DLP-USB232M User’s Manual
DLP-USB232M-G USB – SERIAL UART Interface Module
The DLP-USB232M-G lead free module uses FTDI’s 2nd generation FT232BM USB-UART chip that adds extra
functionality to its predecessor (the FT8U232AM) and reduces external component count.
HARDWARE FEATURES
• Single Chip USB Asynchronous Serial Data Transfer
• EEPROM programmable on-board via USB
• Full Handshaking & Modem Interface Signals
VIRTUAL COM PORT ( VCP ) DRIVERS for
• UART I/F Supports 7 / 8 Bit Data, 1 / 2 Stop Bits and
- Windows 98 and Windows 98 SE
Odd/Even/Mark/Space/No Parity
- Windows 2000 / ME / XP
• Data rate 300 => 3M Baud ( TLL )
- Windows CE **
• Data rate 300 => 1M Baud ( RS232 )
- MAC OS-8 and OS-9
• Data rate 300 => 3M Baud ( RS422/RS485 )
- MAC OS-X **
• 384 Byte Receive Buffer / 128 Byte Transmit Buffer
- Linux 2.40 and greater
for high data throughput
D2XX ( USB Direct Drivers + DLL S/W Interface )
• Adjustable RX buffer timeout
• Full hardware assisted hardware or X-On / X-Off
handshaking
[ ** = In planning or under development ]
• In-built support for event characters and line break
APPLICATION AREAS
condition
• Auto Transmit Buffer control for RS485
- USB - RS232 Converters
• Support for USB Suspend / Resume through SLEEP#
- USB - RS422 / RS485 Converters
and RI# pins
• Support for high power USB Bus powered devices
through PWREN# pin
• Integrated level converter on UART and control
signals for interfacing to 5v and 3.3v logic
- Upgrading RS232 Legacy Peripherals to USB
- Cellular and Cordless Phone USB data transfer
cables and interfaces
- Interfacing MCU based designs to USB
- USB Audio and Low Bandwidth Video data transfer
• Integrated 3.3v regulator for USB IO
- PDA - USB data transfer
• Integrated Power-On-Reset circuit
- USB Smart Card Readers
• Integrated 6MHz – 48Mhz clock multiplier PLL
- Set Top Box (S.T.B ) PC - USB interface
• USB Bulk or Isocronous data transfer modes
- USB Hardware Modems
• 4.4v to 5.25v single supply operation
- USB Wireless Modems
• UHCI / OHCI / EHCI host controller compatible
- USB Instrumentation
• USB 1.1 and USB 2.0 compatible
- USB Bar Code Readers
• USB VID, PID , Serial Number and Product
Description strings in external EEPROM
Copyright © DLP Design 2002
Page 1 of 12
ENHANCEMENTS
This section summarizes the enhancements of the 2nd
generation silicon from FTDI compared to its FT8U232AM
predecessor. For further details, consult the device pin-out
description and functional descriptions.
• Integrated Level Converter on UART interface and
control signals
The previous devices would drive the UART and control
signals at 5v CMOS logic levels. The new device has
• Lower Suspend Current
a separate VCC-IO pin allowing the device to directly
Integration of RCCLK within the device and internal
interface to 3.3v and other logic families without the need
design improvements reduce the suspend current of the
for external level converter i.c.’s.
FT232BM to under 200uA ( excluding the 1.5k pull-up
on USB DP ) in USB suspend mode. This allows greater
• Improved Power Management control for USB Bus
margin for peripherals to meet the USB Suspend current
Powered, high current devices
limit of 500uA.
