325-240-328
325-240-328
325-240-328 数据手册
325 SERIES CARD EDGE CONNECTOR .100" (2.54mm) Contact Spacing, Accepts .125" (3.18mm) Thick Board 325 SERIES ORDERING CODE Example Part Number 325 - 122 - 520 - 2 09 Series Total Number of Contacts Contact Code Contact Rows Mounting Options Series 325 Total Number of Contacts 1 005, 006,...061 010, 012,...122 Contact Rows Single Row Dual Row Contact Code Description & Tail Size Tail Length "G" 500 Wire Hole .050 x .025 (1.27 x 0.64) .260 (6.60) 520 P.C. Tail .025 Square (0.64 Square) .175 (4.45) 540 Wire Wrap .025 Square (0.64 Square) .560(14.22) FEATURES .100 (2.54) Contact Spacing x .300 (7.62) Row Spacing Accepts .125 (3.18) Nominal Thickness P.C. Board High Profile Insulator Body, .600 (15.24) Contact Termination Options include P.C. Tail, Wire Hole & .025 (0.64) Square Wire Wrap L Single or Dual Row Configurations L Variety of Mounting Options L Accepts In-Contact Polarizing Keys L Automatic Wire Wrap Positioning Holes L L L L SPECIFICATIONS U Insulator Material: Polyphenylene Sulphide, UL 94V-0, Colour: Green U Contact Material: Copper, Nickel, Tin Alloy CA-725 U Contact Plating: Gold on the Mating Area, Tin on the Contact Tails, Nickel Underplate U Current Rating: 3 Amperes Continuous U Contact Resistance: 10 Milliohms Maximum U Dielectric Withstanding Voltage: 1200 V AC rms at Sea Level Between Adjacent Contacts U Insulation Resistance: 5000 Megohms Minimum U Operating Temperature: -65 to +105 Degrees C U Insertion Force: 16 oz (4.45 N) Maximum per Contact Pair when Tested with a .135 (3.43) Thick Gauge U Withdrawal Force: 1 oz (0.28 N) Minimum per Contact Pair when Tested with a .115 (2.92) Thick Gauge Page 32 Contact Rows 1 2 Mounting Options 2 01 07 08 09 Description Single Row Dual Row Description No Mounting Lugs M3-0.5 Metric Threaded Inserts #4-40 Unified Threaded Inserts .160 (4.06) Dia. Mounting Holes Ordering Code Notes 1) All connector sizes up to 61 contacts single row / 122 contacts dual row are available upon request. 2) For details of the mounting options, refer to page 68. Tel: (416) 754 - 3322 CARD EDGE CONNECTOR SERIES 325 ccepts .125" (3.18mm) Thick Board, Contact Spacing .100" (2.54mm) NUMBER OF CONTACTS "A" "B" "C" "D" "E" Single Dual Inch (mm) Inch (mm) Inch (mm) Inch (mm) Inch (mm) 5 15 18 22 25 30 36 40 43 10 30 36 44 50 60 72 80 86 1.355 2.355 2.655 3.055 3.355 3.855 4.455 4.855 5.155 (34.42) (59.82) (67.44) (77.60) (85.22) (97.92) (113.16) (123.32) (130.94) 1.056 2.056 2.356 2.756 3.056 3.556 4.156 4.556 4.856 (26.82) (52.22) (59.84) (70.00) (77.62) (90.32) (105.56) (115.72) (123.34) .722 1.722 2.022 2.422 2.722 3.222 3.822 4.222 4.522 (18.34) (43.74) (51.36) (61.52) (69.14) (81.84) (97.08) (107.24) (114.86) .600 1.600 1.900 2.300 2.600 3.100 3.700 4.100 4.400 (15.24) (40.64) (48.26) (58.42) (66.04) (78.74) (93.98) (104.14) (111.76) .400 1.400 1.700 2.100 2.400 2.900 3.500 3.900 4.200 (10.16) (35.56) (43.18) (53.34) (60.96) (73.66) (88.90) (99.06) 50 61 100 122 5.855 6.955 (148.72) (176.66) 5.556 6.656 (141.12) (169.06) 5.222 6.322 (132.64) (160.58) 5.100 6.200 (129.54) (157.48) 4.900 6.000 (106.68) (124.46) (152.40) Dimensions of Other Connector Sizes are Listed on Page 72 Fax: (416) 754 - 3299 Page 33 .100" (2.54mm) CONTACT SPACING CONNECTOR DIMENSIONS 325, 340, 341, 342, 345, 391, 392, 395, 745 Series Card Edge Connectors DIMENSION SERIES Number of Contacts Single Dual 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 10 12 14 16 18 20 22 24 26 28 30 32 34 36 38 40 42 44 46 48 50 52 54 56 58 60 62 64 66 68 70 72 74 76 78 80 82 84 86 88 90 92 94 96 98 100 102 104 106 108 110 112 114 116 118 120 122 124 126 128 130 132 134 136 138 140 142 144 146 148 150 Page 72 "A" 325 340 341, 391 "B" 342, 392 345, 395 325 340 341, 391 345, 395 342, 392 Inch (mm) Inch (mm) Inch (mm) Inch (mm) Inch (mm) Inch (mm) Inch (mm) Inch (mm) Inch (mm) 1.355 1.455 1.555 1.655 1.755 1.855 1.955 2.055 2.155 2.255 2.355 2.455 2.555 2.655 2.755 2.855 2.955 3.055 3.155 3.255 3.355 3.455 3.555 3.655 3.755 3.855 3.955 4.055 4.155 4.255 4.355 4.455 4.555 4.655 4.755 4.855 4.955 5.055 5.155 5.255 5.355 5.455 5.555 5.655 5.755 5.855 5.955 6.055 6.155 6.255 6.355 6.455 6.555 6.655 6.755 6.855 6.955 (34.42) (36.96) (39.50) (42.04) (44.58) (47.12) (49.66) (52.20) (54.74) (57.28) (59.82) (62.36) (64.90) (67.44) (69.98) (72.52) (75.06) (77.60) (80.14) (82.68) (85.22) (87.76) (90.30) (92.84) (95.38) (97.92) (100.46) (103.00) (105.54) (108.08) (110.62) (113.16) (115.70) (118.24) (120.78) (123.32) (125.86) (128.40) (130.94) (133.48) (136.02) (138.56) (141.10) (143.64) (146.18) (148.72) (151.26) (153.80) (156.34) (158.88) (161.42) (163.96) (166.50) (169.04) (171.58) (174.12) (176.66) 1.900 2.000 2.100 2.200 2.300 2.400 2.500 2.600 2.700 2.800 2.900 3.000 3.100 3.200 3.300 3.400 3.500 3.600 3.700 3.800 3.900 4.000 4.100 4.200 4.300 4.400 4.500 4.600 4.700 4.800 4.900 5.000 5.100 5.200 5.300 5.400 5.500 5.600 5.700 5.800 5.900 6.000 6.100 6.200 6.300 6.400 6.500 6.600 6.700 6.800 6.900 7.000 7.100 7.200 7.300 7.400 (48.26) (50.80) (53.34) (55.88) (58.42) (60.96) (63.50) (66.04) (68.58) (71.12) (73.66) (76.20) (78.74) (81.28) (83.82) (86.36) (88.90) (91.44) (93.98) (96.52) (99.06) (101.60) (104.14) (106.68) (109.22) (111.76) (114.30) (116.84) (119.38) (121.92) (124.46) (127.00) (129.54) (132.08) (134.62) (137.16) (139.70) (142.24) (144.78) (147.32) (149.86) (152.40) (154.94) (157.48) (160.02) (162.56) (165.10) (167.64) (170.18) (172.72) (175.26) (177.80) (180.34) (182.88) (185.42) (187.96) 