SERIES 633/634/637/638
WATERPROOF HD D-SUB
Plug and Receptacle , Straight or Right Angle PCB Mount
High Density Waterproof D-Sub
.090"(2.29mm) Contact Spacing x .078"(1.98mm) Row Spacing
Plug and Receptacle in 15, 26 or 44 Contact Pin Sizes
Pin Contact Mating Design with P.C. Tail Termination in Right Angle,
Straight or Solder Cup Termination
Plug Shell Indents Provide Grounding and Additional Mating
Retention
Grounding Feature include Two Prong Boardlock for Exceptional
Retention to P.C. Board
Mounting Options for Panel Mount or Connector Mating include
Threaded Inserts or Threaded Standoffs
D-Shaped Connector Mating Outline provides Polarization
Degree of Protection: IP67 as per IEC60529
Specifications:
Insulator Material
PBT Thermoplastic with 30% Glass Filled,
UL 94V-0 Rated, Black color
Contact Material
Contact Plating
Shell Material
Epoxy Sealant
O-Ring
Current Rating
Contact Resistance
Insulation Resistance
Dielectric Voltage
Operating Temp.
Pins and Sockets: Copper Alloy
Gold Plating over Nickel underplating
Nickel Plated Steel
Epoxy
Silicone
3A Per Contact
10 Milliohms MAX
5000 Megohms MIN
1000V AC rms at Sea Level
-25°C To +85°C
Ordering Code:
633-W15-221-012
MOUNTING OPTION:
2 . . . . #4-40 UNC THREADED HOLE
SERIES:
PLUG, Right Angle, 9.7 [0.383], High Density Size . . . . 633
Receptacle, Right Angle, 9.7 [0.383], High Density Size . . . . 634
PLUG, Vertical PCB Mount, High Density Size . . . . 637
Receptacle, Vertical PCB Mount, High Density Size . . . . 638
NOTE:ALL CONNECTORS ARE SHIPPED WITH
#4-40 UNC HEXAGON SCREWS
(Packed Separately)
CROSS / REF:
EDAC CODE
WATERPROOF . . . . W
SHELL OPTIONS:
1 . . . . NICKEL PLATED
INSULATOR COLOR:
0 . . . . BLACK
NO. OF CONTACTS:
15 CONTACT PINS . . . . 15
26 CONTACT PINS . . . . 26
44 CONTACT PINS . . . . 44
CONTACT CODE:
21 . . . . PC TAIL FOR HIGH DENSITY TYPE D-SUB
22 . . . . SOLDER CUP TERMINATION
62 . . . . RIGHT ANGLE TAIL FOR HIGH DENSITY TYPE D-SUB
CONTACT PLATING
Gold Flash Plating over Nickel . . . . 2
15 µIN of Gold Plating over Nickel . . . . 3
30 µIN of Gold Plating over Nickel . . . . 6
www.edac.net
Rev.1
很抱歉,暂时无法提供与“637-W15-221-012”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+125.627181+16.27000
- 10+106.7820410+13.82936
- 48+95.5887948+12.37972
- 96+91.0280796+11.78906
- 144+88.46134144+11.45664
- 288+84.24207288+10.91021
- 528+80.71950528+10.45400
- 1008+77.124491008+9.98841
