395-020-523-201
395-020-523-201
    CARD EDGE 20POS DL .100X.200 BLK
395-020-523-201 数据手册
345/395 SERIES Card Edge Connector 0.100" (2.54mm) Pitch • FEATURES: • • • • • • • • • • .100" (2.54mm) Contact Spacing x .200" (5.08mm) Row Spacing Accepts .062" (1.57mm) Nominal Thickness P.C. Board High Profile Insulator Body, .600" (15.24mm) Contact Termination Options include P.C. Tail, Wire Wrap, 90 Degree Bends and Extender Board Bends Single or Dual Row Configurations Large Variety of Mounting Options, Flush or Offset Lugs Accepts between Contact and In-Contact Polarizing Keys Pre-assembled Card Guides are available Automatic Wire Wrap Positioning Holes RoHS Compliant & UL Certified Specifications: Insulator Material Contact Material Contact Plating Current Rating Contact Resistance Dielectric Withstand Voltage Insulation Resistance Operating Temperature Insertion Force Withdrawal Force UL 94V-0 Thermoplastic Polyester Copper Alloy Gold Plating on mating area and Tin Plating on tails with Nickel underplating all over 3 Amperes 10 milliohms maximum 1200 VAC rms at sea level between adjacent contacts 5000 Megaohms minimum -40°C to +105°C 16oz (4.45N) maximum per contact pair when tested with .070" (1.78mm) thick gauge 1oz (0.28N) minimum per contact pair when tested with .054" (1.37mm) thick gauge Series: 345-050-520-202 Example Part Number: Insulator Color 345 395 Series Thermoplastic Polyester, Green Thermoplastic Polyester, Black Total Number of Contacts Contact Code Contact Code Contact Rows and Insulator Style 500 520 521 523 524 525 540 541 542 544 555 556 558 559 560 Mounting Options Total Number of Contacts: Contact Rows 005, 006, . . . . 072 010, 012, . . . . 144 Single Row Dual Row Contact Rows & Insulator Style Description 1 2 4 5 6 8 Single Row, Flush Mounting Lugs Dual Row, Flush Mounting Lugs Single Row, .110 (2.79) Offset Lugs Dual Row, .110 (2.79) Offset Lugs Single Row, .170 (4.32) Offset Lugs Dual Row, .170 (4.32) Offset Lugs Mounting Options: 01 02 03 04 07 08 12 58 78 88 Description No Mounting Lug Ø.128" (Ø3.25mm) Mounting Holes Ø.116" (Ø2.95mm) I.D. Floating Eyelets Ø.156" (Ø3.96mm) Mounting Holes M3-0.5 Metric Threaded Inserts #4-40 Unified Threaded Inserts Ø.128" (Ø3.25mm) Side Mounting Holes .468" (11.89mm) Offset Card Guides In-Line Card Guides 2.750" (69.85mm) Long In-Line Card Guides 1.250" (31.75mm) Long Description & Tail Size Wire Hole .050 x .025 (1.27 x 0.64) P.C. Tail .030 x .018 (0.76 x 0.46) P.C. Tail .025 Square (0.64 Square) P.C. Tail .025 Square (0.64 Square) P.C. Tail .018 Square (0.46 Square) P.C. Tail .018 Square (0.46 Square) Wire Wrap .025 Square (0.64 Square) Wire Wrap .025 Square (0.64 Square) Wire Wrap .025 Square (0.64 Square) Wire Wrap .050 x .025 (1.27 x 0.64) EXTENDER BOARD BEND (CODE 500 CONTACTS) EXTENDER BOARD BEND (CODE 520 CONTACTS) 90 DEGREE BEND (CODE 541 CONTACTS) 90 DEGREE BEND (CODE 541 CONTACTS) EXTENDER BOARD BEND (CODE 523 CONTACTS) Tail Length "G" .260 (6.60) .175 (4.45) .150 (3.81) .390 (9.91) .175 (4.45) .150 (3.81) .560 (14.22) .750 (19.05) .645 (16.38) .750 (19.05) Ordering Code Notes: 1) All connector sizes up to 72 contacts single row / 144 contacts dual row are available upon request. 