305/315/355 SERIES
Card Edge Connectors 0.156” (3.96mm) Pitch
Features:
0.156” (3.96mm) contact spacing x 0.140” (3.56mm) row spacing
Accepts 0.062” (1.57mm) nominal thickness P.C. board
Low profile insulator body, 0.470” (11.94mm)
Contact termination options include P.C. tail, wire hole, extender board bends
Dual row configuration
Large variety of mounting options
Accepts between contact and in-contact polarizing keys
Pre-assembled card guides are available
RoHS Compliant & UL Certified
Specifications:
Insulator Material
UL 94V-0 Thermoplastic Polyester
Contact Material
Copper Alloy
Contact Plating
Gold Plating on mating area and Tin Plating on tails with Nickel underplating all over
Current Rating
5 amps
Contact Resistance
10 milliohms maximum
Dielectric Withstanding Voltage
1800 V AC rms at sea level between adjacent contacts
Insulation Resistance
5000 megaohms minimum
Operating Temperature
-40°C to +105°C
Insertion Force
16 oz (4.45 N) maximum per contact pair when tested with .070” (1.78mm) thick gauge
Withdrawal Force
1 oz (0.28 N) minimum per contact pair when tested with .054” (1.37mm) thick gauge
305-056-521-202
Mounting Options:
Description:
Series
01
No Mounting Lug
Total Number of Contacts
02
Ø.128” (Ø3.25mm) Mounting Holes
Contact Code
03
Ø.116” (Ø2.95mm) I.D. Floating Eyelets
04
Ø.156” (Ø3.96mm) Mounting Holes
07
M3-0.5 Metric Threaded Inserts
08
#4-40 Unified Threaded Inserts
12
Ø.128” (Ø3.25mm) Side Mounting Holes
58
.468” (11.89mm) Offset Card Guides
68
.344” (8.74) Offset Card Guides
78
In-Line Card Guides 2.750” (69.85mm) Long
Example Part Number:
Insulator Style
Mounting Options
Series:
Insulator Color:
305
Green
315
Green
355
Black
Total Number of Contacts:
Contact Rows:
012, 014, . . . . 086
Card Slot Length:
Standard Length per MIL-C-21097
.020"(0.51mm) Shorter than Standard
Dual Row
Contact Code:
Description:
Tail Size:
Tail Length “G”:
500
Wire Hole
.087” x .015” (2.21 x
0.38)
.282” (7.16)
520
P.C. Tail
.046” x .015” (1.17 x
0.38)
.213” (5.41)
521
P.C. Tail
.037” x .015” (0.94 x
0.38)
.125” (3.18)
555
EXTENDER
BOARD BEND
(Code 500 Contacts)
556
EXTENDER
BOARD BEND
(Code 520 Contacts)
Insulator Style:
Description:
2
.295” (7.49) Card Slot Depth
5
.330” (8.38) Card Slot Depth
www.edac.net
IN-CONTACT
POLARIZING KEY
P/N 307-240-328
BETWEEN CONTACT
POLARIZING KEY
P/N 306-240-318
Ordering Code Notes:
1) All connector sizes up to 86 contacts dual row are available upon request.
2) For details of the extender board bends refer to next pages.
3) Consult with EDAC Inc. regarding single row configuration and wire wrap
tail options
4) Insulator style code 5 is available for the 305 and 355 series upon request.
5) For details of the mounting options refer to next pages.
customerservice@edac.net
305/315/355 SERIES
INSULATOR STYLE
CODE 2
CARD SLOT ACCEPTS .054 (1.37)
TO .070 (1.78) THICK P.C. BOARD
.156 (3.96)
.295 (7.50)
CARD SLOT
.343 (8.71) UP TO 27/54 PIN
.500 (12.70) 28/56 & OVER
.090 (2.29) POINT
OF CONTACT
.470 (11.94)
.260 (6.60)
INSULATOR STYLE
CODE 5
.048 (1.22) X .125 (3.18)
WIRE HOLE
.330 (8.38)
CARD SLOT
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
A
B
C
D
E
F
G
H
J
K
L
M
N
P
Q
R
.140 (3.56)
.125 (3.18) POINT
OF CONTACT
PANEL MOUNT .124
(3.15)
CUTOUT
.380 (9.65)
UP TO 27/54 PIN
.140 (3.56)
.535 (13.59)
28/56 PIN & OVER
Ø.136 (3.45) REF.
