HDMI & USB CONNECTORS
690 SERIES
FEATURES:
SPECIFICATIONS:
Insulator Material: UL 94V-0 Thermoplastic, PA9T or LCP
Contact Material: Phosphor Bronze or Copper Alloy
Contact Plating: Gold Plating over Nickel Plating on mating area
and Tin Plating on tails
Shell Material: Brass with Tin Plating
Durability: 1500 Cycles Minimum
Mating Force: 35N Maximum (For Standard USB)
Unmating Force: 10N Minimum (For Standard USB)
EXAMPLE PART NUMBER:
690-004-220-013
Series
22
23
24
60
61
95
96
97
98
99
Total Number of Contacts
Contact Plating Code
Contact Code
Packaging
Material
Type Indicator
Total Number of Contacts:
Single Port position (Type A, Type B, Miniature USB-A)
Single Port position (Miniature USB-B, Miniature USB-AB)
Single Port (IEEE 1394)
Single Port (E-SATA)
Dual Ports (Type A)
Single Port - Standard USB 3.0 compliance (Type A, Type B)
Single Port -Micro USB 3.0 compliance (Type B)
Triple Ports (Type A)
Quadruple Ports (Type A)
Dual Ports -USB 3.0 compliance (Type A)
Single Port (HDMI)
Single Port (Mini DisplayPort)
Dual Ports Combo - (Type A and HDMI)
Single Port position (Type C 3.1)
004
005
006
007
008
009
010
012
016
018
019
020
023
024
Contact Plating Code:
Gold Flash Plating
15 μin Gold
30 μin Gold
Packaging:
T= tape & Reel, B= Tube, C= Tray, D= Box
www.edac.net
Up to 480 Mbps communication speed for standard USB 2.0
Up to 5 Gbps communication speed for standard USB 3.0
Up to 10 Gbps communication speed for USB 3.1 Type C
Readily available in:
Single Port position (Type A, B , Miniature USB-A)
Dual Ports (Type A)
Single Port (HDMI)
Dual Ports (HDMI)
Industry Standard Plug and play technology Hot Pluggable
Compatible with synchronous and asynchronous data
transfer
Data and power combined in one small package
RoHS Compliant
Contact Code:
2
3
6
Right Angle PCB (.390" Footprint)
Right Angle PCB (.405" Footprint)
Right Angle PCB (.147" Footprint)
Right Angle PCB (.114" Footprint)
Vertical with Solder Pad, Thru Hole Type
Vertical PCB
Right Angle PCB (Upright), for Type A only
Right Angle, Surface Mount with Metal Mounting Angles
Right Angle, Surface Mount with Metal Post
Right Angle, Surface Mount with Plastic Post
R/Angle, S/Mount W/Metal Post(4) Thru hole Grounding tab
R/Angle, S/Mount W/Metal Post(2) Thru hole Grounding tab
Material:
2
3
4
Thermoplastic Black, UL 94V-0
PA9T Black
LCP White
Thermoplastic Black, Plastic Tray Packaging
LCP Black
Type Indicator:
Standard Type A
Standard Type B
Standard Type C (3.1)
Miniature USB Type B
Miniature USB Type AB
Miniature Display Port
E-SATA 7P Male
Micro USB-AB
13
23
24
43
53
63
73
83
ORDERING CODE NOTES:
All part numbers deriving from this ordering guide may not be readily available
or could be available upon request. Please contact EDAC's customer service for
more inquiries.
Page 1
很抱歉,暂时无法提供与“690-024-234-031”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+28.815391+3.73878
- 10+24.4632510+3.17409
- 25+22.9265725+2.97471
- 50+21.8302250+2.83246
- 100+20.78683100+2.69708
- 250+19.48475250+2.52813
- 500+18.55485500+2.40748
- 国内价格 香港价格
- 1250+14.985521250+1.94436
