306/316/356 SERIES
Card Edge Connector 0.156" (3.96mm) Pitch
FEATURES:
.156" (3.96mm) Contact Spacing with Single Centreline Row
Accepts .062" (1.57mm) Nominal Thickness P.C. Board
Low Profile Insulator Body, .460" (11.68mm)
Contact Termination Options include P.C. Tail & Wire Hole
Large Variety of Mounting Options
Accepts between Contact and In-Contact Polarizing Keys
Pre-assembled Card Guides are available
RoHS Compliant & UL Recognize
Specifications:
Insulator Material
Contact Material
Contact Plating
Current Rating
Contact Resistance
Dielectric Withstand Voltage
Insulation Resistance
Operating Temperature
Insertion Force
Withdrawal Force
UL 94V-0 Thermoplastic Polyester
Copper Alloy
Gold Plating on mating area and Tin Plating on tails with Nickel underplating all over
5 Amperes
10 milliohms maximum
1800 VAC rms at sea level between adjacent contacts
5000 Megohms minimum
-40°C to +105°C
16oz (4.45N) maximum per contact pair when tested with .070" (1.78mm) thick gauge
1oz (0.28N) minimum per contact pair when tested with .054" (1.37mm) thick gauge
306-022-521-178
Example Part Number:
Series
Total Number of Contacts
Insulator Color
306
316
356
Green
Green
Black
Card Slot Length
Standard Length per MIL-C-21097
.020"(0.51mm) Shorter than Standard
Ordering Code Notes:
Contact Code
Mounting Options
Total Number of Contacts:
006, 007, . . . . 043
Contact Rows
1) All connector sizes up to 43 contacts dual row are available upon request.
2) For contacts with overall tin plating, change the first digit of the contact
code from 5 to 4.
3) 5) For details of the mounting options refer to next pages.
Centre Row
Contact Code
Description & Tail Size
500
520
521
.087 x .015 (2.21 x 0.38)
.046 x .015 (1.17 x 0.38)
.037 x .015 (0.94 x 0.38)
Wire Hole
P.C. Tail
P.C. Tail
Series:
Mounting Options:
101
102
103
104
107
108
112
158
168
178
www.edac.net
Tail Length "G"
.282 (7.16)
.213 (5.41)
.125 (3.18)
Description
No Mounting Lug
Ø.128" (Ø3.25mm) Mounting Holes
Ø.116" (Ø2.95mm) I.D. Floating Eyelets
Ø.156" (Ø3.96mm) Mounting Holes
M3-0.5 Metric Threaded Inserts
#4-40 Unified Threaded Inserts
Ø.128" (Ø3.25mm) Side Mounting Holes
.468" (11.89mm) Offset Card Guides
.344 (8.74) Offset Card Guides
In-Line Card Guides
P/N 338-240-328
P/N 306-240-318
306/316/356 SERIES
CARD SLOT ACCEPTS
.054 (1.37) TO .070 (1.78)
THICK P.C. BOARD
.343
(8.71)
SIZES 28 PIN AND OVER PROVIDED IN
DIALLYL PHTHALATE OR PHENOLIC
INSULATOR MATERIAL WILL HAVE A
BODY WIDTH OF .500 (12.70)
.156 (3.96)
P/N 338-240-328
.460
(11.68)
.295 (7.49)
CARD SLOT
.250
(6.35)
.165 (4.19)
POINT OF
CONTACT
.047 (1.19) X .125 (3.18)
WIRE HOLE
1
2
3
4
5
6
7
8
9
10
11
12
A
B
C
D
E
F
H
J
K
L
M
N
EXPLODED VIEW OF CONTACT RETENSION TWIST
