307-022-501-102
307-022-501-102
    CONNEDGEDUALFMALE44POS0.156
307-022-501-102 数据手册
307/357 SERIES Card Edge Connector 0.156" (3.96mm) Pitch FEATURES • 0.156" (3.96mm) Contact Spacing by 0.200" (5.08mm) Row Spacing • Accepts .062" (1.57mm) Nominal Thickness P.C. Board • Low Profile Insulator Body, 0.473" (12.01mm) • Contact Termination Options include P.C. Tail, Wire Hole, Wire Wrap, 90° and Extender Board Bends • Single or Dual Row Configurations • Large Variety of Mounting Options • Accepts between Contact and In-Contact Polarizing Keys • Pre-assembled Card Guides are available • RoHS Compliant UL Certified Specifications: Insulator Material Contact Material Contact Plating Current Rating Contact Resistance Withstand Voltage Insulation Resistance Operating Temperature Insertion Force Withdrawal Force UL 94V-0 Thermoplastic Polyester Copper Alloy Gold Plating on mating area and Tin Plating on tails with Nickel underplating all over 5A Continuous 10 milliohms maximum 1800VAC rms at sea level between adjacent contacts 5000 Megaohms minimum Operating Temperature: -40°C to +105°C 16oz (4.45N) maximum per contact pair when tested with .070" (1.78mm) thick gauge 1oz (0.28N) minimum per contact pair when tested with .054" (1.37mm) thick gauge Contact Code Example Part Number 307-044-520-202 Series Total Number of Contacts Contact Code Contact Rows Mounting Options Series: Insulator Color 307 357 Thermoplastic Polyester, Green Thermoplastic Polyester, Black Total Number of Contacts: 006, 007, . . . . 044 012, 014, . . . . 088 Contact Rows: 1 2 Contact Rows Single Row Dual Row Description Single Row (Single Readout Flush Mounting Lugs) Dual Row (Dual Readout Flush Mounting Lugs) Mounting Options: 01 02 03 04 07 08 12 58 68 78 www.edac.net Description No Mounting Lug Ø.128" (Ø3.25mm) Mounting Holes Ø.116" (Ø2.95mm) I.D. Floating Eyelets Ø.156" (Ø3.96mm) Mounting Holes M3-0.5 Metric Threaded Inserts #4-40 Unified Threaded Inserts Ø.128" (Ø3.25mm) Side Mounting Holes .468" (11.89mm) Offset Card Guides .344" (8.74mm) Offset Card Guides In-Line Card Guides 505 525 527 531 545 547 558 559 501 521 541 553 554 557 500 520 522 524 540 542 555 556 558 559 560 Description & Tail Size Tail Length "G" Single Row Contacts - Read One Side of Daughter Board Wire Hole .087 x .013 (2.21 x 0.33) .282 (7.16) P.C. Tail .046 x .013 (1.17 x 0.33) .213 (5.41) P.C. Tail .046 x .013 (1.17 x 0.33) .358 (9.09) P.C. Tail .023 x .013 (0.58 x 0.33) .213 (5.41) Wire Wrap .046 x .013 (1.17 x 0.33) .708 (17.98) Wire Wrap .046 x .013 (1.17 x 0.33) .520 (13.21) 90 DEGREE BEND (CODE 545 CONTACTS) 90 DEGREE BEND (CODE 527 CONTACTS) Single Row Contacts - Read Both Sides of Daughter Board Wire Hole .089 x .014 (2.29 x 0.36) .213 (5.41) P.C. Tail .046 x .014 (1.17 x 0.36) .213 (5.41) Wire Wrap .046 x .014 (1.17 x 0.36) .495 (12.57) 90 DEGREE BEND (CODE 521 CONTACTS) 90 DEGREE BEND (CODE 501 CONTACTS) 90 DEGREE BEND (CODE 541 CONTACTS) Dual Row Contacts - Read Both Sides of Daughter Board Wire Hole .087 x .013 (2.21 x 0.33) .282 (7.16) P.C. Tail .046 x .013 (1.17 x 0.33) .213 (5.41) P.C. Tail .046 x .013 (1.17 x 0.33) .358 (9.09) P.C. Tail .023 x .013 (0.58 x 0.33) .213 (5.41) Wire Wrap .046 x .013 (1.17 x 0.33) .708 (17.98) Wire Wrap .046 x .013 (1.17 x 0.33) .520 (13.21) .062 EXTENDER BOARD BEND (CODE 500 CONTACTS) .062 EXTENDER BOARD BEND (CODE 520 CONTACTS) 90 DEGREE BEND (CODE 522 AND 540 CONTACTS) 90 DEGREE BEND (CODE 522 AND 540 CONTACTS) .062 EXTENDER BOARD BEND (CODE 522 CONTACTS) Ordering Code Notes: 1) All connector sizes up to 44 contacts single row / 88 contacts dual row are available upon request. 2) For contacts with overall tin plating, change the first digit of the contact code from 5 to 4 3) For details of the extender board and 90 degree bends refer to next pages. 