Contact Detail
521-P.C. Tail .025 Sq.(0.64 Sq.) - Tail LG=.150(3.81)
.156 [3.96] Contact Spacing x .200 [5.08] Row Spacing
Mounting Option
01-No Mounting Lugs
0.370 9.40
ISSUE NUMBER
THIS IS A C.A.D. GENERATED DRAWING
DO NOT MAKE MANUAL REVISIONS TO MASTER.
ORIGINAL
1
0.330 8.38 Card Slot
0.160 4.06 Point of Contact
0.156 3.96
2.972 75.49
3.118 79.20
0.600 15.24
A
A
See Accompanying Pages for:
Contact Bend Details
Mounting Options
337 / 387 Series Card Edge Connector
Part Number: 387-036-521-201
EDAC INC
TORONTO, ONTARIO
CANADA
YOUR CONNECTION TO QUALITY & SERVICE
THESE DRAWINGS AND SPECIFICATIONS
ARE THE PROPERTY OF EDAC INC.,AND
SHALL NOT BE REPRODUCED,OR COPIED
OR USED AS THE BASIS FOR THE
MANUFACTURE OR SALE OF APPARATUS
WITHOUT WRITTEN PERMISSION.
ACAD REFERENCE NO.
DRAWN:
J.LEE
337 ENG MASTER
DATE: OCT. 06/09
DATE:
CHECKED:
SCALE:
SECTION A-A
Card Slot Accepts
.054 [1.37] to .070 [1.78]
Thick P.C. Board
NTS
DRAWING NUMBER
337 Assembly
SHEET 1 OF 3
ISSUE
1
ISSUE NUMBER
0.120 3.05
0.635 16.13
0.635 16.13
0.235 5.97
0.285 7.24
0.095 2.41
0.245 6.22
.125 [3.18] to .185 [4.70]
Outside Tails
.045 [1.14] to .060 [1.52]
Between Tails
Between Tails
556 Contact Code
1
0.165 4.19
0.170 4.32
.125 [3.18] to .210 [5.33]
Outside Tails
555 Contact Code
ORIGINAL
0.375 9.53
0.200 5.08
0.060 1.52
558 Contact Code
0.150 3.81
559 Contact Code
Contact Bend Detail
EDAC INC
TORONTO, ONTARIO
CANADA
Outside Tails
Between Tails
0.060 1.52
560 Contact Code
ACAD REFERENCE NO.
DRAWN:
J.LEE
DATE:
CHECKED:
SCALE:
337 ENG MASTER
DATE: OCT. 06/09
NTS
DRAWING NUMBER
337 Assembly
SHEET 2 OF 3
ISSUE
1
0.125 3.18
Code x01
ISSUE NUMBER
ORIGINAL
1
.128 [3.25] Dia
Through Holes
Code x12
.128 [3.25] Dia
Through Holes
0.468 11.89
0.344 8.74
0.125 3.18
0.250 6.35
Code x02
0.060 1.52
0.116 2.95 I.D.
Floating Eyelets
0.250 6.35 Dia.
0.090 2.29
.010 [0.25]
Radial Float
Code x03
2.755 69.98
0.328 8.33
2.505 63.63
0.005 0.13
1.550 39.37
.156 [3.96] Dia
Through Holes
Code x04
0.250 6.35
0.250 6.35
0.250 6.35
0.250 6.35
M3-0.5 Metric
Threaded Insert
0.242 6.15
0.423 10.74
Code x58
Code x07
#4-40 UNC
Threaded Insert
Code x68
Mounting Options
EDAC INC
Code x08
TORONTO, ONTARIO
CANADA
Code x78
ACAD REFERENCE NO.
DRAWN:
J.LEE
DATE:
CHECKED:
SCALE:
337 ENG MASTER
DATE: OCT. 06/09
NTS
DRAWING NUMBER
337 Assembly
SHEET 3 OF 3
ISSUE
1
很抱歉,暂时无法提供与“387-036-521-201”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 25+92.1327725+11.93442
