Han® ES Press
Size 6 B - 24 B
Features
Description
• E
asy bridging functionality of contacts by means
of plug-in jumpers directly on the connector
• Fast realisation of potential multiplication as well
as star and delta bridges
• To assemble the conductor close the blue press
button with light finger pressure
• R
apid termination technology without tools for a
time saving assembly and for optimal process reliability
• Conductors can be connected with and without
ferrules
• M
ating compatible to connectors of the Han E®,
Han® ES and Han® ESS product families
• Integrated opening for measuring probe
• Audible and tactile snap-in of press buttons and
plug-in jumpers
• Z
ero Insertion Force (ZIF) of conductor into
contact
• Jumpers for potential multiplication within the connector
• Jumpers to bridge star and delta circuits within the
connector
• S
uitable for hoods and housings of the Han® B,
Han® M, Han® EMV, Han® HPR, Han® Easy Hood
and Han-Drive® series
• S
uitable for control cabinets in combination
with Han-Snap® series
Hint:
When using plug-in jumpers within Han® ES Press
hoods of high construction must be used.
Removal of conductor
To open the blue press button use a standard
screw driver (blade 2.5 mm) with a light lever
movement.
HARTING Electric GmbH & Co. KG | Wilhelm-Harting-Straße 1 | D-32339 Espelkamp
Tel.: +49 5772 47-97100 | Fax: +49 5772 47-495
www.HARTING.com | electric@HARTING.com
2016-02-24
Han® Datasheet 0975
Han® ES Press
Size 6 B - 24 B
Current carrying capacity
Specifications
The current carrying capacity of the connectors is limited by the
thermal load capability of the contact element material including
the connections and the insulating parts. The derating curve
is therefore valid for currents which flow constantly (non-intermittent) through each contact element of the connector evenly,
without exceeding the allowed maximum temperature.
Measuring and testing techniques according to
DIN EN 60 512-5-2.
DIN EN 60 664-1
DIN EN 61 984
Inserts
Contacts
6, 10, 16, 24
Electrical data acc. to
DIN EN 61 984
Rated current
Rated voltage
Rated impulse voltage
Pollution degree
16 A
500 V
6 kV
3
Insulation resistance
≥ 1010 Ω
Material
polycarbonate
Limiting temperatures
-40 °C ... +125 °C
Flammability acc. to UL 94
V0
Mating cycles
≥ 500
Operating current (A)
Technical characteristics
Contacts
Material power contacts
copper alloy
Surface
silver plated
3 µm Ag
Contact resistance
≤ 3 mΩ
Cage clamp termination 0.14 ... 2.5 mm²
Max. insulation diameter
5.0 mm
Stripping length
9 ... 11 mm
Ambient temperature (°C)
➀ Han® 6 ES Press insert 1.5 mm²
➁ Han® 10 ES Press insert 1.5 mm²
➂ Han® 16 ES Press insert 1.5 mm²
➃ Han® 24 ES Press insert 1.5 mm²
Contacts
2, 3, 5, 8, 12
Colour jumpers
RAL 3018 (red)
RAL 5012 (blue)
RAL 5004 (black)
DIN EN 61 984
Rated current
Rated voltage
Pollution degree
16 A
500 V
6 kV
3
-40 °C ... +125 °C
V0
Mating cycles
≥5
Material insulation
polyamide
≥ 1010 Ω
Material jumpers
copper alloy
Surface jumpers
- tin plated
3 μm Sn
Contact resistance
≤ 1,0 mΩ
Plug-in jumpers
➀ Han® 6 ES Press insert 2.5 mm²
➁ Han® 10 ES Press insert 2.5 mm²
➂ Han® 16 ES Press insert 2.5 mm²
➃ Han® 24 ES Press insert 2.5 mm²
Han® ES Press
Size 6 B
Number of contacts
6+
500 V 16 A
Identification
Part number
Male insert (M) Female insert (F)
Han® 6 ES Press
09 33 006 2648
Drawing
Dimensions in mm
09 33 006 2748
1) Distance for contacts max. 21 mm
Contact arrangement: view from termination side
Panel cut out
Han® ES Press
Size 10 B
Number of contacts
10 +
500 V 16 A
Identification
Part number
Han® 10 ES Press
09 33 010 2648
Drawing
Dimensions in mm
09 33 010 2748
Panel cut out
Han® ES Press
Size 16 B
Number of contacts
16 +
500 V 16 A
Identification
Part number
Han® 16 ES Press
09 33 016 2648
Drawing
Dimensions in mm
09 33 016 2748
Panel cut out
Han® ES Press
Size 24 B
Number of contacts
24 +
500 V 16 A
Identification
Part number
Han® 24 ES Press
09 33 024 2648
Drawing
Dimensions in mm
09 33 024 2748
Panel cut out
Han® ES Press
Size 6 B - 24 B
Identification
Part number
Drawing
Han® ES Press plug-in jumper
plug-in jumper 2 x 1 red
09 33 000 9820
plug-in jumper 2 x 1 blue
09 33 000 9821
plug-in jumper 2 x 1 black
09 33 000 9822
plug-in jumper 1 x 3 red
09 33 000 9831
plug-in jumper 1 x 3 blue
09 33 000 9842
plug-in jumper 1 x 3 black
09 33 000 9853
plug-in jumper 1 x 5 red
09 33 000 9833
plug-in jumper 1 x 5 blue
09 33 000 9844
plug-in jumper 1 x 5 black
09 33 000 9855
plug-in jumper 1 x 8 red
09 33 000 9836
plug-in jumper 1 x 8 blue
09 33 000 9847
plug-in jumper 1 x 8 black
09 33 000 9858
plug-in jumper 1 x 12 red
09 33 000 9840
plug-in jumper 1 x 12 blue
09 33 000 9851
plug-in jumper 1 x 12 black
09 33 000 9862
Dimensions in mm
很抱歉,暂时无法提供与“09330009821”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 5+33.490345+4.31660
- 10+31.9122610+4.11320
- 25+29.4574725+3.79680
- 50+27.9670650+3.60470
- 75+27.0026875+3.48040
- 100+26.47665100+3.41260
- 125+26.12597125+3.36740
- 150+25.68761150+3.31090
- 250+24.81090250+3.19790
- 500+23.93419500+3.08490
- 国内价格 香港价格
- 1+42.087501+5.42470
- 10+35.7450410+4.60721
- 25+33.5086925+4.31897
- 50+31.9071350+4.11254
- 100+30.38312100+3.91611
- 250+28.48051250+3.67088
- 500+27.12127500+3.49569
- 1000+25.827741000+3.32896
- 2500+24.212442500+3.12077
