305/315/355 SERIES
Card Edge Connector 0.156" (3.96mm) Pitch
FEATURES:
.156" (3.96mm) Contact Spacing x .140" (3.56mm) Row Spacing
Accepts .062" (1.57mm) Nominal Thickness P.C. Board
Low Profile Insulator Body, .470" (11.94mm)
Contact Termination Options include P.C. Tail, Wire Hole,
Extender Board Bends
Dual Row Configuration
Large Variety of Mounting Options
Accepts between Contact and In-Contact Polarizing Keys
Pre-assembled Card Guides are available
RoHS Compliant & UL Certified
Specifications:
UL 94V-0 Thermoplastic Polyester
Copper Alloy
Gold Plating on mating area and Tin Plating on tails with Nickel underplating all over
5 Amperes
10 milliohms maximum
1800 VAC rms at sea level between adjacent contacts
5000 Megaohms minimum
-40°C to +105°C
16oz (4.45N) maximum per contact pair when tested with .070" (1.78mm) thick gauge
1oz (0.28N) minimum per contact pair when tested with .054" (1.37mm) thick gauge
Insulator Material
Contact Material
Contact Plating
Current Rating
Contact Resistance
Dielectric Withstand Voltage
Insulation Resistance
Operating Temperature
Insertion Force
Withdrawal Force
305-056-521-202
Example Part Number:
Series
Total Number of Contacts
Contact Code
Insulator Style
Mounting Options
Series:
Insulator Color
305
315
355
Green
Green
Black
Card Slot Length
Standard Length per MIL-C-21097
.020"(0.51mm) Shorter than Standard
Total Number of Contacts:
Contact Rows
012, 014, . . . . 086
Dual Row
Contact Code Description & Tail Size
500
520
521
555
556
Wire Hole
.087 x .013 (2.21 x 0.33)
P.C. Tail
.046 x .013 (1.17 x 0.33)
P.C. Tail
EXTENDER BOARD BEND (Code 500 Contacts)
EXTENDER BOARD BEND (Code 520 Contacts)
Insulator Style
2
5
www.edac.net
Mounting Options:
01
02
03
04
07
08
12
58
68
78
Description
No Mounting Lug
Ø.128" (Ø3.25mm) Mounting Holes
Ø.116" (Ø2.95mm) I.D. Floating Eyelets
Ø.156" (Ø3.96mm) Mounting Holes
M3-0.5 Metric Threaded Inserts
#4-40 Unified Threaded Inserts
Ø.128" (Ø3.25mm) Side Mounting Holes
.468" (11.89mm) Offset Card Guides
.344 (8.74) Offset Card Guides
In-Line Card Guides 2.750" (69.85mm) Long
Ordering Code Notes:
1) All connector sizes up to 86 contacts dual row are available upon request.
2) For details of the extender board bends refer to next pages.
3) Consult with EDAC Inc. regarding single row configuration and wire wrap tail
options
4) Insulator style code 5 is available for the 305 and 355 series upon request.
5) For details of the mounting options refer to next pages.
Tail Length "G"
.282 (7.16)
.213 (5.41)
.125 (3.18)
IN-CONTACT
POLARIZING KEY
P/N 307-240-328
Description
.295 (7.49) Card Slot Depth
.330 (8.38) Card Slot Depth
Page 1
BETWEEN CONTACT
POLARIZING KEY
P/N 306-240-318
305/315/355 SERIES
INSULATOR STYLE
CODE 2
CARD SLOT ACCEPTS .054 (1.37)
TO .070 (1.78) THICK P.C. BOARD
.156 (3.96)
.295 (7.50)
CARD SLOT
.343 (8.71) UP TO 27/54 PIN
.500 (12.70) 28/56 & OVER
.090 (2.29) POINT
OF CONTACT
.470 (11.94)
.260 (6.60)
INSULATOR STYLE
CODE 5
.048 (1.22) X .125 (3.18)
WIRE HOLE
.330 (8.38)
CARD SLOT
1
2
3
4
5
6
7
8
9
10
11
A
B
C
D
E
F
G
H
J
K
L
12
13
14
15
16
N
P
Q
R
.140 (3.56)
M
.125 (3.18) POINT
OF CONTACT
PANEL MOUNT .124
(3.15)
CUTOUT
.380 (9.65)
UP TO 27/54 PIN
.140 (3.56)
.535 (13.59)
28/56 PIN & OVER
Ø.136 (3.45) REF.
