09676507658
09676507658
    HARTING(浩亭)
09676507658 数据手册
D SUB IP 67 MA ANG_PCB_50P_S4_METAL FRAM Part number 09 67 650 7658 Description D SUB IP 67 MA ANG_PCB_50P_S4_METAL FRAM Identification Category Connector Series D-Sub Identification IP67 Element Male connector Specification With rear metal mounting plate Description of the contact Turned Angled Termination method Wave soldering termination Locking type Fixing flange with thread 4-40 UNC Version Number of contacts 50 Additional contacts With grounding pin Performance level S4 PCB fixing With board locks Technical characteristics Rated current 5A Clearance distance ≥ 1 mm Creepage distance ≥ 1 mm Contact resistance ≤ 35 mΩ Limiting temperature -25 ... +70 °C Insertion force ≤ 170 N Withdrawal force ≥ 10 N Mating cycles ≥ 500 Degree of protection acc. to IEC 60529 IP67 Test voltage Ur.m.s. 1.2 kV Flammability acc. to UL 94 V-0 Material properties Material (insert) Brass, tin plated Thermoplastic resin, glass-fibre filled Material (contacts) Copper alloy Material (seal) Silicone Colour (seal) Red Net weight 56.28 g
09676507658 价格&库存
很抱歉,暂时无法提供与“09676507658”相匹配的价格&库存,您可以联系我们找货
    库存:93
