345/395 SERIES
Card Edge Connector 0.100" (2.54mm) Pitch
• FEATURES:
.100" (2.54mm) Contact Spacing x .200" (5.08mm) Row Spacing
Accepts .062" (1.57mm) Nominal Thickness P.C. Board
High Profile Insulator Body, .600" (15.24mm)
Contact Termination Options include P.C. Tail, Wire Wrap, 90
Degree Bends and Extender Board Bends
Single or Dual Row Configurations
Large Variety of Mounting Options, Flush or Offset Lugs
Accepts between Contact and In-Contact Polarizing Keys
Pre-assembled Card Guides are available
Automatic Wire Wrap Positioning Holes
RoHS Compliant & UL Certified
Specifications:
Insulator Material
Contact Material
Contact Plating
Current Rating
Contact Resistance
Dielectric Withstand Voltage
Insulation Resistance
Operating Temperature
Insertion Force
Withdrawal Force
UL 94V-0 Thermoplastic Polyester
Copper Alloy
Gold Plating on mating area and Tin Plating on tails with Nickel underplating all over
3 Amperes
10 milliohms maximum
1200 VAC rms at sea level between adjacent contacts
5000 Megaohms minimum
-40°C to +105°C
16oz (4.45N) maximum per contact pair when tested with .070" (1.78mm) thick gauge
1oz (0.28N) minimum per contact pair when tested with .054" (1.37mm) thick gauge
Series:
345-050-520-202
Example Part Number:
Insulator Color
345
395
Series
Thermoplastic Polyester, Green
Thermoplastic Polyester, Black
Total Number of Contacts
Contact Code
Contact Code
Contact Rows and Insulator Style
500
520
521
523
524
525
540
541
542
544
555
556
558
559
560
Mounting Options
Total Number of Contacts:
Contact Rows
005, 006, . . . . 072
010, 012, . . . . 144
Single Row
Dual Row
Contact Rows & Insulator Style
Description
1
2
4
5
6
8
Single Row, Flush Mounting Lugs
Dual Row, Flush Mounting Lugs
Single Row, .110 (2.79) Offset Lugs
Dual Row, .110 (2.79) Offset Lugs
Single Row, .170 (4.32) Offset Lugs
Dual Row, .170 (4.32) Offset Lugs
Mounting Options:
01
02
03
04
07
08
12
58
78
88
Description
No Mounting Lug
Ø.128" (Ø3.25mm) Mounting Holes
Ø.116" (Ø2.95mm) I.D. Floating Eyelets
Ø.156" (Ø3.96mm) Mounting Holes
M3-0.5 Metric Threaded Inserts
#4-40 Unified Threaded Inserts
Ø.128" (Ø3.25mm) Side Mounting Holes
.468" (11.89mm) Offset Card Guides
In-Line Card Guides 2.750" (69.85mm) Long
In-Line Card Guides 1.250" (31.75mm) Long
Description & Tail Size
Wire Hole
.050 x .025 (1.27 x 0.64)
P.C. Tail
.030 x .018 (0.76 x 0.46)
P.C. Tail
.025 Square (0.64 Square)
P.C. Tail
P.C. Tail
.018 Square (0.46 Square)
P.C. Tail
Wire Wrap
Wire Wrap
Wire Wrap
Wire Wrap
EXTENDER BOARD BEND (CODE 500 CONTACTS)
EXTENDER BOARD BEND (CODE 520 CONTACTS)
90 DEGREE BEND (CODE 541 CONTACTS)
EXTENDER BOARD BEND (CODE 523 CONTACTS)
Tail Length "G"
.260 (6.60)
.175 (4.45)
.150 (3.81)
.390 (9.91)
.175 (4.45)
.150 (3.81)
.560 (14.22)
.750 (19.05)
.645 (16.38)
.750 (19.05)
Ordering Code Notes:
1) All connector sizes up to 72 contacts single row / 144 contacts dual
row are available upon request.
2) The 500 contact code is only available in the 345 series. Green
polyphenylene sulphide insulator material will be supplied.
3) For details of the extender board and 90 degree bends refer to next
pages.
4) For lug-less connectors, code 01 mounting, specify contact row code
1 or 2.