1.375 1.475 1.575 1.675 1.775 1.875 1.975 2.075 2.175 2.275 2.375 2.475 2.575 2.675 2.775 2.875 2.975 3.075 3.175 3.275 3.375 3.475 3.575 3.675 3.775 3.875 3.975 4.075 4.175 4.275 4.375 4.475 4.575 4.675 4.775 4.875 4.975 5.075 5.175 5.275 5.375 5.475 5.575 5.675 5.775 5.875 5.975 6.075 6.175 6.275 6.375 6.475 6.575 6.675 6.775 6.875 (34.93) (37.47) (40.01) (42.55) (45.09) (47.63) (50.17) (52.71) (55.25) (57.79) (60.33) (62.87) (65.41) (67.95) (70.49) (73.03) (75.57) (78.11) (80.65) (83.19) (85.73) (88.27) (90.81) (93.35) (95.89) (98.43) (100.97) (103.51) (106.05) (108.59) (111.13) (113.67) (116.21) (118.75) (121.29) (123.83) (126.37) (128.91) (131.45) (133.99) (136.53) (139.07) (141.61) (144.15) (146.69) (149.23) (151.77) (154.31) (156.85) (159.39) (161.93) (164.47) (167.01) (169.55) (172.09) (174.63) 1.300 1.400 1.500 1.600 1.700 1.800 1.900 2.000 2.100 2.200 2.300 2.400 2.500 2.600 2.700 2.800 2.900 3.000 3.100 3.200 3.300 3.400 3.500 3.600 3.700 3.800 3.900 4.000 4.100 4.200 4.300 4.400 4.500 4.600 4.700 4.800 4.900 5.000 5.100 5.200 5.300 5.400 5.500 5.600 5.700 5.800 5.900 6.000 6.100 6.200 6.300 6.400 6.500 6.600 (33.02) (35.56) (38.10) (40.64) (43.18) (45.72) (48.26) (50.80) (53.34) (55.88) (58.42) (60.96) (63.50) (66.04) (68.58) (71.12) (73.66) (76.20) (78.74) (81.28) (83.82) (86.36) (88.90) (91.44) (93.98) (96.52) (99.06) (101.60) (104.14) (106.68) (109.22) (111.76) (114.30) (116.84) (119.38) (121.92) (124.46) (127.00) (129.54) (132.08) (134.62) (137.16) (139.70) (142.24) (144.78) (147.32) (149.86) (152.40) (154.94) (157.48) (160.02) (162.56) (165.10) (167.64) 1.335 1.435 1.535 1.635 1.735 1.835 1.935 2.035 2.135 2.235 2.335 2.435 2.535 2.635 2.735 2.835 2.935 3.035 3.135 3.235 3.335 3.435 3.535 3.635 3.735 3.835 3.935 4.035 4.135 4.235 4.335 4.435 4.535 4.635 4.735 4.835 4.935 5.035 5.135 5.235 5.335 5.435 5.535 5.635 5.735 5.835 5.935 6.035 6.135 6.235 6.335 6.435 6.535 6.635 6.735 6.835 6.935 7.035 7.135 7.235 7.335 7.435 7.535 7.635 7.735 7.835 7.935 8.035 (33.91) (36.45) (38.99) (41.53) (44.07) (46.61) (49.15) (51.69) (54.23) (56.77) (59.31) (61.85) (64.39) (66.93) (69.47) (72.01) (74.55) (77.09) (79.63) (82.17) (84.71) (87.25) (89.79) (92.33) (94.87) (97.41) (99.95) (102.49) (105.03) (107.57) (110.11) (112.65) (115.19) (117.73) (120.27) (122.81) (125.35) (127.89) (130.43) (132.97) (135.51) (138.05) (140.59) (143.13) (145.67) (148.21) (150.75) (153.29) (155.83) (158.37) (160.91) (163.45) (165.99) (168.53) (171.07) (173.61) (176.15) (178.69) (181.23) (183.77) (186.31) (188.85) (191.39) (193.93) (196.47) (199.01) (201.55) (204.09) 