI DO BDBUS2/RTS#/D2/TDO DI BDBUS3/CTS#/D3/TMS CS BDBUS4/DTR#/D4/GPIOL0 BDBUS5/DSR#/D5/GPIOL1 BDBUS6/DCD#/D6/GPIOL3 BDBUS7/RI#/D7/GPIOL4 PWREN# SUSPEND# BCBUS0/TXDEN/RXF#/GPIOH0 OSCI BCBUS1/WRSTB#/TXE#/GPIOH1 BCBUS2/RDSTB#/RD#/GPIOH2 BCBUS3/TXLED#/WR#/GPIOH3 BCBUS4/RXLED#/SIWUB/GPIOH4 OSCO BCBUS5/-/-/GPIOH5 BCBUS6/-/-/GPIOH6 BCBUS7/PWRSAV#/PWRSAV#/GPIOH7 EECS EECLK EEDATA DM DP RESET# REF VREGOUT VREGIN U1 FT1232HQ 50 49 14 6 7 8 63 62 61 2 3 13 3 C15 .1uF C16 .1uF C17 2 C14 .1uF RTS# RI# DSR# CTS# PWREN RXLED# EXTVCC PORTVCC PWREN DB2 DB7 DB5 DB3 PWREN SIWUA EXTVCC PORTVCC P3V3 1 FB2 240-1018-1 2 1 C18 C20 2 4.7uF/10V FB3 240-1018-1 1 4.7uF/10V 18 17 16 15 14 13 12 11 10 18 17 16 15 14 13 12 11 10 1 J1 Serial Signal Usage 1 2 3 4 5 6 7 8 9 J1 Parallel Signal Usage 1 2 3 4 5 6 7 8 9 C19 .1uF C21 .1uF VPHY VPLL DCD# TXLED# TXD DTR# RXD TXDEN DB0 DB4 DB1 RXF# TXE# DB6 WR# RD# Note: Only one J1 is present. Two connectors are shown here to show the functional use models - one for parallel and one for serial. RXF# or TXDEN TXE# or WRSTB# RD# or RDSTB# WR# or TXLED# SIWUA or RXLED# DB0 or TXD DB1 or RXD DB2 or RTS# DB3 or CTS# DB4 or DTR# DB5 or DSR# DB6 or DCD# DB7 or RI# 245 or 232 mode Parallel or Serial Mode .1uF 16 17 18 19 21 22 23 24 26 27 28 29 30 32 33 34 38 39 40 41 43 44 45 46 48 52 53 54 55 57 58 59 60 36 2 FT2232HQ pin definitions: PIN NAME/232/245/MPSSE C23 27pF C22 27pF P3V3 P5V0 C3 .1uF R6 10K R3 1K .1uF C1 10/10 Tant FB1 240-1018-1 10uF/10V 1 C2 .01 1 2 3 4 R2 2K2 20 31 42 56 P5V0 C6 1.0uF/0603 2 EXTVCC 1 2 3 4 5 U3 R7 0 PORTVCC 8 7 6 5 10K VCCIO VCCIO VCCIO VCCIO GND GND GND GND GND GND GND GND VCC CS NC SK NC/ORG DIN GND DOUT 93LC46 R1 12 37 64 1 5 11 15 25 35 47 51 CN1 USB B Conn P3V3 C9 .1uF DLP-USB1232H v1.2 4 VCORE VCORE VCORE AGND C B A 5 4 9 VPHY VPLL 10 D C B A
DLP-USB1232H 价格&库存
很抱歉,暂时无法提供与“DLP-USB1232H”相匹配的价格&库存,您可以联系我们找货