MINUS .012 (0.30)
+.000
-.015 (0.38)
.124 (3.15)
.380 (9.65)
PANEL MOUNT
CUT OUT
.315 (8.00)
.156 (3.96)
.125 (3.18)
.055 (1.40)
CUT OUT FOR IN-CONTACT
POLARIZING KEY
.136 (3.45) DIA
CUT OUT FOR BETWEEN CONTACT
POLARIZING KEY
.050 (1.27) DIA +.004 (0.10) /-.000
FOR CODE 520 P.C. TAIL
.041 (1.04) DIA +.004 (0.10) /-.000
FOR CODE 521 P.C. TAIL
.008 (0.20) DIA
NUMBER OF
CONTACTS
Single
6
8
10
12
15
18
22
25
28
30
36
40
43
"A"
inch
1.842
2.154
2.466
2.778
3.246
3.714
4.338
4.806
5.274
5.586
6.522
7.146
7.614
www.edac.net
"B"
mm
46.79
54.71
62.64
70.56
82.45
94.34
110.19
122.07
133.96
141.88
165.66
181.51
193.40
Inch
1.532
1.844
2.156
2.468
2.936
3.404
4.028
4.496
4.964
5.276
6.212
6.836
7.304
"D"
"C"
mm
38.91
46.84
54.76
62.69
74.57
86.46
102.31
114.20
126.09
134.01
157.78
173.63
185.52
Inch
1.246
1.558
1.87
2.182
2.65
3.118
3.742
4.21
4.678
4.99
5.926
6.55
7.018
mm
31.65
39.57
47.50
55.42
67.31
79.20
95.05
106.93
118.82
126.75
150.52
166.37
178.26
Page 2
306,356
Inch
mm
1.100
27.94
1.412
35.86
1.724
43.79
2.036
51.71
2.504
63.60
2.972
75.49
3.596
91.34
4.064
103.23
4.532
115.11
4.844
123.04
5.780
146.81
6.404
162.66
6.872
174.55
"E"
316
Inch
1.080
1.392
1.704
2.016
2.484
2.952
3.576
4.044
4.512
4.824
5.760
6.384
6.852
mm
27.43
35.36
43.28
51.21
63.09
74.98
90.83
102.72
114.60
122.53
146.30
162.15
174.04
Inch
0.780
1.092
1.404
1.716
2.184
2.652
3.276
3.744
4.212
4.524
5.460
6.084
6.552
mm
19.81
27.74
35.66
43.59
55.47
67.36
83.21
95.10
106.98
114.91
138.68
154.53
166.42
306/316/356 SERIES
.250 (6.35) DIA
.010 (0.25) RADIAL
FLOAT
0.328(8.33)
CONNECTOR
DIMENSION
CONNECTOR
C
DIMENSION
.005 (0.51) VERTICAL
FLOAT
.116 (2.95) I.D.
FLOATING EYELETS
B
MOUNTING OPTION
CODE x103
(FLOATING EYLETS)
MOUNTING OPTION
CODE x101
(NO MOUNTING LUGS)
"A" DIA.THROUGH
HOLES
CODE x07
M3-0.5 METRIC
CODE x08
#4-40 UNC
THREADED INSERTS
CONNECTOR
DIMENSION
CONNECTOR
DIMENSION
B
B
MOUNTING OPTION
CODES x107 & x108
(THREADED INSERTS)
MOUNTING OPTION
CODES x102 AND x104
(THROUGH MOUNTING HOLES)
"A"
0.090(2.20)
"C"
CARD GUIDE
CARD GUIDE
1.550
(39.37)
CONNECTOR
"B"
CONNECTOR
.250
(6.35)
.250 (6.35)
#4-40 UNC
THREADED
INSERT
CONNECTOR
"B"
DIMENSION
#4-40 UNC
THREADED
INSERT
CONNECTOR "B"
DIMENSION
MOUNTING OPTION
CODE x178
(IN-LINE CARD GUIDE)
MOUNTING OPTION
CODES x158 & x168
(OFFSET CARD GUIDES)
CODE X102 AND X104- THROUGH MTG. HOLES
"A" DIA.
CODE X102
CODE X104
0.128(3.25)
0.156(3.96)
CODE X107 AND X108- THREADED INSERTS
CODE X107
INSERT
M3-0.5(METRIC)
"D"
CODES X158 AND X168
OFFSET CARD GUIDES
CODE X158
CODE X168
"A"
0.468(11.89)
0.344(8.74)
"B"
2.755(69.98)
2.505(63.63)
CODE X108
"C"
0.125(3.18)
0.060(1.52)
#4-40 UNC
"D"
0.423(10.74)
0.242(6.15)
www.edac.net
Page 3
很抱歉,暂时无法提供与“338-240-328”相匹配的价格&库存,您可以联系我们找货
