305-050-500-202
305-050-500-202
    CONN CARDEDGE 50POS .156 X .140
305-050-500-202 数据手册
Mounting Option 02-.128 (3.25) Dia. Mounting Holes Contact Detail 500-Wire Hole .087x.013(2.21x0.33) - Tail LG.=.282(7.16) .156 [3.96] Contact Spacing x .140 [3.56] Row Spacing ISSUE NUMBER THIS IS A C.A.D. GENERATED DRAWING DO NOT MAKE MANUAL REVISIONS TO MASTER. ORIGINAL 1 0.343 8.71 Card Slot Accepts .054 (1.37) to .070 (1.78) Thick P.C. Board 0.156 3.96 4.064 103.23 4.210 106.93 0.295 7.49 Card Slot 4.496 114.20 0.460 11.68 A A 0.090 2.29 Point of Contact 4.806 122.07 305 / 315 / 355 Card Edge Connector Part Number: 305-050-500-202 See Accompanying Page for: • Mounting Options EDAC INC TORONTO, ONTARIO CANADA YOUR CONNECTION TO QUALITY & SERVICE THESE DRAWINGS AND SPECIFICATIONS ARE THE PROPERTY OF EDAC INC.,AND SHALL NOT BE REPRODUCED,OR COPIED OR USED AS THE BASIS FOR THE MANUFACTURE OR SALE OF APPARATUS WITHOUT WRITTEN PERMISSION. SECTION A-A ACAD REFERENCE NO. J.LEE DRAWN: CHECKED: SCALE: NTS DRAWING NUMBER 305 Assembly 305 ENG MASTER DATE: SEPT. 21/09 DATE: SHEET 1 OF 2 ISSUE 1 0.125 3.18 Code x01 Code x12 ISSUE NUMBER THIS IS A C.A.D. GENERATED DRAWING DO NOT MAKE MANUAL REVISIONS TO MASTER. ORIGINAL 1 .128 [3.25] Dia Through Holes .128 [3.25] Dia Through Holes 0.468 11.89 0.344 8.74 0.125 3.18 0.060 1.52 Code x02 0.116 2.95 I.D. Floating Eyelets 0.090 2.29 0.250 6.35 Dia. .010 [0.25] Radial Float 2.750 69.85 Code x03 2.500 63.50 0.328 8.33 0.005 0.13 1.550 39.37 .156 [3.96] Dia Through Holes 0.250 6.35 Code x04 M3-0.5 Metric Threaded Insert #4-40 UNC Threaded Insert Code x68 305 / 315 / 355 Card Edge Connector Mounting Options EDAC INC Code x08 0.250 6.35 0.242 6.15 0.423 10.74 Code x58 Code x07 0.250 6.35 TORONTO, ONTARIO CANADA YOUR CONNECTION TO QUALITY & SERVICE THESE DRAWINGS AND SPECIFICATIONS ARE THE PROPERTY OF EDAC INC.,AND SHALL NOT BE REPRODUCED,OR COPIED OR USED AS THE BASIS FOR THE MANUFACTURE OR SALE OF APPARATUS WITHOUT WRITTEN PERMISSION. Code x78 ACAD REFERENCE NO. J.LEE DRAWN: CHECKED: SCALE: NTS DRAWING NUMBER 305 Assembly 305 ENG MASTER DATE: SEPT. 21/09 DATE: SHEET 2 OF 2 ISSUE 1
305-050-500-202
1. 物料型号:305-050-500-202 2. 器件简介:文档中没有提供器件的简介信息。 3. 引脚分配:文档中提到了不同代码的引脚孔,例如Code x01、Code x12、Code x02、Code x03、Code x04、Code x58、Code x68、Code x78和Code x07,但未提供具体的引脚分配图或详细说明。 4. 参数特性:文档中提到了接触间距为0.156英寸(3.96mm),行间距为0.140英寸(3.56mm),卡槽接受0.054英寸(1.37mm)到0.070英寸(1.78mm)厚的PCB板。 5. 功能详解:文档中没有提供详细的功能解释。 6. 应用信息:文档中没有提供应用信息。 7. 封装信息:文档中提到了305、315和355卡边缘连接器的装配信息,但没有提供封装的详细描述。
305-050-500-202 价格&库存
很抱歉,暂时无法提供与“305-050-500-202”相匹配的价格&库存,您可以联系我们找货
