341/391 SERIES
Card Edge Connector 0.100" (3.96mm) Pitch
FEATURES:
UL Recognized
.100" (2.54mm) Contact Spacing x .140" (3.56mm)
Row Spacing
Accepts .062" (1.57mm) Nominal Thickness P.C.
Board
Low Profile Insulator Body, .437" (11.10mm)
Contact Termination Options include P.C. Tail,
Wire Hole and Extender Board Bends
Single or Dual Row Configurations
Variety of Mounting Options
Accepts between Contact and In-Contact
Polarizing Keys
RoHS Compliant & UL Certified
SPECIFICATIONS:
Insulator Material
Contact Material
Contact Plating
Current Rating
Contact Resistance
Dielectric Withstanding Voltage
Insulation Resistance
Operating Temperature
Insertion Force
Withdrawal Force
EXAMPLE PART NUMBER
UL 94V-0 Thermoplastic Polyester . DAP Material is available upon request
Copper Alloy
Gold Plating on mating area and Tin Plating on tails with Nickel underplating all over
3 Amperes
10 milliohms maximum
1200 VAC rms at sea level between adjacent contacts
5000 Megaohms minimum
-40°C to +105°C
16oz (4.45N) maximum per contact pair when tested with .070" (1.78mm) thick gauge
1oz (0.28N) minimum per contact pair when tested with .054" (1.37mm) thick gauge
341-062-520-202
Contact Rows:
Description
1
2
Series
Total Number of Contacts
Single Row
Dual Row
Contact Code
Mounting Options:
Contact Rows
Mounting Options
Series:
Insulator Color
341
391
Green
Black
Total Number of Contacts:
005, 006, . . . . 060
010, 012, . . . . 120
Contact Code
500
520
521
522
524
555
556
560
01
02
03
04
07
08
Contact Rows
Ordering Code Notes:
Single Row
Dual Row
1) All connector sizes up to 60 contacts single row / 120 contacts dual
row are available upon request.
2) The 500 contact code is only available in the 341 series. Green
polyphenylene sulphide insulator material will be supplied.
3) For details of the extender board bends refer to next pages.
4) For details of the mounting options refer to page 3.
Description & Tail Size Tail Length "G"
Wire Hole
.050 x .013 (1.27 x 0.33)
P.C. Tail
.025 x .013 (0.64 x 0.33)
P.C. Tail
P.C. Tail
P.C. Tail
Extender Board Bend(Code 500 Contacts)
Extender Board Bend(Code 521 Contacts)
Extender Board Bend(Code 522 Contacts)
Description
No Mounting Lug
Ø.128" (Ø3.25mm) Mounting Holes
Ø.116" (Ø2.95mm) I.D. Floating Eyelets
Ø.156" (Ø3.96mm) Mounting Holes
M3-0.5 Metric Threaded Inserts
#4-40 Unified Threaded Inserts
.220 (5.59)
.125 (3.18)
.260 (6.60)
.375 (9.53)
.100 (2.54)
www.edac.net
Page 1
341/391 SERIES
NUMBER OF CONTACTS
SINGLE
DOUBLE
5
6
10
15
18
22
25
28
30
36
40
43
50
60
10
12
36
44
50
56
60
72
80
86
100
120
"A"
"B"
"C"
"D"
"D"
INCH
MM
INCH
MM
INCH
MM
INCH
MM
INCH
MM
1.375
1.475
1.875
2.375
2.675
3.075
3.375
3.675
3.875
4.475
4.875
5.175
5.875
6.875
(34.93)
(37.47)
(47.63)
(60.33)
(67.95)
(78.11)
(85.73)
(93.35)
(98.43)
(113.67)
(123.83)
(131.45)
(149.23)
(174.63)
1.075
1.175
1.575
2.075
2.375
2.775
3.075
3.375
3.575
4.175
4.575
4.875
5.575
6.575
(27.31)
(29.85)
(40.01)
(52.71)
(60.33)
(70.49)
(78.11)
(85.73)
(90.81)
(106.05)
(116.21)
(123.83)
(141.61)
(167.01)
0.775
0.875
1.275
1.775
2.075
2.475
2.775
3.075
3.275
3.875
4.275
4.575
5.275
6.275
(19.69)
(22.23)
(32.39)
(45.09)
(52.71)
(62.87)
(70.49)
(78.11)
(83.19)
(98.43)
(108.59)
(116.21)
(133.99)
(159.39)
0.600
0.700
1.100
1.600
1.900
2.300
2.600
2.900
3.100
3.700
4.100
4.400
5.100
6.100
(15.24)
(17.78)
(27.94)
(40.64)
(48.26)
(58.42)
(66.04)
(73.66)
(78.74)
(93.98)
(104.14)
(111.76)
(129.54)
(154.94)
0.400
0.500
0.900
1.400
1.700
2.100
2.400
2.700
2.900
3.500
3.900
4.200
4.900
5.900
(10.16)
(12.7)
(22.86)
(35.56)
(43.18)
(53.34)
(60.96)
(68.58)
(73.66)
(88.9)
(99.06)
(106.68)
(124.46)
(149.86)
www.edac.net
Page 2
341/391 SERIES
NO MOUNTING LUGS
A
CONNECTOR
DIMENSION
CONNECTOR
"C"
DIMENSION
"B"
MOUNTING OPTION
CODES x02 and xO4
MOUNTING OPTION
CODE x01
.250 (6.35) DIA
DIA THROUGH HOLES
.010 (0.25) RADIAL FLOAT
.328(8.33)
.116 (2.95) I.D.
FLOATING EYELETS
.005 (0.51) VERTICAL FLOAT
CONNECTOR
"B"
DIMENSION
CONNECTOR
"B"
DIMENSION
MOUNTING OPTION
CODE x03
CODE x07
M3-0.5 METRIC
CODE x08
#4-40 UNC
THREADED
INSERTS
MOUNTING OPTION
CODES x07 & xO8
CODE X02 AND X04- THROUGH MTG. HOLES
"A" DIA.
CODE X02
CODE X04
0.128(3.25)
0.156(3.96)
CODE X07 AND X08- THREADED INSERTS
CODE X07
INSERT
CODE X08
M3-0.5(METRIC)
#4-40 UNC
.120
(3.05)
.165
(4.19)
A
A
.045 (1.14) TO .060 (1.52)
BETWEEN TAILS
.125 (3.18) TO .210 (5.33)
OUTSIDE TAILS
CONTACT CODE 555
BEND USES WIRE HOLE
CONTACTS
BETWEEN TAILS
OUTSIDE TAILS
CONTACT CODE 560
.095
(2.41)
A
BETWEEN TAILS
.125 (3.18) TO .185 (4.70)
OUTSIDE TAILS
CONTACT CODE 556
www.edac.net
Page 3
很抱歉,暂时无法提供与“341-040-520-202”相匹配的价格&库存,您可以联系我们找货
