322 SERIES
Card Edge Connector .156" (3.96mm) Pitch
FEATURES:
.156" (3.96mm) Contact Spacing x .200" (5.08mm) Row Spacing
Accepts .062" (1.57mm) Nominal Thickness P.C. Board
Low Profile Insulator Body, .473" (12.01mm) with Card Guides
Contact Termination Options include P.C. Tail, Wire Hole, Wire
Wrap, 90 Degree and Extender Board Bends
Single or Dual Row Configurations
Variety of Mounting Options
Accepts between Contact and In-Contact Polarizing Keys
RoHS Compliant
EXAMPLE PART NUMBER
322-044-500-258
Series
Total Number of Contacts
SERIES: 322
Contact Code
SPECIFICATIONS
Mounting Options
Contact Rows
Insulator Material:
Contact Material:
Contact Plating:
Grey polycarbonate, Glass reinforced
Copper alloy
Gold plating on mating area, Tin plating on tails
with nickel underplating all over
Current Rating:
Refer to 307/357 Series for more information/specifications
Contact Rows and Insulator Material:
1
2
Total Number of Contacts:
Contact Rows
022
044
Single Row
Dual Row
Contact Code
See 307/357 Series for available Contact Code Options and Tail
Length "G" Dimensions
Mounting Options:
Description
54
57
58
Single Row, Grey Polycarbonate
Double Row, Grey Polycarbonate
Description
Ø.156" (Ø3.96mm) x .300" (7.62mm) Deep Holes
M3-0.5 Metric Threaded Inserts
#4-40 Unified Threaded Inserts
4.875 (123.83)
4.530 (115.06)
DUAL ROW CONTACTS
4.306 (109.37)
.325 (8.26)
CARD SLOT
.343 (8.71)
CARD SLOT ACCEPTS
.054 (1.37) TO .070 (1.78)
THICK P.C. BOARDS
.100 (2.54)
POINT OF
CONTACT
CODE 54 MOUNTING - .156 (3.96) DIA X .300 (7.62) DEEP HOLES
CODE 57 MOUNTING - M3-0.5 METRIC THREADED INSERTS
CODE 58 MOUNTING - #4-40 UNC THREADED INSERTS
3.000
(76.20)
SINGLE ROW CONTACTS
READ ONE SIDE
OF DAUGHTER BOARD
3.610 (91.69)
.062
(1.57)
.325 (8.26)
CARD SLOT
.100 (2.54)
POINT OF
CONTACT
.473
(12.01)
SINGLE ROW CONTACTS
.048 (1.22) X .125 (3.18)
WIRE HOLE
READ BOTH SIDES
OF DAUGHTER BOARD
G
.156 (3.96)
.325 (8.26)
CARD SLOT
3.276 (83.21)
4.030 (102.36)
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
22
A
B
C
D
E
F
H
J
K
L
M
N
P
R
S
T
U
V
W
X
Y
Z
www.edac.net
Page 1
.180 (4.57)
POINT OF
CONTACT
很抱歉,暂时无法提供与“322-022-521-158”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 25+229.4466025+29.77798
