341-012-520-201
341-012-520-201
    CARDEDGE 12POS DL .100 GREEN
341-012-520-201 数据手册
Mounting Option 02-.128 (3.25) Dia. Mounting Holes Contact Detail 500-Wire Hole .050x.013(1.27x0.33) - Tail LG.=.220(5.59) .100 [2.54] Contact Spacing x .140 [3.56] Row Spacing ISSUE NUMBER THIS IS A C.A.D. GENERATED DRAWING DO NOT MAKE MANUAL REVISIONS TO MASTER. ORIGINAL 1 1.275 32.39 1.100 27.94 Card Slot Accpets .054 (1.37) To .070 (1.78) Thick P.C. Board 0.330 8.38 0.295 7.49 Card Slot 0.125 3.18 Point of Contact A 0.437 11.10 SECTION A-A A See Accompanying Pages for: • Contact Bend Details • Mounting Options • Features and Specifications 341/391 Series Card Edge Connector Part Number: 341-020-500-202 EDAC INC TORONTO, ONTARIO CANADA YOUR CONNECTION TO QUALITY & SERVICE THESE DRAWINGS AND SPECIFICATIONS ARE THE PROPERTY OF EDAC INC.,AND SHALL NOT BE REPRODUCED,OR COPIED OR USED AS THE BASIS FOR THE MANUFACTURE OR SALE OF APPARATUS WITHOUT WRITTEN PERMISSION. ACAD REFERENCE NO. J.LEE DRAWN: CHECKED: SCALE: NTS DRAWING NUMBER 341 Assembly 341 ENG MASTER DATE: SEPT. 03/09 DATE: SHEET 1 OF 3 ISSUE 1 ISSUE NUMBER THIS IS A C.A.D. GENERATED DRAWING DO NOT MAKE MANUAL REVISIONS TO MASTER. ORIGINAL 1 Bend Detail 0.120 3.05 0.095 2.41 0.165 4.19 0.190 4.82 .205 [5.21] 0.343 8.71 .125 [3.18] to .210 [5.33] Outside Tails .125 [3.18] to .185 [4.70] Outside Tails .045 [1.14] to .060 [1.52] Between Tails .045 [1.14] to .060 [1.52] Between Tails 555 Contact Code .125 [3.18] to .210 [5.33] Outside Tails .045 [1.14] to .060 [1.52] Between Tails 556 Contact Code 560 Contact Code Mounting Options .010 [0.25] Radial Float 0.116 2.95 I.D. Floating Eyelets .128 [3.25] Dia Through Holes Code x01 Code x02 0.250 6.35 Dia. Code x03 .156 [3.96] Dia Through Holes Code x04 M3-0.5 Metric Threaded Insert Code x07 #4-40 UNC Threaded Insert Code x08 0.328 8.33 0.005 0.13 Vertical Float 341/391 Series Card Edge Connector Bend Detail and Mounting Options EDAC INC TORONTO, ONTARIO CANADA YOUR CONNECTION TO QUALITY & SERVICE THESE DRAWINGS AND SPECIFICATIONS ARE THE PROPERTY OF EDAC INC.,AND SHALL NOT BE REPRODUCED,OR COPIED OR USED AS THE BASIS FOR THE MANUFACTURE OR SALE OF APPARATUS WITHOUT WRITTEN PERMISSION. ACAD REFERENCE NO. J.LEE DRAWN: CHECKED: SCALE: NTS DRAWING NUMBER 341 Assembly 341 ENG MASTER DATE: SEPT. 03/09 DATE: SHEET 2 OF 3 ISSUE 1 ISSUE NUMBER THIS IS A C.A.D. GENERATED DRAWING DO NOT MAKE MANUAL REVISIONS TO MASTER. ORIGINAL 1 Features xUL Recognized x.100 (2.54) Contact Spacing x .140 (3.56) Row Spacing xAccepts .062 (1.57) Nominal Thickness P.C. Board xLow Profile Insulator Body .437 (12.01) xContact Termination Options include P.C. Tail, Wire Hole, and Extender Board Bends xSingle or Dual Row Configurations xVariety of Mounting Options xAccepts Between Contact and In-Contact Polarizing Keys Specifications xInsulator Material: Thermoplastic Polyester, UL 94V-0 xContact Material: Copper, Nickel, Tin Alloy CA-725 xContact Plating: Gold on the Mating Area, Tin on the Contact Tails, Nickel Underplate xCurrent Rating: 3 Amperes Continuous xContact Resistance: 10 Milliohms Maximum xDielectric Withstanding Voltage: 1200 V AC rms at Sea Level Between Adjacent Contacts xInsulation Resistance: 5000 Megohms Minimum xOperating Temperature: -65 to +105 Degrees C xInsertion Force: 16 oz (4.45 N) Maximum per Contact Pair when Tested with a .070 (1.78) Thick Gauge xWithdrawal Force: 1 oz (0.28 N) Minimum per Contact Pair when Tested with a .054 (1.37) Thick Gauge 341/391 Series Card Edge Connector Features and Specifications EDAC INC TORONTO, ONTARIO CANADA YOUR CONNECTION TO QUALITY & SERVICE THESE DRAWINGS AND SPECIFICATIONS ARE THE PROPERTY OF EDAC INC.,AND SHALL NOT BE REPRODUCED,OR COPIED OR USED AS THE BASIS FOR THE MANUFACTURE OR SALE OF APPARATUS WITHOUT WRITTEN PERMISSION. ACAD REFERENCE NO. J.LEE DRAWN: CHECKED: SCALE: NTS DRAWING NUMBER 341 Assembly 341 ENG MASTER DATE: SEPT. 03/09 DATE: SHEET 3 OF 3 ISSUE 1
341-012-520-201 价格&库存
很抱歉,暂时无法提供与“341-012-520-201”相匹配的价格&库存,您可以联系我们找货