PANEL MOUNT
CUT OUT
.156 (3.96)
Ø.050 (1.27)+.004 (0.10)/-.000
HOLE PATTERN FOR DUAL P.C. TAIL
.008 (0.20) DIA
MINUS .012 (0.30)
+.000
-.015 (0.38)
CARD SLOT
DEPTH PLUS
.020 (0.51)
.125 (3.18)
IN-CONTACT
POLARIZING KEY
NUMBER OF
CONTACTS
Single
12
30
36
44
48
50
56
60
72
86
"A"
inch
1.842
2.466
2.778
3.246
3.714
4.338
4.65
4.806
5.274
5.586
6.522
7.614
www.edac.net
.055 (1.40)
CUT OUT FOR
POLARIZING KEY
"B"
mm
46.79
62.64
70.56
82.45
94.34
110.19
118.11
122.07
133.96
141.88
165.66
193.40
Inch
1.532
2.156
2.468
2.936
3.404
4.028
4.340
4.496
4.964
5.276
6.212
7.304
"D"
"C"
mm
38.91
54.76
62.69
74.57
86.46
102.31
110.24
114.20
126.09
134.01
157.78
185.52
Inch
1.246
1.870
2.182
2.650
3.118
3.742
4.054
4.210
4.678
4.990
5.926
7.018
mm
31.65
47.50
55.42
67.31
79.20
95.05
102.97
106.93
118.82
126.75
150.52
178.26
Page 2
305,355
Inch
mm
1.100
27.94
1.724
43.79
2.036
51.71
2.504
63.60
2.972
75.49
3.596
91.34
3.908
99.26
4.064
103.23
4.532
115.11
4.844
123.04
5.780
146.81
6.872
174.55
"E"
315
Inch
1.080
1.704
2.016
2.484
2.952
3.576
3.888
4.044
4.512
4.824
5.760
6.852
mm
27.43
43.28
51.21
63.09
74.98
90.83
98.76
102.72
114.60
122.53
146.30
174.04
Inch
0.780
1.404
1.716
2.184
2.652
3.276
3.588
3.744
4.212
4.524
5.460
6.552
mm
19.81
35.66
43.59
55.47
67.36
83.21
91.14
95.10
106.98
114.91
138.68
166.42
305/315/355 SERIES
.250 (6.35) DIA
A DIA THROUGH
CODE x07
M3-0.5 METRIC
CODE x08
#4-40 UNC
THREADED INSERTS
.010 (0.25) RADIAL
FLOAT
HOLES
0.328(8.33)
CONNECTOR
DIMENSION
CONNECTOR
B
DIMENSION
MOUNTING OPTION
CODES x02 AND xO4
(THROUGH MOUNTING HOLES)
C
CONNECTOR
DIMENSION
MOUNTING OPTION
CODE x01
(NO MOUNTING LUGS)
B
.005 (0.51) VERTICAL
FLOAT
.116 (2.95) I.D.
FLOATING EYELETS
CONNECTOR
DIMENSION
MOUNTING OPTION
CODES x07 & x08
(THREADED INSERTS)
MOUNTING OPTION
CODE x03
(FLOATING EYLETS)
.120 (3.05)
B
.095 (2.41)
0.255
(6.48)
.045 (1.14) TO .060 (1.52)
BETWEEN TAILS
.125 (3.18) TO .185 (4.70)
OUTSIDE TAILS
BETWEEN TAILS
.125 (3.18) TO .210 (5.33)
OUTSIDE TAILS
0.185
(4.70)
CONTACT CODE 556
CONTACT CODE 555 BEND USES
WIRE HOLE CONTACTS
0.090(2.20)
"A"
"C"
CARD GUIDE
CARD GUIDE
1.550
(39.37)
"B"
CONNECTOR
CONNECTOR
.260 (6.60)
#4-40 UNC
THREADED
INSERT
CONNECTOR "B"
DIMENSION
.260 (6.60)
#4-40 UNC
THREADED
INSERT
CONNECTOR
"B"
DIMENSION
"D"
MOUNTING OPTION
CODE x78
(IN-LINE CARD GUIDE)
MOUNTING OPTION
CODES x58 & x68
(OFFSET CARD GUIDES)
SEE A CAD REF. DWG. # 305-220-002
CODE X02 AND X04- THROUGH MTG. HOLES CODES X58 AND X68- OFFSET CARD GUIDES
"A" DIA.
CODE X02
CODE X04
CODE X58
CODE X68
0.128(3.25)
0.156(3.96)
"A"
0.468(11.89)
0.344(8.74)
"B"
2.755(69.98)
2.505(63.63)
CODE X08
"C"
0.125(3.18)
0.060(1.52)
#4-40 UNC
"D"
0.423(10.74)
0.242(6.15)
CODE X07 AND X08- THREADED INSERTS
CODE X07
INSERT
M3-0.5(METRIC)
www.edac.net
Page 3
很抱歉,暂时无法提供与“305-048-500-202”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+106.275981+13.76646
- 10+90.3116610+11.69852
- 25+84.6526325+10.96548
- 50+80.6116950+10.44204
- 100+76.76454100+9.94370
- 250+71.96078250+9.32144
- 500+68.52932500+8.87695
- 1000+65.262681000+8.45380
