307/357 SERIES
Card Edge Connector 0.156" (3.96mm) Pitch
FEATURES
• 0.156" (3.96mm) Contact Spacing by 0.200" (5.08mm) Row
Spacing
• Accepts .062" (1.57mm) Nominal Thickness P.C. Board
• Low Profile Insulator Body, 0.473" (12.01mm)
• Contact Termination Options include P.C. Tail, Wire Hole, Wire
Wrap, 90° and Extender Board Bends
• Single or Dual Row Configurations
• Large Variety of Mounting Options
• Accepts between Contact and In-Contact Polarizing Keys
• Pre-assembled Card Guides are available
• RoHS Compliant UL Certified
Specifications:
Insulator Material
Contact Material
Contact Plating
Current Rating
Contact Resistance
Withstand Voltage
Insulation Resistance
Operating Temperature
Insertion Force
Withdrawal Force
UL 94V-0 Thermoplastic Polyester
Copper Alloy
Gold Plating on mating area and Tin Plating on tails with Nickel underplating all over
5A Continuous
10 milliohms maximum
1800VAC rms at sea level between adjacent contacts
5000 Megaohms minimum
Operating Temperature: -40°C to +105°C
16oz (4.45N) maximum per contact pair when tested with .070" (1.78mm) thick gauge
1oz (0.28N) minimum per contact pair when tested with .054" (1.37mm) thick gauge
Contact Code
Example Part Number
307-044-520-202
Series
Total Number of Contacts
Contact Code
Contact Rows
Mounting Options
Series:
Insulator Color
307
357
Thermoplastic Polyester, Green
Thermoplastic Polyester, Black
Total Number of Contacts:
006, 007, . . . . 044
012, 014, . . . . 088
Contact Rows:
1
2
Contact Rows
Single Row
Dual Row
Description
Single Row (Single Readout Flush Mounting Lugs)
Dual Row (Dual Readout Flush Mounting Lugs)
Mounting Options:
01
02
03
04
07
08
12
58
68
78
www.edac.net
Description
No Mounting Lug
Ø.128" (Ø3.25mm) Mounting Holes
Ø.116" (Ø2.95mm) I.D. Floating Eyelets
Ø.156" (Ø3.96mm) Mounting Holes
M3-0.5 Metric Threaded Inserts
#4-40 Unified Threaded Inserts
Ø.128" (Ø3.25mm) Side Mounting Holes
.468" (11.89mm) Offset Card Guides
.344" (8.74mm) Offset Card Guides
In-Line Card Guides
505
525
527
531
545
547
558
559
501
521
541
553
554
557
500
520
522
524
540
542
555
556
558
559
560
Description & Tail Size
Tail Length "G"
Single Row Contacts - Read One Side of Daughter Board
Wire Hole
.087 x .013 (2.21 x 0.33)
.282 (7.16)
P.C. Tail
.046 x .013 (1.17 x 0.33)
.213 (5.41)
P.C. Tail
.358 (9.09)
P.C. Tail
.023 x .013 (0.58 x 0.33)
.213 (5.41)
Wire Wrap
.708 (17.98)
Wire Wrap
.520 (13.21)
90 DEGREE BEND (CODE 545 CONTACTS)
90 DEGREE BEND (CODE 527 CONTACTS)
Single Row Contacts - Read Both Sides of Daughter Board
Wire Hole
.089 x .014 (2.29 x 0.36)
.213 (5.41)
P.C. Tail
.046 x .014 (1.17 x 0.36)
.213 (5.41)
Wire Wrap
.495 (12.57)
90 DEGREE BEND (CODE 521 CONTACTS)
90 DEGREE BEND (CODE 501 CONTACTS)
90 DEGREE BEND (CODE 541 CONTACTS)
Dual Row Contacts - Read Both Sides of Daughter Board
Wire Hole
.282 (7.16)
P.C. Tail
.213 (5.41)
P.C. Tail
.358 (9.09)
P.C. Tail
.213 (5.41)
Wire Wrap
.708 (17.98)
Wire Wrap
.520 (13.21)
.062 EXTENDER BOARD BEND (CODE 500 CONTACTS)
.062 EXTENDER BOARD BEND (CODE 520 CONTACTS)
90 DEGREE BEND (CODE 522 AND 540 CONTACTS)
.062 EXTENDER BOARD BEND (CODE 522 CONTACTS)
Ordering Code Notes:
1) All connector sizes up to 44 contacts single row / 88 contacts dual
row are available upon request.
2) For contacts with overall tin plating, change the first digit of the
contact code from 5 to 4
3) For details of the extender board and 90 degree bends refer to next
pages.
4) For details of the mounting options refer to next pages.
