690-024-334-031
690-024-334-031
    SMD
    USB连接器 Type-C 24P 沉板 端口数:1 额定电流:1.25A,5A 工作温度:-40℃~+85℃
690-024-334-031 数据手册
HDMI & USB CONNECTORS 690 SERIES FEATURES: • • • • SPECIFICATIONS: Insulator Material: UL 94V-0 Thermoplastic, PA9T or LCP Contact Material: Phosphor Bronze or Copper Alloy Contact Plating: Gold Plating over Nickel Plating on mating area and Tin Plating on tails Shell Material: Brass with Tin Plating Durability: 1500 Cycles Minimum Mating Force: 35N Maximum (For Standard USB) Unmating Force: 10N Minimum (For Standard USB) EXAMPLE PART NUMBER: • • • • 690-004-220-013 Series 20 21 22 23 24 60 61 95 96 97 98 99 Total Number of Contacts Contact Plating Code Contact Code Packaging Material Type Indicator Total Number of Contacts: Single Port position (Type A, Type B, Miniature USB-A) Single Port position (Miniature USB-B, Miniature USB-AB) Single Port (IEEE 1394) Single Port (E-SATA) Dual Ports (Type A) Single Port - Standard USB 3.0 compliance (Type A, Type B) Single Port -Micro USB 3.0 compliance (Type B) Triple Ports (Type A) Quadruple Ports (Type A) Dual Ports -USB 3.0 compliance (Type A) Single Port (HDMI) Single Port (Mini DisplayPort) Dual Ports Combo - (Type A and HDMI) Single Port position (Type C 3.1) 004 005 006 007 008 009 010 012 016 018 019 020 023 024 Contact Plating Code: Gold Flash Plating 15 μin Gold 30 μin Gold Packaging: T= tape & Reel, B= Tube, C= Tray, D= Box www.edac.net Up to 480 Mbps communication speed for standard USB 2.0 Up to 5 Gbps communication speed for standard USB 3.0 Up to 10 Gbps communication speed for USB 3.1 Type C Readily available in: Single Port position (Type C 3.1) Single Port position (Type A, B , Miniature USB-A) Single Port position (Miniature USB-B, Miniature USB-AB) Single Port (IEEE 1394) Single Port (E-SATA) Dual Ports (Type A) Single Port - Standard USB 3.0 compliance (Type A, Type B) Single Port -Micro USB 3.0 compliance (Type B) Triple Ports (Type A) Quadruple Ports (Type A) Dual Ports -USB 3.0 compliance (Type A) Single Port (HDMI) Single Port (Mini DisplayPort) Dual Ports Combo - (Type A and HDMI) Dual Ports (HDMI) Industry Standard Plug and play technology Hot Pluggable Compatible with synchronous and asynchronous data transfer Data and power combined in one small package RoHS Compliant Contact Code: 2 3 6 Right Angle PCB (.390" Footprint) Right Angle PCB (.405" Footprint) Right Angle PCB (.147" Footprint) Right Angle PCB (.114" Footprint) Vertical with Solder Pad, Thru Hole Type Vertical PCB Right Angle PCB (Upright), for Type A only Right Angle, Surface Mount with Metal Mounting Angles Right Angle, Surface Mount with Metal Post Right Angle, Surface Mount with Plastic Post R/Angle, S/Mount W/Metal Post(4) Thru hole Grounding tab R/Angle, S/Mount W/Metal Post(2) Thru hole Grounding tab Material: 0 1 2 3 4 Thermoplastic Black, UL 94V-0 PA9T Black LCP White Thermoplastic Black, Plastic Tray Packaging LCP Black Type Indicator: Standard Type A Standard Type B Standard Type C (3.1) Miniature USB Type B Miniature USB Type AB Miniature Display Port E-SATA 7P Male Micro USB-AB 13 23 24 43 53 63 73 83 ORDERING CODE NOTES: All part numbers deriving from this ordering guide may not be readily available or could be available upon request. Please contact EDAC's customer service for more inquiries. Page 1
690-024-334-031 价格&库存
很抱歉,暂时无法提供与“690-024-334-031”相匹配的价格&库存,您可以联系我们找货