5) For details of the mounting options refer to page 3 & page 4.
www.edac.net
Page 1
345/395 SERIES
SECTIONS THROUGH
CONTACT POSITION
DUAL ROW
SINGLE ROW
0.025±0.005
(NOSE GAP)
"A"
AUTOMATIC
WIRE WRAP
POSITIONING
HOLE AND SLOT
"B"
.330 (8.38)
CARD SLOT
.600
(15.24)
"C"
.160 (4.06) POINT
OF CONTACT
.370
(9.40)
EVEN
NUMBERED
SIDE OF
CONNECTOR
(2,4,6,8...)
0.200(5.08)
CARD SLOT ACCEPTS .054 (1.37)
TO .070 (1.78) THICK P.C. BOARD
.128 (3.25) DIA
THROUGH HOLES
B
"D"
.250
(6.35)
.250 (6.35)
G
0.125(3.18)
B
.170 (4.32)
OR
.110 (2.79)
OFFSET LUGS
FLUSH MTG. LUG
FOR RIGHT ANGLE MOUNTING
WITH FLUSH OR OFFSET LUGS
.100 (2.54)
.030 (0.76) X .080
(2.03) WIRE HOLE
.125 (3.18)
"E"
SEE SHEET 3
FOR CONTACT CODES, DESCRIPTION
AND TAIL SIZES, SEE SHEET 1
FOR 90°, EXTENDER BOARD BENDS
CONTACTS, SEE SHEET 3
FOR IN CONTACTS AND BETWEEN
CONTACTS POLARIZING KEYS PART NO.,
SEE SHEET 1
"F"
.200 (5.08)
.136 (3.45)
DIA REF
0.100
.400 (10.16)
.350
(8.89)
0.055
(1.40)
.080
(2.03)
CUT OUT FOR
IN-CONTACT
POLARIZING KEY.
.100 (2.54)
.042
(1.07)
CUT OUT FOR
BETWEEN CONTACT
POLARIZING KEY.
+.000
D MINUS .012 (0.30) -.015 (0.38)
RECOMMENDED DAUGHTER BOARD
NUMBER OF CONTACTS
Single
5
10
13
15
18
22
25
30
31
36
43
50
60
72
Double
10
30
36
44
50
60
62
72
86
100
120
144
www.edac.net
.200
PANEL MOUNT
(5.08)
CUT OUT
.140 (3.56)
PANEL MOUNT
E
.042 (1.07) +.004 (0.10)/-.000
FOR ALL P.C. TAILS
EXCEPT CODE 524
.031 (0.79) +.004 (0.10)/-.000
FOR CODE 524 P.C. TAIL
.008 (0.20) DIA
CONNECTOR MOUNTING PATTERN
"A"±.015 (±0.38)
"B"±.010 (±0.25)
Inch
1.335
1.835
2.135
2.335
2.635
3.035
3.335
3.835
3.935
4.435
5.135
5.835
6.835
8.035
Inch
1.075
1.575
1.875
2.075
2.375
2.775
3.075
3.575
3.675
4.175
4.875
5.575
6.575
7.775
mm
33.91
46.61
54.23
59.31
66.93
77.09
84.71
97.41
99.95
112.65
130.43
148.21
173.61
204.09
mm
27.31
40.01
47.63
52.71
60.33
70.49
78.11
90.81
93.35
106.05
123.83
141.61
167.01
197.49
B
"C"±.015 (±0.38)
Inch
0.760
1.260
1.560
1.760
2.060
2.460
2.760
3.260
3.360
3.860
4.560
5.260
6.260
7.460
mm
19.30
32.00
39.62
44.70
52.32
62.48
70.10
82.80
85.34
98.04
115.82
133.60
159.00
189.48
"D"+.010 /-.006
(+0.25/-0.15)
Inch
mm
0.600
15.24
1.100
27.94
1.400
35.56
1.600
40.64
1.900
48.26
2.300
58.42
2.600
66.04
3.100
78.74
3.200
81.28
3.700
93.98
4.400
111.76
5.100
129.54
6.100
154.94
7.300
185.42
"E"±.005 (±0.13)
Inch
0.400
0.900
1.200
1.400
1.700
2.100
2.400
2.900
3.000
3.500
4.200
4.900
5.900
7.100
mm
10.16
22.86
30.48
35.56
43.18
53.34
60.96
73.66
76.20
88.90
106.68
124.46
149.86
180.34
345/395 SERIES
.250 (6.35) DIA
A
.010 (0.25) RADIAL
FLOAT
DIA THROUGH
HOLES
0.328(8.33)
CONNECTOR
DIMENSION
CONNECTOR
C
DIMENSION
CONNECTOR
B
MOUNTING OPTION
CODES x02 AND xO4
(THROUGH MOUNTING HOLES)
MOUNTING OPTION
CODE x01
(NO MOUNTING LUGS)
B
DIMENSION
.005 (0.51) VERTICAL
FLOAT
.116 (2.95) I.D.
