624-015-261-032
624-015-261-032
    弯插
624-015-261-032 数据手册
623/624 SERIES D-Sub Connectors: Right Angle, 0.197” (5.00mm) Footprint Features: • • • • • • • • • Two contact rows with 0.197”(5.00mm) footprint, right angle bend 0.109”(2.77mm) contact spacing X 0.112”(2.84mm) row spacing Plug and receptacle in 9, 15, or 25 contact sizes Pin and socket contact mating design with P.C. tail termination Metal shell provides EMI/RFI shielding, plug shell indents provide grounding and additional mating retention Board mounting features include two prong boardlock for exceptional retention to P.C. board Flange mounting options for panel mount or connector mating include through hole, threaded hole and threaded standoffs D-shaped connector mating outline provides polarization Design based on requirements of MIL-C-24038, EIA RS-232 and RS-449 Specifications: Insulator Material Thermoplastic Polyester, UL 94V-0, Chemical Resistant, Color: Black Contact Material Plug (Pins): Copper Alloy Receptacle (Socket): Copper Alloy Contact Plating Selective Gold (See Ordering Code) over Nickel for the Mating Area, Tin Plating for Tail Area Shell Material Nickel Plated Steel Current Rating 3 amps Contact Resistance 25 Milliohms maximum Insulation Resistance 5000 megaohms minimum Dielectric Withstanding Voltage 1000 V AC rms at Sea Level Operating Temperature -55°C To +85°C (upto +125°C for high temp) Insertion Force 16 oz (4.45 N) Maximum Per Contact Position Withdrawal Force 1 oz (0.28 N) Minimum Per Contact Position Ordering Code: 623-025-261-033 SERIES: 623: PLUG (PIN) 624: RECEPTACLE (SOCKET) NO. OF CONTACTS: 009 - 9 CONTACTS 015 - 15 CONTACTS 025 - 25 CONTACTS CONTACT FINISH CODE: 2 - GOLD FLASH PLATING 3 - 15 MICROINCHES OF GOLD PLATING 6 - 30 MICROINCHES OF GOLD PLATING CONTACT CODE: 61 - .197" FOOTPRINT CONTACT www.edac.net FLANGE MOUNTING OPTIONS: 1 - DIA .120"(DIA 3.05MM) THROUGH HOLE 2 - #4-40 THREADED HOLE 3 - #4-40 THREADED STANDOFF 5 - M3 THREADED HOLE BOARD MOUNTING FEATURE: 3 - TWO PRONG BOARDLOCKS INSULATOR MATERIAL CODE: 0 - STANDARD 5 - HIGH TEMP INSULATOR customerservice@edac.net 623/624 SERIES D-Sub Connectors: Right Angle, 0.197” (5.00mm) Footprint PLUG 623 SERIES 2.77±0.13 B 2.77±0.13 5.00 12.55±0.38 8.36±0.25 2.84 2.54 #4-40/M3 1.385 1.385 P.C.B EDGE 3.70 RECOMMENDED P.C.B LAYOUT (FOR PLUG AND RECEPTACLE) 5.00±0.25 6.40±0.25 2.54±0.25 6.00±0.25 14.80±0.38 8.80±0.25 5.00 Ø1.10 2-Ø3.20 5.00 A B C 3.18±0.38 RECEPTACLE 624 SERIES A B C 2.77±0.13 12.55±0.38 7.90±0.25 2.84 #4-40/M3 1.385 2.54±0.25 5.80±0.25 14.60±0.38 8.80±0.25 5.00 6.40±0.25 5.00±0.25 3.70 NUMBER OF CONTACTS www.edac.net A±0.38 Inch (mm) B±0.25 Inch (mm) C±0.25 PLUG Inch (mm) 3.18±0.38 C±0.13 RECEPTACLE Inch (mm) 9 1.213 (30.81) .984 (24.99) .666 (16.92) .643 (16.33) 15 1.543 (39.19) 1.312 (33.32) .994 (25.25) .971 (24.66) 25 2.088 (53.04) 1.852 (47.04) 1.534 (38.96) 1.511 (38.38) customerservice@edac.net
624-015-261-032
1. 物料型号:文档中提到的型号为623/624系列,其中623系列为插头(PIN),624系列为插座(SOCKET)。
2. 器件简介:这些连接器是直角D-Sub连接器,具有0.197英寸(5.00mm)的足迹,两排接触点,间距为0.109英寸(2.77mm)x 0.112英寸(2.84mm)。它们有9、15或25个接触点的大小,并具有P.C.尾端终止的插座和插头接触设计。
3. 引脚分配:文档中提供了插头和插座的推荐PCB布局图,包括接触点的位置和尺寸。
4. 参数特性:包括绝缘材料、接触材料、接触镀层、壳体材料、电流额定值、接触电阻、绝缘电阻、介电强度、操作温度范围、插入力和拔出力等。
5. 功能详解:金属壳体提供EMI/RFI屏蔽,插头壳体的凹槽提供接地和额外的配对保持力。板载安装特性包括两个叉板锁,为P.C.板提供卓越的保持力。
6. 应用信息:设计基于MIL-C-24038、EIA RS-232和RS-449的要求。
7. 封装信息:提供了法兰安装选项,包括通孔、螺纹孔和螺纹支架。
624-015-261-032 价格&库存
很抱歉,暂时无法提供与“624-015-261-032”相匹配的价格&库存,您可以联系我们找货
  • 250+30.56510250+3.89290
  • 1000+28.850801000+3.67450
  • 2500+28.081102500+3.57650