2) The 500 contact code is only available in the 345 series. Green polyphenylene sulphide insulator material will be supplied. 3) For details of the extender board and 90 degree bends refer to next pages. 4) For lug-less connectors, code 01 mounting, specify contact row code 1 or 2. 5) For details of the mounting options refer to page 3 & page 4. www.edac.net Page 1 345/395 SERIES Card Edge Connector 0.100" (2.54mm) Pitch SECTIONS THROUGH CONTACT POSITION DUAL ROW SINGLE ROW 0.025±0.005 (NOSE GAP) "A" AUTOMATIC WIRE WRAP POSITIONING HOLE AND SLOT "B" .330 (8.38) CARD SLOT .600 (15.24) "C" .160 (4.06) POINT OF CONTACT .370 (9.40) EVEN NUMBERED SIDE OF CONNECTOR (2,4,6,8...) 0.200(5.08) CARD SLOT ACCEPTS .054 (1.37) TO .070 (1.78) THICK P.C. BOARD .128 (3.25) DIA THROUGH HOLES B "D" .250 (6.35) .250 (6.35) G 0.125(3.18) B .170 (4.32) OR .110 (2.79) OFFSET LUGS FLUSH MTG. LUG FOR RIGHT ANGLE MOUNTING WITH FLUSH OR OFFSET LUGS .100 (2.54) .030 (0.76) X .080 (2.03) WIRE HOLE .125 (3.18) "E" SEE SHEET 3 FOR CONTACT CODES, DESCRIPTION AND TAIL SIZES, SEE SHEET 1 FOR 90°, EXTENDER BOARD BENDS CONTACTS, SEE SHEET 3 FOR IN CONTACTS AND BETWEEN CONTACTS POLARIZING KEYS PART NO., SEE SHEET 1 "F" .200 (5.08) .136 (3.45) DIA REF 0.100 .400 (10.16) .350 (8.89) 0.055 (1.40) .080 (2.03) CUT OUT FOR IN-CONTACT POLARIZING KEY. .100 (2.54) .042 (1.07) CUT OUT FOR BETWEEN CONTACT POLARIZING KEY. +.000 D MINUS .012 (0.30) -.015 (0.38) RECOMMENDED DAUGHTER BOARD NUMBER OF CONTACTS Single 5 10 13 15 18 22 25 30 31 36 43 50 60 72 Double 10 20 26 30 36 44 50 60 62 72 86 100 120 144 www.edac.net .200 PANEL MOUNT (5.08) CUT OUT .140 (3.56) PANEL MOUNT E .042 (1.07) +.004 (0.10)/-.000 FOR ALL P.C. TAILS EXCEPT CODE 524 .031 (0.79) +.004 (0.10)/-.000 FOR CODE 524 P.C. TAIL .008 (0.20) DIA CONNECTOR MOUNTING PATTERN "A"±.015 (±0.38) "B"±.010 (±0.25) Inch 1.335 1.835 2.135 2.335 2.635 3.035 3.335 3.835 3.935 4.435 5.135 5.835 6.835 8.035 Inch 1.075 1.575 1.875 2.075 2.375 2.775 3.075 3.575 3.675 4.175 4.875 5.575 6.575 7.775 mm 33.91 46.61 54.23 59.31 66.93 77.09 84.71 97.41 99.95 112.65 130.43 148.21 173.61 204.09 mm 27.31 40.01 47.63 52.71 60.33 70.49 78.11 90.81 93.35 106.05 123.83 141.61 167.01 197.49 B "C"±.015 (±0.38) Inch 0.760 1.260 1.560 1.760 2.060 2.460 2.760 3.260 3.360 3.860 4.560 5.260 6.260 7.460 mm 19.30 32.00 39.62 44.70 52.32 62.48 70.10 82.80 85.34 98.04 115.82 133.60 159.00 189.48 "D"+.010 /-.006 (+0.25/-0.15) Inch