FFS CONNECTOR
1.25mm
Emboss Tape
Connectors for FFC
pitch
Features ––––––––––––––––––––––––
• Surface mountable (SMT)
Because of its small pitch and its ability to be surface mounted,
this connector meets the demand for high-density packaging.
• Double-leaf contact mating enhances
reliability through redundancy
The contact is made of phosphor bronze that maintains its
spring force in adverse environmental conditions. FFC leads can
be inserted with little force, yet the contact pressure is high once
they are inserted.
• Low profile design
This connector is very small with a mounting height of only
2.8mm.
• Simple snap-in action
The FFS series connectors are designed
for surface mounting (SMT) and to meet
They are miniature connectors with a
height of only 2.8mm. Their high contact
pressure eliminates fretting corrosion and
ensures secure connections. Low insertion
force make connection easy.
The FFC is securely connected by simply inserting its leads
into the connector.
• Embossed tape for automatic mounting
The FFS connector is supplied packaged in embossed tape for
automatic mounting.
• Solder tabs
This connector also features reinforcing solder tabs to prevent
lifting of the connector during mating and unmating.
Specifications –––––––––––––––––––
• Current rating: 0.5A AC, DC
• Voltage rating: 50V AC, DC
• Temperature range: -25˚C to +85˚C
(including temperature rise in applying
electrical current)
• Contact resistance: Initial value/20m Ω max.
After environmental testing/30m Ω max.
• Insulation resistance: 800M Ω min.
• Withstanding voltage: 500V AC/minute
• Applicable FFC: Conductor pitch/1.25mm
Conductor width/0.8mm
Mating part thickness/0.3±0.05mm
FFC to be actually used should be checked for applicability.
* Compliant with RoHS.
* Refer to "General Instruction and Notice when using
Terminals and Connectors" at the end of this catalog.
* Contact JST for details.
Standards ––––––––––––––––––––––
Recognized E60389
Certified LR20812
1
FFS
CONNECTOR
Connector –––––––––––––––––––––––––––––––––––––––––––––––––––––––––––––––
(6.5)
B
A
(1.9)
1.2
5.3
2.8
1.25
Dimensions (mm)
B
Q'ty /
reel
3.75
7.55
1,000
5.00
8.80
1,000
06FFS-SP-TF
6.25
10.05
1,000
8
08FFS-SP-TF
8.75
12.55
1,000
15
15FFS-SP-TF
17.50
21.30
1,000
21
21FFS-SP-TF
25.00
28.80
1,000
26
26FFS-SP-TF
31.25
35.05
2,000
Circuits
Model No.
4
04FFS-SP-TF
5
05FFS-SP-TF
6
A
Material and Finish
Contact: Phosphor bronze, copper-undercoated, tin-plated (reflow treatment)
Housing: PPS, UL94V-0
Solder tab: Brass, copper-undercoated, tin-plated (reflow treatment)
RoHS compliance This product displays (LF)(SN) on a label.
Note: The products listed above are supplied on embossed tape.
Lead section dimensions of FFC ––––––––––––––––––––––––––––––––––––––––––––
1.25x(N+1)±0.2
1.25±0.2
1.25x(N-1)±0.15
1.25±0.2
0.8±0.1
0.3±0.05
Conductor
10.0
3.3min.
1.25±0.1
Reinforcing layer
Base layer
Film cover layer
Note: N --- Number of circuits
PC board layout (viewed from component side) and Assembly layout ––––––––––––––––––
1.25±0.05
1.2
2.8
(6.5)
5.3
4.35±0.1
4.2±0.1
2.5±0.1
0.7min.
FFC
2.7±0.1
Note:
1. Tolerances are non-cumulative: ±0.05mm for all centers.
2. The dimensions above should serve as a guideline.
2
04FFS-SP-TF(LF)(SN) 价格&库存
很抱歉,暂时无法提供与“04FFS-SP-TF(LF)(SN)”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1000+3.060111000+0.39670
- 2000+2.892142000+0.37493
- 3000+2.801393000+0.36316
- 4000+2.674024000+0.34665
- 5000+2.589635000+0.33571
- 10000+2.4869410000+0.32240
- 国内价格 香港价格
- 1+4.149151+0.53788
- 10+3.0770010+0.39889
- 50+2.5278550+0.32770
- 100+2.16175100+0.28024
- 500+2.08329500+0.27007
- 1000+2.030991000+0.26329
- 2000+2.004842000+0.25990
- 国内价格 香港价格
- 1+7.797701+1.01090
- 10+6.7316010+0.87270
- 25+6.1687025+0.79970
- 100+5.55780100+0.72050
- 250+5.07870250+0.65840
- 1000+3.581401000+0.46430
- 10000+3.5215010000+0.45660
