SERIES 690W
WATERPROOF USB & HDMI
Plug and Socket , USB and HDMI Connectors
E-SEAL Waterproof Connectors: Standard USB TypeA, Micro
USB, Mini USB Type B and HDMI Type A
Compatible with all Windows versions
1.2Mbps or 480Mbps communication speed
Complies with USB1.0 (USB2.0 upon request)
Compatible with asynchronous and isochronous data transfer
methods
Silicone rubber seals
Bayonet locking system for safe mating under severe vibration
or shock conditions
Degree of Protection: IP67 as per IEC60529
Specifications:
Insulator Material
Thermoplastic, UL 94V-0 Rated, Black color
Contact Material
Contact Plating
Shell Material
Rubber Seals
O-Ring
Signal Current Rating
Contact Resistance
Insulation Resistance
Operating Temp.
Plugs and Sockets: Copper Alloy
Gold Plating over Nickel underplating
Nickel Plated Steel
Silicone
Silicone
1A Per Contact
50 Milliohms MAX
100 Megohms MIN
-25°C To +85°C
M00-383-001 Cap is used for:
1. 690-W04-260-014
2. 690-W19-260-012
M00-383-002 Cap is used for:
1. 690-W05-260-044
Ordering Code:
690-W04-260-012
SERIES:
USB, HDMI . . . . 690
CROSS / REF:
EDAC CODE
WATERPROOF . . . . W
NO. OF CONTACTS:
(STANDARD USB-A) 4 CONTACT PINS . . . . 04
(MICRO OR MINI USB) 5 CONTACT PINS . . . . 05
(HDMI) 19 CONTACT PINS . . . . 19
TYPE:
11 . . . . HDMI TYPE A, MALE
12 . . . . HDMI TYPE A, FEMALE
13 . . . . USB TYPE A, MALE
14 . . . . USB TYPE A, FEMALE
43 . . . . MINI USB TYPE B, MALE
44 . . . . MINI USB TYPE B, FEMALE
83 . . . . MICRO USB, FEMALE
INSULATOR COLOR:
0 . . . . BLACK
CONTACT PLATING
Gold Flash Plating over Nickel . . . . 2
15 µIN of Gold Plating over Nickel . . . . 3
30 µIN of Gold Plating over Nickel . . . . 6
CONTACT CODE:
60 . . . . STRAIGHT TYPE
90 . . . . SMT TYPE (MICRO USB ONLY)
www.edac.net
Page 1
很抱歉,暂时无法提供与“690-W19-260-012”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+159.46200
- 200+63.63360
- 500+61.50600
- 1000+60.45840
- 国内价格 香港价格
- 1+125.996311+16.30891