4) For details of the mounting options refer to next pages. Page 1 307/357 SERIES Card Edge Connector 0.156" (3.96mm) Pitch A BETWEEN CONTACT POLARIZING KEY P/N 306-240-318 IN-CONTACT POLARIZING KEY P/N 307-240-328 B C D .156 (3.96) CARD SLOT ACCEPTS .054 (1.37) TO .070 (1.78) THICK P.C. BOARD .343 (8.71) UP TO 27/54 PIN .500 (12.70) 28/56 & OVER SINGLE ROW CONTACTS READ ONE SIDE OF DAUGHTER BOARD DUAL ROW CONTACTS .300 (7.62) CARD SLOT .300 (7.62) CARD SLOT .473 (12.01 .270 (6.86) .125 (3.18) POINT OF CONTACT .095 (2.41) POINT OF CONTACT NUMBERED SIDE OF CONNECTOR G .048 (1.22) X .125 (3.18) WIRE HOLE SINGLE ROW CONTACTS READ BOTH SIDES OF DAUGHTER BOARD E EDAC .200 (5.08) 1 2 3 4 5 6 7 8 9 10 A B C D E F H J K .300 (7.62) CARD SLOT L .175 (4.45) POINT OF CONTACT NUMBERED SIDE OF CONNECTOR .124 (3.15) PANEL MOUNT PANEL MOUNT CUT OUT CUT OUT E ( D MINUS .012 (0.30) ) +.000 -.015 (0.38) .380 (9.65) UP TO 27/54 PIN.200 (5.08) .535 (13.59) 28/56 PIN & OVER .156 (3.96) .136 (3.45) DIA REF .320 (8.13) B .050 (1.27) DIA +.004 (0.10)/-.000 HOLE PATTERN FOR ALL P.C. TAILS EXCEPT CODES 524 & 531 .031 (0.79) +.004 (0.10)/-.000 CONNECTOR MOUNTING PATTERN FOR CODE 524 & 531 TAILS .055 (1.40) .125 (3.18) CUT OUT FOR IN-CONTACT POLARIZING KEY .008 (0.20) DIA CUT OUT FOR BETWEEN CONTACT POLARIZING KEY RECOMMENDED DAUGHTER BOARD NUMBER OF CONTACTS Single Double 6 12 8 16 10 20 12 24 15 30 18 36 20 40 22 44 25 50 28 56 30 60 36 72 43 86 88 44 "A" Inch 1.842 2.154 2.466 2.778 3.246 3.714 4.026 4.338 4.806 5.274 5.586 6.522 7.614 7.770 "B" mm 46.79 54.71 62.64 70.56 82.45 94.34 102.26 110.19 122.07 133.96 141.88 165.66 193.40 197.36 Inch 1.532 1.844 2.156 2.468 2.936 3.404 3.716 4.028 4.496 4.964 5.276 6.212 7.304 7.460 "C" mm 38.91 46.84 54.76 62.69 74.57 86.46 94.39 102.31 114.20 126.09 134.01 157.78 185.52 189.48 www.edac.net Page 2 Inch 1.246 1.558 1.870 2.182 2.650 3.118 3.430 3.742 4.210 4.678 4.990 5.926 7.018 7.174 "D" mm 31.65 39.57 47.50 55.42 67.31 79.20 87.12 95.05 106.93 118.82 126.75 150.52 178.26 182.22 Inch 1.100 1.412 1.724 2.036 2.504 2.972 3.284 3.596 4.064 4.532 4.844 5.780 6.872 7.028 "E" mm 27.94 35.86 43.79 51.71 63.60 75.49 83.41 91.34 103.23 115.11 123.04 146.81 174.55 178.51 Inch 0.780 1.092 1.404 1.716 2.184 2.652 2.964 3.276 3.744 4.212 4.524 5.460 6.552 6.708 mm 19.81 27.74 35.66 43.59 55.47 67.36 75.29 83.21 95.10 106.98 114.91 138.68 166.42 170.38 307/357 SERIES Card Edge Connector 0.156" (3.96mm) Pitch CONTACT CODE 560 CONTACT CODE 556 CONTACT CODE 555 ±.015 0.095 ±.020 0.170 ±.015 0.120 ±.020 0.245 CONTACT CODE 559 CONTACT CODE 558 ±.005 R0.050 ±.015 0.060 ±.005 R0.050 ±.015 0.062 .165 (4.19) ±.010 R0.180 R0.120~0.180 A ±.010 0.200 .125 MIN..210 MAX. .125 MIN..210 MAX. .045 MIN..060 MAX. BETWEEN TAILS. .045 MIN..060 MAX. BETWEEN TAILS. VARIATION 01 NO MOUNTING LUG VARIATION 02 .128±.003 DIA. MOUNTING HOLE .045 (1.14) TO .060 (1.52) BETWEEN TAILS .125 (3.18) TO .210 (5.33) OUTSIDE TAILS VARIATION 03 .116 +.003 I.D. FLOATING EYELET -.000 0.150±0.010 ±.010 0.150 ±.020 0.250 ±.020 0.300 ±.025 0.230 VARIATIONS 07 AND 08 VARIATION 04 THREADED INSERT .156+.002 DIA. MOUNTING HOLE -.000 .010 MIN. TOTAL RADIAL FLOAT 0.005 MIN. VERTICAL FLOAT 0.128 DIA. C 0.116 DIA. 0.156DIA. 0.350 0.476 .125 REF .020 #4-40 UNC THREADED INSERTS .020 1.500 .020 1.500 #4-40 UNC THREADED INSERTS #4-40 UNC THREADED INSERTS .425 MAX .089 REF .059 REF 1.500 "B" M3-0.5 THREADED INSERT OR 4-40 UNC THREADED INSERT .245 MAX "B" "B" .157 MAX MOUNTING OPTION MOUNTING OPTION MOUNTING OPTION CODE #58 CODE #68 CODE #78 www.edac.net Page 3
307-022-501-102 价格&库存
很抱歉,暂时无法提供与“307-022-501-102”相匹配的价格&库存,您可以联系我们找货