1.056 1.156 1.256 1.356 1.456 1.556 1.656 1.756 1.856 1.956 2.056 2.156 2.256 2.356 2.456 2.556 2.656 2.756 2.856 2.956 3.056 3.156 3.256 3.356 3.456 3.556 3.656 3.756 3.856 3.956 4.056 4.156 4.256 4.356 4.456 4.556 4.656 4.756 4.856 4.956 5.056 5.156 5.256 5.356 5.456 5.556 5.656 5.756 5.856 5.956 6.056 6.156 6.256 6.356 6.456 6.556 6.656 (26.82) (29.36) (31.90) (34.44) (36.98) (39.52) (42.06) (44.60) (47.14) (49.68) (52.22) (54.76) (57.30) (59.84) (62.38) (64.92) (67.46) (70.00) (72.54) (75.08) (77.62) (80.16) (82.70) (85.24) (87.78) (90.32) (92.86) (95.40) (97.94) (100.48) (103.02) (105.56) (108.10) (110.64) (113.18) (115.72) (118.26) (120.80) (123.34) (125.88) (128.42) (130.96) (133.50) (136.04) (138.58) (141.12) (143.66) (146.20) (148.74) (151.28) (153.82) (156.36) (158.90) (161.44) (163.98) (166.52) (169.06) 1.400 1.500 1.600 1.700 1.800 1.900 2.000 2.100 2.200 2.300 2.400 2.500 2.600 2.700 2.800 2.900 3.000 3.100 3.200 3.300 3.400 3.500 3.600 3.700 3.800 3.900 4.000 4.100 4.200 4.300 4.400 4.500 4.600 4.700 4.800 4.900 5.000 5.100 5.200 5.300 5.400 5.500 5.600 5.700 5.800 5.900 6.000 6.100 6.200 6.300 6.400 6.500 6.600 6.700 6.800 6.900 (35.56) (38.10) (40.64) (43.18) (45.72) (48.26) (50.80) (53.34) (55.88) (58.42) (60.96) (63.50) (66.04) (68.58) (71.12) (73.66) (76.20) (78.74) (81.28) (83.82) (86.36) (88.90) (91.44) (93.98) (96.52) (99.06) (101.60) (104.14) (106.68) (109.22) (111.76) (114.30) (116.84) (119.38) (121.92) (124.46) (127.00) (129.54) (132.08) (134.62) (137.16) (139.70) (142.24) (144.78) (147.32) (149.86) (152.40) (154.94) (157.48) (160.02) (162.56) (165.10) (167.64) (170.18) (172.72) (175.26) 1.075 1.175 1.275 1.375 1.475 1.575 1.675 1.775 1.875 1.975 2.075 2.175 2.275 2.375 2.475 2.575 2.675 2.775 2.875 2.975 3.075 3.175 3.275 3.375 3.475 3.575 3.675 3.775 3.875 3.975 4.075 4.175 4.275 4.375 4.475 4.575 4.675 4.775 4.875 4.975 5.075 5.175 5.275 5.375 5.475 5.575 5.675 5.775 5.875 5.975 6.075 6.175 6.275 6.375 6.475 6.575 6.675 6.775 6.875 6.975 7.075 7.175 7.275 7.375 7.475 7.575 7.675 7.775 (27.31) (29.85) (32.39) (34.93) (37.47) (40.01) (42.55) (45.09) (47.63) (50.17) (52.71) (55.25) (57.79) (60.33) (62.87) (65.41) (67.95) (70.49) (73.03) (75.57) (78.11) (80.65) (83.19) (85.73) (88.27) (90.81) (93.35) (95.89) (98.43) (100.97) (103.51) (106.05) (108.59) (111.13) (113.67) (116.21) (118.75) (121.29) (123.83) (126.37) (128.91) (131.45) (133.99) (136.53) (139.07) (141.61) (144.15) (146.69) (149.23) (151.77) (154.31) (156.85) (159.39) (161.93) (164.47) (167.01) (169.55) (172.09) (174.63) (177.17) (179.71) (182.25) (184.79) (187.33) (189.87) (192.41) (194.95) (197.49) 