ISSUE NUMBER
THIS IS A C.A.D. GENERATED DRAWING
DO NOT MAKE MANUAL REVISIONS TO MASTER.
39.50±0.25
ORIGINAL
1
25.00±0.25
16.30±0.25
21.10±0.25
2.84±0.25
2-#4-40UNC
Threaded
Standoffs
7.90±0.25
2.77
5.80 9.65
Materials and Finish
7.30
3.80
Insulator: PBT with Glass Fiber, UL94V-0, Black
Shell: Steel, Nickel Plated
Contact: Copper Alloy, with
2-Gold Flash Plating over Nickel
Watertight Frame: PBT with Glass Fiber, UL94V-0,
Black
O-Ring: Silicone
Epoxy Sealant: Epoxy
DEGREE OF PROTECTION: IP67 AS PER IEC60529
Electrical Characteristics
Current Rating: 5 Amperes
Dielectric Withstanding Voltage: 1000 V, for 1
Minute
Insulation Resistance: 5000 Megohm Min.
Contact Resistance: 10 Milliohms Max.
Working Temperature: -55C to +105C
Mounting Option
2- #4-40 UNC THREADED HOLE
Contact Code:
20- PC TAIL
THIS SERIES FULLY CONFORMS TO THE
EUROPEAN UNION DIRECTIVES 2002/95/EC
COMPLIANT AND 2002/96/EC FOR RoHS COMPLIANCY.
Standard Density Waterproof D-Sub Connector
RECEPTACLE
PART NUMBER: 628-W09-220-012
EDAC INC
TORONTO, ONTARIO
CANADA
YOUR CONNECTION TO QUALITY & SERVICE
THESE DRAWINGS AND SPECIFICATIONS
ARE THE PROPERTY OF EDAC INC.,AND
SHALL NOT BE REPRODUCED,OR COPIED
OR USED AS THE BASIS FOR THE
MANUFACTURE OR SALE OF APPARATUS
WITHOUT WRITTEN PERMISSION.
ACAD REFERENCE NO. 628-630W Assembly
DRAWN: R.STA.MONICA
DATE: June.4/13
CHECKED:
DATE:
SCALE:
NTS
SHEET 1 OF
DRAWING NUMBER
628-630W Assembly
1
ISSUE
1
很抱歉,暂时无法提供与“628-009-220-046”相匹配的价格&库存,您可以联系我们找货
