341-240-318
341-240-318
341-240-318 数据手册
725 Example Part Number: 725-100-520-206 Series Total Number of Contacts Contact Code Contact Rows Insulator Options Series: 725 Total Number of Contacts SPECIFICATIONS: - Insulator Material: UL 94V-0 Thermoplastic Polyester - Color: Black - Contact Material: Copper, Nickel, Tin Alloy CA-725 - Contact Plating: 30µIN of Gold on the Mating Area, Tin Plating on Compliant Section and Contact Tails, Nickel underplate. Other Plating Options also available upon Request - Current Rating: 2 Amperes Continuous - Contact Resistance: 10 Milli Ohms Maximum - Dielectric Withstanding Voltage: 1200 V AC RMS at Sea Level between Adjacent Contacts - Insulation Resistance: 5000 MOhms Minimum - Operating Temperature: -65⁰C to +125⁰C - Daughter Board Insertion Force: 16 Oz (4.45N) Maximum per Contact Pair, when tested with a .054"(1.37) thick gauge - Contact Insertion Into Hole: 20 Lbs (89N) Maximum - Contact Retention Into Hole: 10 Lbs (44N) Minimum - Reinsertability of Hole: 3 times Minimum FEATURES: - CSA Approved and UL Recognized - Contact Termination Options include P.C. Tail and .025"(0.64) Square Wire Wrap - High Profile Insulator Body .645"(16.38) with End Notch Option - Compliant Section for Gas Tight reliable connection in plated through holes eliminates soldering operation - Accept between Contact and In-Contact Polarizing Keys (Special Features, if requested) Single Row Double Row Contact Code 520 522 525 540 541 545 560 Description Tail Length "G" P.C. TAIL REGULAR POINT P.C. TAIL REGULAR POINT P.C. TAIL HIGH POINT WIRE WRAP REGULAR POINT WIRE WRAP REGULAR POINT WIRE WRAP HIGH POINT MAKE BEFORE BREAK (MBB) CONTACT Contact Rows .175"(4.45) .375"(9.53) .175"(4.45) .560"(14.22) .750"(19.05) .560"(14.22) Description 1 2 Single Row Double Row Insulator Options Description 01 06 .645"(16.38) Full Height Ends .550"(13.97) Notched Ends Ordering Notes: All connectors sizes up to 75 contacts in single row or 150 contacts in double row are available upon request. Recommended Daughter Board: Polarizing Features: BETWEEN CONTACT POLARIZING KEY P/N 341-240-318 Contact Rows 005, 006, . . . . 075 010, 012, . . . . 150 PROPOSED IN-CONTACT POLARIZING KEY P/N 725-240-328 .535 (13.59) KEY CUT OUTS BOARD TAB .440 (11.18) .050 (1.27) CUT OUT FOR BETWEEN CONTACT POLARIZING KEY +.000 MINUS .012 (0.30) -.015 (0.38) .080 (2.03) CUT OUT FOR IN-CONTACT POLARIZING KEY ( "D" Phone: (416) - 754 - 3322 Fax: (416) - 754 - 3299 Email: CustomerService@edac.net Website: www.edac.net 725 .200 (5.08) ROW SPACING .100 (2.54) "E" RECOMMENDED MOTHER BOARD HOLE PATTERN "C" .040 (1.02) DIA ± .003 (0.08) SEE NOTE BELOW .008 (0.20) DIA "D" .350 (8.89) TO OBTAIN OPTIMUM COMPLIANT SECTION PERFORMANCE, DRILL HOLES .0453 ± .001 (1.15 ± 0.03) DIAMETER COPPER PLATE, .001 (25.4 MICRONS) MINIMUM THICKNESS, FOLLOWED BY TIN-LEAD PLATE TO PROVIDE FINISHED HOLES .040 ± .003 (1.02 ± 0.08) DIAMETER CARD SLOT ACCEPTS .054(1.37) TO .070 (1.78) THICK P.C. BOARD "Y" .420 (10.67) CARD SLOT .550 (13.97) .100 (2.54) .230 (5.84) CONTACT POINT "Y" CODE 201 CODE 101 "G" MAKE BEFORE BREAK (M.B.B) POINT CONTACTS Single Row Versions May Require Backup Springs Depending upon the Application. .025 (0.64) SQUARE P.C. & WIRE WRAP TAILS .100 (2.54) "E" .300 (7.62) .200 (5.08) 41 40 82 80 39 38 78 76 37 4.360 (110.74) 4.200 4.260 (108.20) 4.100 4.160 (105.66) 4.000 4.060 (103.12) 3.900 40 39 74 (106.68) 4.000 (101.60) (104.14) 3.900 (99.06) (101.60) 3.800 (96.52) (99.06) 3.700 (93.98) 3.960 (100.58) 3.800 (96.52) 3.600 (91.44) 36 72 3.860 (98.04) 70 68 3.760 (95.50) 3.660 (92.96) 3.700 (93.98) 3.600 (91.44) 3.500 (8.900 3.400 (86.36) 35 35 34 33 32 31 66 64 62 3.560 (90.42) 3.460 (87.88) 3.360 (85.34) 3.500 (8.900 3.400 (86.36) 3.300 (83.82) 3.200 (81.28) 