The previous devices had a USBEN pin, which became
active when the device was enumerated by USB. To
• Support for USB Isocronous Transfers
provide power control, this signal had to be externally
While USB Bulk transfer is usually the best choice for
gated with SLEEP# and RESET#. This gating is now
data transfer, the scheduling time of the data is not
done on-chip. USBEN has now been replaced with the
guaranteed. For applications where scheduling latency
new PWREN# signal which can be used to directly drive
takes priority over data integrity such as transferring
a transistor or P-Channel MOSFET in applications where
audio and low bandwidth video data, the new device now
power switching of external circuitry is required. A new
offers an option of USB Isocronous transfer via an option
EEPROM based option makes the device pull gently
bit in the EEPROM.
down its UART interface lines when the power is
shut off (PWREN# is High ). In this mode, any residual
• Programmable Receive Buffer Timeout
voltage on external circuitry is bled to GND when power
In the previous device, the receive buffer timeout used
is removed thus ensuring that external circuitry controlled
to flush remaining data from the receive buffer was fixed
by PWREN# resets reliably when power is restored.
at 16ms timeout. This timeout is now programmable
over USB in 1ms increments from 1ms to 255ms, thus
allowing the device to be better optimized for protocols
requiring faster response times from short data packets.
Page 2 of 12
• TXDEN Timing fix
FPGA as supplied by vendors such as Altera and Xilinx.
TXDEN timing has now been fixed to remove the external
The FPGA device would normally be un-configured ( i.e.
delay that was previously required for RS485 applications
have no defined function ) at power-up.
at high baud rates. TXDEN now works correctly during a
Application software on the PC could use Bit Bang Mode
transmit send-break condition.
to download configuration data to the FPGA which would
define it’s hardware function, then after the FPGA device
• Improved PreScaler Granularity
is configured the FT232BM can switch back into UART
The previous version of the Prescaler supported division
interface mode to allow the programmed FPGA device
by ( n + 0 ), ( n + 0.125 ), ( n + 0.25 ) and ( n + 0.5 )
to communicate with the PC over USB. This approach
where n is an integer between 2 and 16,384 ( 214 ). To
allows a customer to create a “generic” USB peripheral
these have been added ( n + 0.375 ), ( n + 0.625 ), ( n
whose hardware function can be defined under control of
+ 0.75 ) and ( n+ 0.875 ) which can be used to improve
the application software. The FPGA based hardware can
the accuracy of some baud rates and generate new baud
be easily upgraded or totally changed simply by changing
rates which were previously impossible ( especially with
the FPGA configuration data file. Application notes,
higher baud rates ).
software and development modules for this application
area will be available from FTDI and other 3rd party
• PreScaler Divide By 1 Fix
developers.
The previous device had a problem when the integer part
of the divisor was set to 1. In the 2nd generation device,
• USB 2.0 (full speed option)
setting the prescaler value to 1 gives a baud rate of 2
A new EEPROM based option allows the FT232BM to
million baud and setting it to zero gives a baud rate of 3
return a USB 2.0 device descriptor as opposed to USB
million baud. Non-integer division is not supported with
1.1. Note: The device would be a USB 2.0 Full Speed
divisor values of 0 and 1.
device (12Mb/s) as opposed to a USB 2.0 High Speed
device (480Mb/s).
• Bit Bang Mode
The 2nd generation device has a new option referred to
as “Bit Bang” mode. In Bit Bang mode, the eight UART
interface control lines can be switched between UART
interface mode and an 8-bit Parallel IO port. Data packets
can be sent to the device and they will be sequentially
sent to the interface at a rate controlled by the prescaler
setting. As well as allowing the device to be used standalone as a general purpose IO controller for example
controlling lights, relays and switches, some other
interesting possibilities exist. For instance, it may be
possible to connect the device to an SRAM configurable
Page 3 of 12
Table 1 - DLP-USB232M PINOUT DESCRIPTION
Pin#
Description
1
BOARD ID (Out) Identifies the board as either a DLP-USB245M or DLP-USB232M. High for DLPUSB232M and low for DLP-USB245M.
2
Ground
3
RESET# (In) Can be used by an external device to reset the FT245BM. If not required, this pin must
be tied to VCC.
4
RESETO# (Out) Output of the internal Reset Generator. Stays high impedance for ~ 2ms after
VCC > 3.5v and the internal clock starts up, then clamps it’s output to the 3.3v output of the internal
regulator. Taking RESET# low will also force RSTOUT# to go high impedance. RSTOUT# is NOT
affected by a USB Bus Reset.