PANEL MOUNT
CUT OUT
.156 (3.96)
Ø.050 (1.27)+.004 (0.10)/-.000
HOLE PATTERN FOR DUAL P.C. TAIL
.008 (0.20) DIA
MINUS .012 (0.30)
+.000
-.015 (0.38)
CARD SLOT
DEPTH PLUS
.020 (0.51)
.125 (3.18)
IN-CONTACT
POLARIZING KEY
NUMBER OF
CONTACTS
"A"
"B"
.055 (1.40)
CUT OUT FOR
POLARIZING KEY
"C"
"D"
"E"
305,355
315
Single
inch
mm
Inch
mm
Inch
mm
Inch
mm
Inch
mm
Inch
mm
12
1.842
46.79
1.532
38.91
1.246
31.65
1.100
27.94
1.080
27.43
0.780
19.81
62.64
2.156
54.76
1.870
47.50
1.724
43.79
1.704
43.28
1.404
35.66
24
2.778
70.56
2.468
62.69
2.182
55.42
2.036
51.71
2.016
51.21
1.716
43.59
30
3.246
82.45
2.936
74.57
2.650
67.31
2.504
63.60
2.484
63.09
2.184
55.47
36
3.714
94.34
3.404
86.46
3.118
79.20
2.972
75.49
2.952
74.98
2.652
67.36
44
4.338
110.19
4.028
102.31
3.742
95.05
3.596
91.34
3.576
90.83
3.276
83.21
48
4.65
118.11
4.340
110.24
4.054
102.97
3.908
99.26
3.888
98.76
3.588
91.14
50
4.806
122.07
4.496
114.20
4.210
106.93
4.064
103.23
4.044
102.72
3.744
95.10
56
5.274
133.96
4.964
126.09
4.678
118.82
4.532
115.11
4.512
114.60
4.212
106.98
60
5.586
141.88
5.276
134.01
4.990
126.75
4.844
123.04
4.824
122.53
4.524
114.91
72
6.522
165.66
6.212
157.78
5.926
150.52
5.780
146.81
5.760
146.30
5.460
138.68
86
7.614
193.40
7.304
185.52
7.018
178.26
6.872
174.55
6.852
174.04
6.552
166.42
www.edac.net
305/315/355 SERIES
.250 (6.35) DIA
A DIA THROUGH
CODE x07
M3-0.5 METRIC
CODE x08
#4-40 UNC
THREADED INSERTS
.010 (0.25) RADIAL
FLOAT
HOLES
0.328(8.33)
CONNECTOR
DIMENSION
CONNECTOR
B
DIMENSION
MOUNTING OPTION
CODES x02 AND xO4
(THROUGH MOUNTING HOLES)
C
CONNECTOR
DIMENSION
MOUNTING OPTION
CODE x01
(NO MOUNTING LUGS)
B
.005 (0.51) VERTICAL
FLOAT
.116 (2.95) I.D.
FLOATING EYELETS
CONNECTOR
DIMENSION
MOUNTING OPTION
CODES x07 & x08
(THREADED INSERTS)
MOUNTING OPTION
CODE x03
(FLOATING EYLETS)
.120 (3.05)
B
.095 (2.41)
0.255
(6.48)
.045 (1.14) TO .060 (1.52)
BETWEEN TAILS
.125 (3.18) TO .185 (4.70)
OUTSIDE TAILS
BETWEEN TAILS
.125 (3.18) TO .210 (5.33)
OUTSIDE TAILS
0.185
(4.70)
CONTACT CODE 556
CONTACT CODE 555 BEND USES
WIRE HOLE CONTACTS
0.090(2.20)
"A"
"C"
CARD GUIDE
CARD GUIDE
1.550
(39.37)
"B"
CONNECTOR
CONNECTOR
.260 (6.60)
#4-40 UNC
THREADED
INSERT
CONNECTOR "B"
DIMENSION
.260 (6.60)
#4-40 UNC
THREADED
INSERT
CONNECTOR
"B"
DIMENSION
"D"
MOUNTING OPTION
CODE x78
(IN-LINE CARD GUIDE)
MOUNTING OPTION
CODES x58 & x68
(OFFSET CARD GUIDES)
SEE A CAD REF. DWG. # 305-220-002
CODE X02 AND X04- THROUGH MTG. HOLES CODES X58 AND X68- OFFSET CARD GUIDES
CODE X02
CODE X04
0.128(3.25)
0.156(3.96)
CODE X07 AND X08- THREADED INSERTS
"A" DIA.
CODE X07
INSERT
www.edac.net
M3-0.5(METRIC)
CODE X58
CODE X68
"A"
0.468(11.89)
0.344(8.74)
"B"
2.755(69.98)
2.505(63.63)
CODE X08
"C"
0.125(3.18)
0.060(1.52)
#4-40 UNC
"D"
0.423(10.74)
0.242(6.15)
很抱歉,暂时无法提供与“243-240-318”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1000+2.703461000+0.35042
