424-035-500-112
424-035-500-112
    插件,P=5.08mm
    5.08MM P数:35
424-035-500-112 数据手册
408/424 SERIES METAL TO METAL (TWO PIECE) CONNECTOR • FEATURES: • .200" (5.08mm) Contact Spacing x .125" (3.18mm) or .150" (3.81mm) Row Spacing with staggered Grid • Accepts .062" (1.57mm) or .093" (2.36mm) Nominal Thickness P.C. Board • Edacon Hermaphroditic Contact Mating Design • Contact Termination Options include P.C. Tail, Fork Tail, Wire Hole and Wire Wrap • Open or Closed Card Slot Ends, Card Guides Optional • Accepts Polarizing Keys without Loss of Contact Position • 408 series without Card Guides Designed to mate with 421 Series, 408 Series with Card Guides design to mate with 422 Series, 424 Series Designed to mate with 423 Series • RoHS Compliant Specifications: Insulator Material Contact Material Contact Plating Current Rating Contact Resistance Dielectric Withstand Voltage Insulation Resistance Operating Temperature Insertion Force Withdrawal Force Example Part Number: UL 94V-0 Diallyl Phthalate, Green Color Copper Alloy Gold Plating over Nickel over entire contact 10A Continuous 10 milliohms maximum 2000 VAC rms at sea level 5000 Megaohms minimum -65°C to +125°C 2 to 16 Oz (0.56 to 4.45N) per contact position 2 to 16 Oz (0.56 to 4.45N) per contact position 424-041-500-112 Series Total Number of Contacts Series 408 424 Insulator Card Slot Ends Closed Card Slot Ends Open Card Slot Ends per Mil-C-21097 Total Number of Contacts 017, 023, 029, 035, 041 Contact Code Card Slot Width and Mounting Options Card Slot Width and Mounting Options Contact Code Description & Tail Size Tail Length "G" 500 502 520 521 522 523 524 525 540 541 542 .115 x .025 (2.92 x 0.64) .115 x .025 (2.92 x 0.64) .044 x .025 (1.12 x 0.64) .044 x .025 (1.12 x 0.64) .044 x .025 (1.12 x 0.64) .044 x .025 (1.12 x 0.64) .044 x .025 (1.12 x 0.64) .044 x .025 (1.12 x 0.64) .060 x .025 (1.52 x 0.64) .060 x .025 (1.52 x 0.64) .060 x .025 (1.52 x 0.64) Wire Hole Fork Tail P.C. Tail P.C. Tail P.C. Tail P.C. Tail P.C. Tail P.C. Tail Wire Wrap Wire Wrap Wire Wrap www.edac.net .326 (8.28) .168 (4.27) .123 (3.12) .154 (3.91) .186 (4.72) .123 (3.12) .154 (3.91) .186 (4.72) .744 (18.90) .744 (18.90) .965 (24.51) 112 122 212 Accepts .062(1.57) Board Accepts .093(2.36) Board Accepts .062(1.57) Board 222 Accepts .093(2.36) Board Description .128(3.25)Dia.Mounting Holes .128(3.25)Dia.Mounting Holes .128(3.25)Dia.Mounting Holes With Card Guides .128(3.25)Dia.Mounting Holes With Card Guides Ordering Code Notes 1) Contact Codes 523, 524 and 525 are designed for 0.150" (3.81mm) row spacing connectors. 2) Contact code 540 has a wire hole at the tip of the tail. 3) Mounting options 212 and 222 are available on the 408 series connectors only. Page 1 408/424 SERIES METAL TO METAL (TWO PIECE) CONNECTOR NUMBER OF CONTACTS 17 23 29 35 41 "A" 408 inch 2.406 3.006 3.606 4.206 4.806 mm 61.11 76.35 91.59 106.83 122.07 "B" 424 inch 2.570 3.170 3.770 4.370 4.970 mm 65.28 80.52 95.76 111.00 126.24 408 inch 2.134 2.734 3.334 3.934 4.534 424 mm 54.20 69.44 84.68 99.92 115.16 inch 2.300 2.900 3.500 4.100 4.700 www.edac.net Page 2 mm 58.42 73.66 88.90 104.14 119.38 "D" 408 inch 1.920 2.520 3.120 3.720 4.320 mm 48.77 64.01 79.25 94.49 109.73 "E" 408, 424 inch 1.600 2.200 2.800 3.400 4.000 mm 40.64 55.88 71.12 86.36 101.60 "F" 424 inch 1.900 2.500 3.100 3.700 4.300 mm 48.26 63.50 78.74 93.98 109.22
424-035-500-112 价格&库存
很抱歉,暂时无法提供与“424-035-500-112”相匹配的价格&库存,您可以联系我们找货
  • 25+344.2587825+44.62250
