725-030-590-201
725-030-590-201
    插件,P=2.54mm
    2.54MM P数:30P
725-030-590-201 数据手册
725 SERIES Card Edge Connector 0.100" (2.54mm) Pitch FEATURES: • • • • • • • • • • UL Recognized .100" (2.54mm) Contact spacing x .200" (5.08mm) row spacing Accepts .062" (1.57mm) nominal thickness P.C. board Low profile insulator body, .550"(13.97mm) high Contact termination options include P.C. tail, and .025" (0.64mm) square wire wrap Press-Fit compliant section for gas tight reliable connection in plated through holes eliminates soldering operations Single or dual row configurations Accepts between contact and In-Contact polarizing keys (Special features if requested) Tools available for insulator and contact removal. Simple "Flat Rock" tooling is used for connector installation. RoHS Compliant SPECIFICATIONS: Insulator Material Contact Material Contact Plating Current Rating Contact Resistance Dielectric Withstand Voltage Insulation Resistance Operating Temperature Insertion Force Withdrawal Force Contact insertion into Hole Contact Retention in Hole Re-Insertability in same Hole EXAMPLE PART NUMBER UL 94V-0 Thermoplastic Polyester, Black Copper Alloy 30u"Gold Plating on mating area and Tin Plating on tails with Nickel underplating all over 3 Ampere 10 milliohms maximum 1200 VAC rms at sea level between adjacent contacts 5000 Megohms minimum -40°C to +105°C 16oz (4.45N) Maximum per contact pair when tested with .070" (1.78mm) thick gauge 1oz (0.28N) Minimum per contact pair when tested with .054" (1.37mm) thick gauge 20 lbs (89 N) Maximum 10 lbs (44 N) Maximum 3 Times Minimum 725-100-520-201 Series Total Number of Contacts Contact Code Contact Rows Insulator Options Series: 725 Total Number of Contacts: 005, 006, . . . . 075 010, 012, . . . . 150 Contact Rows: 1 2 Insulator Options: 01 www.edac.net Contact Code 520 522 525 540 541 545 560 Description & Contact Point Tail Length "G" P.C. Tail Regular Point P.C. Tail Regular Point P.C. Tail High Point Wire Wrap Regular Point Wire Wrap Regular Point Wire Wrap High Point Make Before Break (MBB) Contacts .190 (4.83) .375 (9.53) .190 (4.83) .560 (14.22) .750 (19.05) .560 (14.22) Ordering Code Notes: Contact Rows Single Row Dual Row Description Single Row Dual Row Description .550" (13.97mm) 1) All connector sizes up to 75 contacts single row / 150 contacts dual row are available upon request. 2) Make-Before-Break switching contacts, assembled in specific contact positions, are available upon request. BETWEEN CONTACT POLARIZING KEY P/N 341-240-318 PROPOSED IN-CONTACT POLARIZING KEY P/N 725-240-328 725 SERIES Card Edge Connector 0.100" (2.54mm) Pitch "C" .420 (10.67) CARD SLOT "D" .350 (8.89) .230 (5.84) CONTACT POINT CARD SLOT ACCEPTS .054(1.37) TO .070 (1.78) THICK P.C. BOARD CODE 101 CODE 201 Single Row Versions May Require Backup Springs Depending upon the Application. "Y" .550 (13.97) .100 (2.54) "Y" MAKE BEFORE BREAK (M.B.B) POINT CONTACTS "G" ±0.020" .025 (0.64) SQUARE P.C. & WIRE WRAP TAILS .100 (2.54) RECOMMENDED DAUGHTER BOARD "E" .535 (13.59) KEY CUT OUTS BOARD TAB .440 (11.18) .300 (7.62) .200 (5.08) .050 (1.27) CUT OUT FOR BETWEEN CONTACT POLARIZING KEY +.000 ( "D" MINUS .012 (0.30) -.015 (0.38) .080 (2.03) CUT OUT FOR IN-CONTACT POLARIZING KEY .200 (5.08) ROW SPACING .040 (1.02) DIA ± .003 (0.08) SEE NOTE BELOW .008 (0.20) DIA .100 (2.54) "E" RECOMMENDED MOTHER BOARD HOLE PATTERN NUMBER OF CONTACTS Single Double 5 10 10 20 15 30 18 36 22 44 25 50 28 56 30 60 31 62 35 70 36 72 43 86 50 100 75 150 www.edac.net TO OBTAIN OPTIMUM COMPLIANT SECTION PERFORMANCE, DRILL HOLES .0453 ± .001 (1.15 ± 0.03) DIAMETER COPPER PLATE, .001 (25.4 MICRONS) MINIMUM THICKNESS, FOLLOWED BY TIN PLATE TO PROVIDE FINISHED HOLES .040 ± .003 (1.02 ± 0.08) DIAMETER "C" Inch 0.760 1.260 1.760 2.060 2.460 2.760 3.060 3.260 3.360 3.760 3.860 4.560 5.260 7.760 "D" mm 19.30 32.00 44.70 52.32 62.48 70.10 77.72 82.80 85.34 95.50 98.04 115.82 133.60 197.10 Inch 0.600 4.400 1.600 1.900 2.300 2.600 2.900 3.100 3.200 3.600 3.700 4.400 5.100 7.600 "E" mm 15.24 111.76 40.64 48.26 58.42 66.04 73.66 78.74 81.28 91.44 93.98 111.76 129.54 193.04 Inch 0.400 0.900 1.400 1.700 2.100 2.400 2.700 2.900 3.000 3.400 3.500 4.200 4.900 7.400 mm 10.16 22.86 35.56 43.18 53.34 60.96 68.58 73.66 76.20 86.36 88.90 106.68 124.46 187.96
725-030-590-201 价格&库存
很抱歉,暂时无法提供与“725-030-590-201”相匹配的价格&库存,您可以联系我们找货