mm 0.600 15.24 1.100 27.94 1.400 35.56 1.600 40.64 1.900 48.26 2.300 58.42 2.600 66.04 3.100 78.74 3.200 81.28 3.700 93.98 4.400 111.76 5.100 129.54 6.100 154.94 7.300 185.42 "E"±.005 (±0.13) Inch 0.400 0.900 1.200 1.400 1.700 2.100 2.400 2.900 3.000 3.500 4.200 4.900 5.900 7.100 mm 10.16 22.86 30.48 35.56 43.18 53.34 60.96 73.66 76.20 88.90 106.68 124.46 149.86 180.34 345/395 SERIES Card Edge Connector 0.100" (2.54mm) Pitch .250 (6.35) DIA A .010 (0.25) RADIAL FLOAT DIA THROUGH HOLES 0.328(8.33) CONNECTOR DIMENSION CONNECTOR C DIMENSION CONNECTOR B MOUNTING OPTION CODES x02 AND xO4 (THROUGH MOUNTING HOLES) MOUNTING OPTION CODE x01 (NO MOUNTING LUGS) B DIMENSION .005 (0.51) VERTICAL FLOAT .116 (2.95) I.D. FLOATING EYELETS MOUNTING OPTION CODE x03 (FLOATING EYLETS) CODE x07 M3-0.5 METRIC CODE x08 #4-40 UNC THREADED INSERTS .128 (3.25) DIA THROUGH HOLES CODE X02 AND X04- THROUGH MTG. HOLES 0.125(3.18) "A" DIA. CONNECTOR DIMENSION CONNECTOR DIMENSION B B CODE X02 CODE X04 0.128(3.25) 0.156(3.96) CODE X07 AND X08- THREADED INSERTS CODE X07 INSERT MOUNTING OPTION CODES x07 & xO8 (THREADED INSERTS) MOUNTING OPTION CODE x12 (SIDE MOUNTING HOLES) WITH INSERTS: CODES X17 & X18, SEE TABLE CODE X17 .468 (11.89) 2.755 (69.98) A CONNECTOR .250 (6.35) .250 (6.35) #4-40 UNC THREADED INSERT #4-40 UNC THREADED INSERT CONNECTOR DIMENSION B MOUNTING OPTION CODES x78 & x88 (IN-LINE CARD GUIDE) www.edac.net "A" CARD GUIDE CONNECTOR CONNECTOR DIMENSION B #4-40 UNC M3-0.5(METRIC) CODE X18 #4-40 UNC CODES X78 AND X88- IN-LINE CARD GUIDES .120 (3.05) CARD GUIDE CODE X08 SIDE MOUNTING HOLES WITH INSERTS INSERT 0.083(2.11) M3-0.5(METRIC) .402 (10.21) MOUNTING OPTION CODES x58 (OFFSET CARD GUIDES) CODE X78 CODE X88 2.750(69.85) 1.250(31.75) 345/395 SERIES Card Edge Connector 0.100" (2.54mm) Pitch NUMBERED SIDE, EVEN NUMBERED SIDE OR ROW "A" SIDE OF CONNECTOR (DEPENDING ON THE SERIES) NUMBERED SIDE, EVEN NUMBERED SIDE OR ROW "A" SIDE OF CONNECTOR (DEPENDING ON THE SERIES) .060 (1.52) .060 (1.52) .200 (5.08) A .150 (3.81) A THIS CONTACT ROW IS STANDARD FOR SINGLE ROW BEND B B CONTACT CODE 559 CONTACT CODE 558 .120 (3.05) THIS CONTACT ROW IS STANDARD FOR SINGLE ROW BEND .165 (4.19) .095 (2.41) A A .045 (1.14) TO .060 (1.52) BETWEEN TAILS .045 (1.14) TO .060 (1.52) BETWEEN TAILS .125 (3.18) TO .185 (4.70) OUTSIDE TAILS .125 (3.18) TO .210 (5.33) OUTSIDE TAILS CONTACT CODE 555 BEND USES WIRE HOLE CONTACTS CONTACT CODE 556 IN-CONTACT POLARIZING KEY MTG. OPTION A B 555 0.245(6.22) 556 0.170(4.32) 558 0.235(5.97) 0.635(16.13) 559 0.285(7.24) 0.635(16.13) 560 0.375(9.53) www.edac.net P/N 345-240-328 .045 (1.14) TO .060 (1.52) BETWEEN TAILS .125 (3.18) TO .210 (5.33) OUTSIDE TAILS CONTACT CODE 560 BETWEEN CONTACT POLARIZING KEY P/N 345-240-318
395-020-523-201 价格&库存
很抱歉,暂时无法提供与“395-020-523-201”相匹配的价格&库存,您可以联系我们找货