5
Ground
6
3V3OUT (Out) Output from the integrated L.D.O. regulator. It’s primary purpose is to provide the
internal 3.3v supply to the USB transceiver cell and the RSTOUT# pin. A small amount of current
( RS232 converter designs.
9
RXLED# (O.C.) LED Drive - Pulses Low when Receiving Data via USB
Page 4 of 12
10
VCC-IO (In) 3.0 volt to +5.25 volt VCC to the UART interface pins 10..12, 14..16 and 18..25.
When interfacing with 3.3v external logic connect VCC-IO to the 3.3v supply of the external logic,
otherwise connect to VCC to drive out at 5v CMOS level. This pin must be connected to VCC from
the target electronics or EXTVCC.
11
EXTVCC – (In) Use for applying main power (4.4 to 5.25 Volts) to the module. Connect to
PORTVCC if module is to be powered by the USB port (typical configuration)
12
PORTVCC - (Out) Power from USB port. Connect to EXTVCC if module is to be powered by the
USB port (typical configuration). 500mA maximum current available to USB adapter and target
electronics if USB device is configured for high power.
13
TXLED# - (O.C.) LED Drive - Pulses Low when Transmitting Data via USB
14
PWRCTL (IN) Bus Powered – Tie Low / Self Powered – Tie High
15
POWEREN# (OUT) Goes Low after the device is configured via USB, then high during USB
suspend. Can be used to control power to external logic using a P-Channel Logic Level
MOSFET switch. Enable the Interface Pull-Down Option in EEPROM when using the PWREN# pin
in this way.
16
TXDEN (OUT) Enable Transmit Data for RS485
17
RI# (IN) Ring Indicator Control Input. When the Remote Wakeup option is enabled in the
EEPROM, taking RI# low can be used to resume the PC USB Host controller from suspend.
18
DCD# (IN)Data Carrier Detect Control Input
19
DSR# (IN)Data Set Ready Control Input / Handshake signal
DTR# (OUT)Data Terminal Ready Control Output / Handshake signal
21
CTS# (IN) Clear To Send Control Input / Handshake signal
22
RTS# (OUT) Request To Send Control Output / Handshake signal
23
RXD (IN) Receive Asynchronous Data Input
24
TXD (OUT)Transmit Asynchronous Data Output
Page 5 of 12
DEVICE CONFIGURATION EXAMPLES
USB Bus Powered and Self Powered Configuration
Figure 1 illustrates a typical USB bus powered configuration. A
Figure 1
USB Bus Powered device gets its power from the USB bus. Basic
rules for USB Bus power devices are as follows –
a) On plug-in, the device must draw no more than 100mA
b) On USB Suspend the device must draw no more than 500uA.
c) A Bus Powered High Power Device (one that draws more than
100mA) should use the SLEEP# pin to keep the current below
100mA on plug-in and 500uA on USB suspend.
d) A device that consumes more than 100mA can not be plugged
into a USB Bus Powered Hub
e) No device can draw more that 500mA from the USB Bus.
f) The power descriptor in the EEPROM should be programmed to a value of zero.
Figure 2
Figure 2 illustrates a typical USB self powered configuration. A USB Self Powered device gets its power from its own
Power Supply and does not draw current from the USB bus.
Basic rules for USB Self power devices are as follows –
a) A Self-Powered device should not force current down the USB bus when the USB Host or Hub Controller is
powered down.
b) A Self Powered Device can take as much current as it likes during normal operation and USB suspend as it has its
own Power Supply.
c) A Self Powered Device can be used with any USB Host and both Bus and Self Powered USB Hubs.
Page 6 of 12
Figure 3 shows how to configure the DLP-USB232M to interface with a 3.3v logic device in Bus-Powered
configuration. In this example, a LDO regulator provides 3.3 volts from the USB Bus to the target microcontroller and
the VCCIO line (pin 10) which in turn will cause the UART interface IO pins to drive out at 3.3v level.
Figure 3
Bus Powered Circuit with Power Control
USB Bus powered circuits need to be able to power down
Figure 4
in USB suspend mode in order to meet the
很抱歉,暂时无法提供与“DLP-USB232M-G2”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 250+238.79310250+30.89427