Page 1
307/357 SERIES
A
BETWEEN CONTACT
POLARIZING KEY
P/N 306-240-318
IN-CONTACT
POLARIZING KEY
P/N 307-240-328
B
C
D
.156 (3.96)
CARD SLOT ACCEPTS .054 (1.37)
TO .070 (1.78) THICK P.C. BOARD
.343 (8.71) UP TO 27/54 PIN
.500 (12.70) 28/56 & OVER
SINGLE ROW
CONTACTS
READ ONE SIDE
OF DAUGHTER BOARD
DUAL ROW
CONTACTS
.300 (7.62)
CARD SLOT
.300 (7.62)
CARD SLOT
.473 (12.01
.270 (6.86)
.125 (3.18) POINT
OF CONTACT
.095 (2.41) POINT
OF CONTACT
NUMBERED SIDE
OF CONNECTOR
G
.048 (1.22) X .125 (3.18)
WIRE HOLE
SINGLE ROW
CONTACTS
READ BOTH SIDES
OF DAUGHTER BOARD
E
1
2
3
4
5
6
7
8
9 10
A
B
C
D
E
F
H
J
K
.300 (7.62)
CARD SLOT
L
.175 (4.45) POINT
OF CONTACT
NUMBERED SIDE
OF CONNECTOR
.124 (3.15)
PANEL MOUNT PANEL MOUNT CUT OUT
CUT OUT
E
( D MINUS .012 (0.30) ) +.000
-.015 (0.38)
.380 (9.65)
UP TO 27/54 PIN.200 (5.08)
.535 (13.59)
28/56 PIN & OVER
.156 (3.96)
.136 (3.45) DIA REF
.320 (8.13)
B
.050 (1.27) DIA +.004 (0.10)/-.000
HOLE PATTERN FOR ALL P.C. TAILS
EXCEPT CODES 524 & 531
.031 (0.79) +.004 (0.10)/-.000
CONNECTOR MOUNTING PATTERN
FOR CODE 524 & 531 TAILS
.055 (1.40)
.125 (3.18)
CUT OUT FOR IN-CONTACT
POLARIZING KEY
.008 (0.20) DIA
CUT OUT FOR BETWEEN CONTACT
POLARIZING KEY
RECOMMENDED DAUGHTER BOARD
NUMBER OF CONTACTS
Single
Double
6
12
8
16
10
24
15
30
18
36
22
44
25
50
28
56
30
60
36
72
43
86
88
44
"A"
Inch
1.842
2.154
2.466
2.778
3.246
3.714
4.026
4.338
4.806
5.274
5.586
6.522
7.614
7.770
"B"
mm
46.79
54.71
62.64
70.56
82.45
94.34
102.26
110.19
122.07
133.96
141.88
165.66
193.40
197.36
Inch
1.532
1.844
2.156
2.468
2.936
3.404
3.716
4.028
4.496
4.964
5.276
6.212
7.304
7.460
"C"
mm
38.91
46.84
54.76
62.69
74.57
86.46
94.39
102.31
114.20
126.09
134.01
157.78
185.52
189.48
www.edac.net
Page 2
Inch
1.246
1.558
1.870
2.182
2.650
3.118
3.430
3.742
4.210
4.678
4.990
5.926
7.018
7.174
"D"
mm
31.65
39.57
47.50
55.42
67.31
79.20
87.12
95.05
106.93
118.82
126.75
150.52
178.26
182.22
Inch
1.100
1.412
1.724
2.036
2.504
2.972
3.284
3.596
4.064
4.532
4.844
5.780
6.872
7.028
"E"
mm
27.94
35.86
43.79
51.71
63.60
75.49
83.41
91.34
103.23
115.11
123.04
146.81
174.55
178.51
Inch
0.780
1.092
1.404
1.716
2.184
2.652
2.964
3.276
3.744
4.212
4.524
5.460
6.552
6.708
mm
19.81
27.74
35.66
43.59
55.47
67.36
75.29
83.21
95.10
106.98
114.91
138.68
166.42
170.38
307/357 SERIES
CONTACT
CODE 560
CONTACT
CODE 556
CONTACT
CODE 555
±.015
0.095
±.020
0.170
±.015
0.120
±.020
0.245
CONTACT
CODE 559
CONTACT
CODE 558
±.005
R0.050
±.015
0.060
±.005
R0.050
±.015
0.062
.165 (4.19)
±.010
R0.180
R0.120~0.180
A
±.010
0.200
.125 MIN..210 MAX.
.125 MIN..210 MAX.
.045 MIN..060 MAX.
BETWEEN TAILS.
.045 MIN..060 MAX.
BETWEEN TAILS.
VARIATION 01
NO MOUNTING LUG
VARIATION 02
.128±.003 DIA. MOUNTING HOLE
.045 (1.14) TO .060 (1.52)
BETWEEN TAILS
.125 (3.18) TO .210 (5.33)
OUTSIDE TAILS
VARIATION 03
.116 +.003 I.D. FLOATING EYELET
-.000
0.150±0.010
±.010
0.150
±.020
0.250
±.020
0.300
±.025
0.230
VARIATIONS 07 AND 08
VARIATION 04
THREADED INSERT
.156+.002 DIA. MOUNTING HOLE
-.000
.010 MIN. TOTAL
RADIAL FLOAT
0.005 MIN.
VERTICAL FLOAT
0.128 DIA.
C
0.116 DIA.
0.156DIA.
0.350
0.476
.125 REF
.020
#4-40 UNC
THREADED
INSERTS
.020
1.500
.020
1.500
#4-40 UNC
THREADED
INSERTS
#4-40 UNC
THREADED
INSERTS
.425
MAX
.089 REF
.059 REF
1.500
"B"
M3-0.5 THREADED INSERT OR
4-40 UNC THREADED INSERT
.245
MAX
"B"
"B"
.157
MAX
MOUNTING OPTION
MOUNTING OPTION
MOUNTING OPTION
CODE #58
CODE #68
CODE #78
www.edac.net
Page 3
很抱歉,暂时无法提供与“307-020-520-202”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 25+63.0220225+8.18310
