977-025-020R121
977-025-020R121
    NORCOMP
    977-025-020R121
977-025-020R121 数据手册
DESCRIPTION: 977 SERIES D-SUB BACKSHELL - 25 POSITION BACKSHELL KIT INCLUDES: METALIZED PLASTIC: (2) BACKSHELL HALVES (2) HOUSING SCREWS (2) HOUSING NUTS (2) 4-40 MOUNTING SCREWS (2) SADDLE WASHERS (2) STRAIN RELIEF CLAMPS (2) STRAIN RELIEF SCREWS MATERIAL: METALIZED PLATING: OPERATING TEMP: ABS HIGH TEMPERATURE PLASTIC UL94HB NICKEL OVER COPPER 0°C TO 85°C PLASTIC: MATERIAL: OPERATING TEMP: ABS HIGH TEMPERATURE PLASTIC UL94HB 0°C TO 85°C **PLEASE NOTE FOR METALIZED VERSION THIS GEOMETRY WILL BE A CIRCLE, NOT A HEX 977-025-0Y0 R YY 1 SERIES POSITIONS 025 MATERIAL 010 = PLASTIC 020 = METALIZED PLASTIC RoHS COMPLIANT COLOR 03 = GREY (ONLY USE WITH 010 OPTION ABOVE) 12 = METALIZED (ONLY USE WITH 020 OPTION ABOVE) PUT-UP 1 = KIT RoHS COMPLIANT N C THESE DRAWINGS AND SPECIFICATIONS ARE THE PROPERTY OF NorComp AND SHALL NOT BE REPRODUCED, COPIED OR USED AS THE BASIS FOR THE MANUFACTURE OR SALE OF APPARATUS WITHOUT WRITTEN PERMISSION. UNITS = mm DRAWN: J. KADEL DATE: 08/22/2019 DO NOT SCALE FROM DRAWING NorComp SCALE: SHEET NTS DWG NO. REV OF 1 1 977-025-0Y0RYY1 3
977-025-020R121 价格&库存
很抱歉,暂时无法提供与“977-025-020R121”相匹配的价格&库存,您可以联系我们找货
977-025-020R121
  • 1+20.796611+2.69389
  • 10+17.6643210+2.28815
  • 25+16.5562325+2.14461
  • 50+15.7634050+2.04192
  • 100+15.00993100+1.94431
  • 250+14.06981250+1.82254
  • 500+13.39794500+1.73551
  • 1000+12.758621000+1.65269
  • 2500+11.960272500+1.54928
库存:11083