FLOATING EYELETS
MOUNTING OPTION
CODE x03
(FLOATING EYLETS)
CODE x07
M3-0.5 METRIC
CODE x08
#4-40 UNC
THREADED INSERTS
.128 (3.25) DIA
THROUGH HOLES
CODE X02 AND X04- THROUGH MTG. HOLES
0.125(3.18)
"A" DIA.
CONNECTOR
DIMENSION
CONNECTOR
DIMENSION
B
B
CODE X02
CODE X04
0.128(3.25)
0.156(3.96)
CODE X07 AND X08- THREADED INSERTS
CODE X07
INSERT
MOUNTING OPTION
CODES x07 & xO8
(THREADED INSERTS)
MOUNTING OPTION
CODE x12
(SIDE MOUNTING HOLES)
WITH INSERTS: CODES X17 & X18,
SEE TABLE
CODE X17
.468
(11.89)
2.755
(69.98)
A
CONNECTOR
.250 (6.35)
.250 (6.35)
#4-40 UNC
THREADED
INSERT
#4-40 UNC
THREADED
INSERT
CONNECTOR
DIMENSION
B
MOUNTING OPTION
CODES x78 & x88
(IN-LINE CARD GUIDE)
www.edac.net
"A"
CARD GUIDE
CONNECTOR
CONNECTOR
DIMENSION
B
#4-40 UNC
M3-0.5(METRIC)
CODE X18
#4-40 UNC
CODES X78 AND X88- IN-LINE CARD GUIDES
.120
(3.05)
CARD GUIDE
CODE X08
SIDE MOUNTING HOLES WITH INSERTS
INSERT
0.083(2.11)
M3-0.5(METRIC)
.402
(10.21)
MOUNTING OPTION
CODES x58
(OFFSET CARD GUIDES)
CODE X78
CODE X88
2.750(69.85)
1.250(31.75)
345/395 SERIES
NUMBERED SIDE, EVEN
NUMBERED SIDE OR ROW
"A" SIDE OF CONNECTOR
(DEPENDING ON THE SERIES)
NUMBERED SIDE, EVEN
.060 (1.52)
.060 (1.52)
.200 (5.08)
A
.150 (3.81)
A
THIS CONTACT ROW
IS STANDARD FOR
SINGLE ROW BEND
B
B
CONTACT CODE 559
CONTACT CODE 558
.120 (3.05)
THIS CONTACT ROW
IS STANDARD FOR
SINGLE ROW BEND
.165 (4.19)
.095 (2.41)
A
A
.045 (1.14) TO .060 (1.52)
BETWEEN TAILS
BETWEEN TAILS
.125 (3.18) TO .185 (4.70)
OUTSIDE TAILS
.125 (3.18) TO .210 (5.33)
OUTSIDE TAILS
CONTACT CODE 555 BEND USES
WIRE HOLE CONTACTS
CONTACT CODE 556
IN-CONTACT
POLARIZING KEY
MTG. OPTION
A
B
555
0.245(6.22)
556
0.170(4.32)
558
0.235(5.97)
0.635(16.13)
559
0.285(7.24)
0.635(16.13)
560
0.375(9.53)
www.edac.net
P/N 345-240-328
BETWEEN TAILS
OUTSIDE TAILS
CONTACT CODE 560
BETWEEN CONTACT
POLARIZING KEY
P/N 345-240-318
很抱歉,暂时无法提供与“345-250-442-102”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 25+5.3420125+0.69445
