09330009820
09330009820
    HARTING(浩亭)
    JUMPERACROSS2X1RED16A
09330009820 数据手册
Han® ES Press Size 6 B - 24 B Features Description • E  asy bridging functionality of contacts by means of plug-in jumpers directly on the connector • Fast realisation of potential multiplication as well as star and delta bridges • To assemble the conductor close the blue press button with light finger pressure • R  apid termination technology without tools for a time saving assembly and for optimal process reliability • Conductors can be connected with and without ferrules • M  ating compatible to connectors of the Han E®, Han® ES and Han® ESS product families • Integrated opening for measuring probe • Audible and tactile snap-in of press buttons and plug-in jumpers • Z  ero Insertion Force (ZIF) of conductor into contact • Jumpers for potential multiplication within the connector • Jumpers to bridge star and delta circuits within the connector • S  uitable for hoods and housings of the Han® B, Han® M, Han® EMV, Han® HPR, Han® Easy Hood and Han-Drive® series • S  uitable for control cabinets in combination with Han-Snap® series Hint: When using plug-in jumpers within Han® ES Press hoods of high construction must be used. Removal of conductor To open the blue press button use a standard screw driver (blade 2.5 mm) with a light lever movement. HARTING Electric GmbH & Co. KG | Wilhelm-Harting-Straße 1 | D-32339 Espelkamp Tel.: +49 5772 47-97100 | Fax: +49 5772 47-495 www.HARTING.com | electric@HARTING.com 2016-02-24 Han® Datasheet 0975 Han® ES Press Size 6 B - 24 B Current carrying capacity Specifications The current carrying capacity of the connectors is limited by the thermal load capability of the contact element material including the connections and the insulating parts. The derating curve is therefore valid for currents which flow constantly (non-intermittent) through each contact element of the connector evenly, without exceeding the allowed maximum temperature. Measuring and testing techniques according to DIN EN 60 512-5-2. DIN EN 60 664-1 DIN EN 61 984 Inserts Contacts 6, 10, 16, 24 Electrical data acc. to DIN EN 61 984 Rated current Rated voltage Rated impulse voltage Pollution degree 16 A 500 V 6 kV 3 Insulation resistance ≥ 1010 Ω Material polycarbonate Limiting temperatures -40 °C ... +125 °C Flammability acc. to UL 94 V0 Mating cycles ≥ 500 Operating current (A) Technical characteristics Contacts Material power contacts copper alloy Surface silver plated 3 µm Ag Contact resistance ≤ 3 mΩ Cage clamp termination 0.14 ... 2.5 mm² Max. insulation diameter 5.0 mm Stripping length 9 ... 11 mm Ambient temperature (°C) ➀ Han® 6 ES Press insert 1.5 mm² ➁ Han® 10 ES Press insert 1.5 mm² ➂ Han® 16 ES Press insert 1.5 mm² ➃ Han® 24 ES Press insert 1.5 mm² Contacts 2, 3, 5, 8, 12 Colour jumpers RAL 3018 (red) RAL 5012 (blue) RAL 5004 (black) Electrical data acc. to DIN EN 61 984 Rated current Rated voltage Rated impulse voltage Pollution degree 16 A 500 V 6 kV 3 Limiting temperatures -40 °C ... +125 °C Flammability acc. to UL 94 V0 Mating cycles ≥5 Material insulation polyamide Insulation resistance ≥ 1010 Ω Material jumpers copper alloy Surface jumpers - tin plated 3 μm Sn Contact resistance ≤ 1,0 mΩ Operating current (A) Plug-in jumpers Ambient temperature (°C) ➀ Han® 6 ES Press insert 2.5 mm² ➁ Han® 10 ES Press insert 2.5 mm² ➂ Han® 16 ES Press insert 2.5 mm² ➃ Han® 24 ES Press insert 2.5 mm² Han® ES Press Size 6 B Number of contacts 6+ 500 V 16 A Identification Part number Male insert (M) Female insert (F) Han® 6 ES Press 09 33 006 2648 Drawing Dimensions in mm 09 33 006 2748 1) Distance for contacts max. 21 mm Contact arrangement: view from termination side Panel cut out Han® ES Press Size 10 B Number of contacts 10 + 500 V 16 A Identification Part number Male insert (M) Female insert (F) Han® 10 ES Press 09 33 010 2648 Drawing Dimensions in mm 09 33 010 2748 1) Distance for contacts max. 21 mm Contact arrangement: view from termination side Panel cut out Han® ES Press Size 16 B Number of contacts 16 + 500 V 16 A Identification Part number Male insert (M) Female insert (F) Han® 16 ES Press 09 33 016 2648 Drawing Dimensions in mm 09 33 016 2748 1) Distance for contacts max. 21 mm Contact arrangement: view from termination side Panel cut out Han® ES Press Size 24 B Number of contacts 24 + 500 V 16 A Identification Part number Male insert (M) Female insert (F) Han® 24 ES Press 09 33 024 2648 Drawing Dimensions in mm 09 33 024 2748 1) Distance for contacts max. 21 mm Contact arrangement: view from termination side Panel cut out Han® ES Press Size 6 B - 24 B Identification Part number Drawing Han® ES Press plug-in jumper plug-in jumper 2 x 1 red 09 33 000 9820 plug-in jumper 2 x 1 blue 09 33 000 9821 plug-in jumper 2 x 1 black 09 33 000 9822 plug-in jumper 1 x 3 red 09 33 000 9831 plug-in jumper 1 x 3 blue 09 33 000 9842 plug-in jumper 1 x 3 black 09 33 000 9853 plug-in jumper 1 x 5 red 09 33 000 9833 plug-in jumper 1 x 5 blue 09 33 000 9844 plug-in jumper 1 x 5 black 09 33 000 9855 plug-in jumper 1 x 8 red 09 33 000 9836 plug-in jumper 1 x 8 blue 09 33 000 9847 plug-in jumper 1 x 8 black 09 33 000 9858 plug-in jumper 1 x 12 red 09 33 000 9840 plug-in jumper 1 x 12 blue 09 33 000 9851 plug-in jumper 1 x 12 black 09 33 000 9862 Dimensions in mm
09330009820 价格&库存
很抱歉,暂时无法提供与“09330009820”相匹配的价格&库存,您可以联系我们找货