3.100 (78.74) 30 60 29 28 56 56 3.260 (82.80) 3.160 (80.26) 3.060 (77.72) 27 26 54 52 2.960 (75.18) 2.860 (72.64) 25 24 23 50 48 46 2.760 (70.10) 2.660 (67.56) 2.560 (65.02) 22 21 20 19 44 42 40 38 36 34 2.460 2.360 2.260 2.160 (62.48) (59.94) (57.40) (54.86) 2.060 1.960 1.860 1.760 (52.32) (49.78) (47.24) (44.70) 1.660 1.560 1.460 1.360 1.260 1.160 (42.16) (39.62) (37.08) (34.54) (32.00) (29.46) 1.060 .960 .860 .760 (26.92) (24.38) (21.84) (19.30) 18 17 16 15 14 13 12 11 10 9 8 7 6 5 32 30 28 26 24 22 20 18 16 14 12 10 3.300 (83.82) 3.200 (81.28) 3.100 (78.74) 3.000 (76.20) 2.900 (73.66) 2.800 (71.12) 2.700 2.600 2.500 2.400 2.300 2.200 2.100 (68.58) (66.04) (63.50) (60.96) (58.42) (55.88) (53.34) 2.000 1.900 1.800 1.700 1.600 1.500 (50.80) (48.26) (54.72) (43.18) (40.64) (38.10) 1.400 1.300 1.200 1.100 1.000 .900 (35.56) (33.02) (30.48) (27.94) (25.40) (22.86) .800 (20.32) .700 (17.78) .600 (15.24) 38 37 36 34 33 32 31 30 3.000 2.900 2.800 2.700 (76.20) (73.66) (71.12) (68.58) 2.600 2.500 2.400 2.300 2.200 2.100 2.000 1.900 (66.04) (63.50) (60.96) (58.42) (55.88) (53.34) (50.80) (48.26) 26 25 1.800 1.700 1.600 1.500 1.400 1.300 1.200 1.100 1.000 .900 .800 .700 .600 (54.72) (43.18) (40.64) (38.10) (35.56) (33.02) (30.48) (27.94) (25.40) (22.86) (20.32) (17.78) (15.24) 18 17 16 15 .500 (12.70) .400 (10.16) 5 4 29 28 27 24 23 22 21 20 19 14 13 12 11 10 9 8 7 6 75 74 73 150 148 146 72 71 70 69 68 67 144 142 66 65 64 63 62 61 60 59 58 57 56 55 54 53 140 138 136 134 132 130 128 126 124 122 120 118 116 114 112 110 108 106 104 52 51 50 49 102 100 98 48 47 46 96 94 92 45 44 90 88 43 42 86 84 7.760 (197.10) 7.600 7.660 (194.56) 7.500 7.560 (192.02) 7.400 7.460 (189.94) 7.300 7.360 (186.94) 7.200 7.260 (184.40) 7.100 7.160 (181.86) 7.000 (193.04) 7.400 (187.96) (190.50) (187.96) (185.42) (182.88) (180.34) (177.80) 7.060 (179.32) 6.900 6.960 (176.78) 6.800 6.860 (174.24) 6.700 6.760 (171.70) 6.600 6.660 (169.16) 6.500 (175.26) (172.72) (170.18) (167.64) (165.10) 74 73 72 7.300 7.200 7.100 7.000 6.900 (185.42) (182.88) (180.34) (177.80) (175.26) 6.800 6.700 6.600 6.500 (172.72) (170.18) (167.64) (165.10) 68 67 66 65 6.460 6.360 6.260 6.160 6.400 6.300 166.62) 6.400 (162.56) 6.200 (164.08) 6.300 (160.02) 6.100 (161.54) 6.200 (157.48) 6.000 (148.84) 6.100 (154.94) 5.900 (156.46) 6.000 (152.40) 5.800 (162.56) (160.02) (157.48) (154.94) (152.40) 64 63 62 61 60 (149.86) (147.32) 6.060 5.960 5.860 5.760 5.660 (153.92) (151.38) (148.84) (146.30) (143.76) 59 58 57 56 5.560 5.460 5.360 5.260 5.160 (141.22) (138.68) (136.14) (133.60) (131.06) 6.560 5.900 (149.86) 5.700 (144.78) 5.800 (147.32) 5.600 (142.24) 5.700 (144.78) 5.500 (139.70) 5.600 (142.24) 5.400 (137.16) 5.500 (139.70) 5.300 (134.62) 5.400 (137.16) 5.200 (132,08) 5.300 (134.62) 5.100 (129.54) 5.200 (132,08) 5.000 (127.00) 5.100 (129.54) 4.900 (124.46) 5.000 (127.00) 4.800 (121.92) 5.060 (128.52) 4.900 (124.46) 4.960 (125.98) 4.800 (121.92) 4.860 (123.44) 4.700 (119.38) 4.760 (120.90) 4.600 (116.84) 4.660 (118.36) 4.500 (114.30) 4.700 (119.38) 4.600 (116.84) 4.500 (114.30) 4.400 (111.76) 4.300 (109.22) 4.560 (115.82) 4.400 (111.76) 4.200 (106.68) 4.460 (113.28) 4.300 (109.22) 4.100 (104.14) 71 70 69 55 54 53 52 51 50 49 48 47 46 45 44 43 42 41 NO OF NO OF NO OF NO OF Inch mm Inch mm Inch mm NO OF Inch mm Inch mm Inch mm NO OF CONTACTS CONTACTS SPACES CONTACTS CONTACTS SPACES +.010 (+0.25) +.010 (+0.25) (SINGLE ROW) (DUAL ROW) C ±.015 (±0.38) D -.006 (-0.15) E ±.005 (±0.13) (SINGLE ROW) (DUAL ROW) C ±.015 (±0.38) D -.006 (-0.15) E ±.005 (±0.13) Phone: (416) - 754 - 3322 Fax: (416) - 754 - 3299 Email: CustomerService@edac.net Website: www.edac.net
341-240-318 价格&库存
很抱歉,暂时无法提供与“341-240-318”相匹配的价格&库存,您可以联系我们找货
    • 150+6.42587150+0.83419
    • 500+4.20271500+0.54558
    库存:500