1.022 1.122 1.222 1.322 1.422 1.522 1.622 1.722 1.822 1.922 2.022 2.122 2.222 2.322 2.422 2.522 2.622 2.722 2.822 2.922 3.022 3.122 3.222 3.322 3.422 3.522 3.622 3.722 3.822 3.922 4.022 4.122 4.222 4.322 4.422 4.522 4.622 4.722 4.822 4.922 5.022 5.122 5.222 5.322 5.422 5.522 5.622 5.722 5.822 5.922 6.022 6.122 6.222 6.322 (25.96) (28.50) (31.04) (33.58) (36.12) (38.66) (41.20) (43.74) (46.28) (48.82) (51.36) (53.90) (56.44) (58.98) (61.52) (64.06) (66.60) (69.14) (71.68) (74.22) (76.76) (79.30) (81.84) (84.38) (86.92) (89.46) (92.00) (94.54) (97.08) (99.62) (102.16) (104.70) (107.24) (109.78) (112.32) (114.86) (117.40) (119.94) (122.48) (125.02) (127.56) (130.10) (132.64) (135.18) (137.72) (140.26) (142.80) (145.34) (147.88) (150.42) (152.96) (155.50) (158.04) (160.58) Tel: (416) 754 - 3322 CONNECTOR DIMENSIONS CONTACT SPACING .100" (2.54mm) Card Edge Connector Series 325, 340, 341, 342, 345, 391, 392, 395, 745 DIMENSION SERIES Number of Contacts Single Dual 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 10 12 14 16 18 20 22 24 26 28 30 32 34 36 38 40 42 44 46 48 50 52 54 56 58 60 62 64 66 68 70 72 74 76 78 80 82 84 86 88 90 92 94 96 98 100 102 104 106 108 110 112 114 116 118 120 122 124 126 128 130 132 134 136 138 140 142 144 146 148 150 "C" 325 340 "D" 341, 391 342, 392 345, 395 745 "E" REST OF SERIES 340 ALL SERIES Inch (mm) Inch (mm) Inch (mm) Inch (mm) Inch (mm) Inch (mm) Inch (mm) Inch (mm) .722 .822 .922 1.022 1.122 1.222 1.322 1.422 1.522 1.622 1.722 1.822 1.922 2.022 2.122 2.222 2.322 2.422 2.522 2.622 2.722 2.822 2.922 3.022 3.122 3.222 3.322 3.422 3.522 3.622 3.722 3.822 3.922 4.022 4.122 4.222 4.322 4.422 4.522 4.622 4.722 4.822 4.922 5.022 5.122 5.222 5.322 5.422 5.522 5.622 5.722 5.822 5.922 6.022 6.122 6.222 6.322 (18.34) (20.88) (23.42) (25.96) (28.50) (31.04) (33.58) (36.12) (38.66) (41.20) (43.74) (46.28) (48.82) (51.36) (53.90) (56.44) (58.98) (61.52) (64.06) (66.60) (69.14) (71.68) (74.22) (76.76) (79.30) (81.84) (84.38) (86.92) (89.46) (92.00) (94.54) (97.08) (99.62) (102.16) (104.70) (107.24) (109.78) (112.32) (114.86) (117.40) (119.94) (122.48) (125.02) (127.56) (130.10) (132.64) (135.18) (137.72) (140.26) (142.80) (145.34) (147.88) (150.42) (152.96) (155.50) (158.04) (160.58) .965 1.065 1.165 1.265 1.365 1.465 1.565 1.665 1.765 1.865 1.965 2.065 2.165 2.265 2.365 2.465 2.565 2.665 2.765 2.865 2.965 3.065 3.165 3.265 3.365 3.465 3.565 3.665 3.765 3.865 3.965 4.065 4.165 4.265 4.365 4.465 4.565 4.665 4.765 4.865 4.965 5.065 5.165 5.265 5.365 5.465 5.565 5.665 5.765 5.865 5.965 6.065 6.165 6.265 6.365 6.465 (24.51) (27.05) (29.59) (32.13) (34.67) (37.21) (39.75) (42.29) (44.83) (47.37) (49.91) (52.45) (54.99) (57.53) (60.07) (62.61) (65.15) (67.69) (70.23) (72.77) (75.31) (77.85) (80.39) (82.93) (85.47) (88.01) (90.55) (93.09) (95.63) (98.17) (100.71) (103.25) (105.79) (108.33) (110.87) (113.41) (115.95) (118.49) (121.03) (123.57) (126.11) (128.65) (131.19) (133.73) (136.27) (138.81) (141.35) (143.89) (146.43) (148.97) (151.51) (154.05) (156.59) (159.13) (161.67) (164.21) .775 .875 .975 1.075 1.175 1.275 1.375 1.475 1.575 1.675 1.775 1.875 1.975 2.075 2.175 2.275 2.375 2.475 2.575 2.675 2.775 2.875 2.975 3.075 3.175 3.275 3.375 3.475 3.575 3.675 3.775 3.875 3.975 4.075 4.175 4.275 4.375 4.475 4.575 4.675 4.775 4.875 4.975 5.075 5.175 5.275 5.375 5.475 5.575 5.675 5.775 5.875 5.975 6.075 6.175 6.275 (19.69) (22.23) (24.77) (27.31) (29.85) (32.39) (34.93) (37.47) (40.01) (42.55) (45.09) (47.63) (50.17) (52.71) (55.25) (57.79) (60.33) (62.87) (65.41) (67.95) (70.49) (73.03) (75.57) (78.11) (80.65) (83.19) (85.73) (88.27) (90.81) (93.35) (95.89) (98.43) (100.97) (103.51) (106.05) (108.59) (111.13) (113.67) (116.21) (118.75) (121.29) (123.83) (126.37) (128.91) (131.45) (133.99) (136.53) (139.07) (141.61) (144.15) (146.69) (149.23) (151.77) (154.31) (156.85) (159.39) .746 .846 .946 1.046 1.146 1.246 1.346 1.446 1.546 1.646 1.746 1.846 1.946 2.046 2.146 2.246 2.346 2.446 2.546 2.646 2.746 2.846 2.946 3.046 3.146 3.246 3.346 3.446 3.546 3.646 3.746 3.846 3.946 4.046 4.146 4.246 4.346 4.446 4.546 4.646 4.746 4.846 4.946 5.046 5.146 5.246 5.346 5.446 5.546 5.646 5.746 5.846 5.946 6.046 (18.95) (21.49) (24.03) (26.57) (29.11) (31.65) (34.19) (36.73) (39.27) (41.81) (44.35) (46.89) (49.43) (51.97) (54.51) (57.05) (59.59) (62.13) (64.67) (67.21) (69.75) (72.29) (74.83) (77.37) (79.91) (82.45) (84.99) (87.53) (90.07) (92.61) (95.15) (97.69) (100.23) (102.77) (105.31) (107.85) (110.39) (112.93) (115.47) (118.01) (120.55) (123.09) (125.63) (128.17) (130.71) (133.25) (135.79) (138.33) (140.87) (143.41) (145.95) (148.49) (151.03) (153.57) .760 .860 .960 1.060 1.160 1.260 1.360 1.460 1.560 1.660 1.760 1.860 1.960 2.060 2.160 2.260 2.360 2.460 2.560 2.660 2.760 2.860 2.960 3.060 3.160 3.260 3.360 3.460 3.560 3.660 3.760 3.860 3.960 4.060 4.160 4.260 4.360 4.460 4.560 4.660 4.760 4.860 4.960 5.060 5.160 5.260 5.360 5.460 5.560 5.660 5.760 5.860 5.960 6.060 6.160 6.260 6.360 6.460 6.560 6.660 6.760 6.860 6.960 7.060 7.160 7.260 7.360 7.460 7.560 7.660 7.760 (19.30) (21.84) (24.38) (26.92) (29.46) (32.00) (34.54) (37.08) (39.62) (42.16) (44.70) (47.24) (49.78) (52.32) (54.86) (57.40) (59.94) (62.48) (65.02) (67.56) (70.10) (72.64) (75.18) (77.72) (80.26) (82.80) (85.34) (87.88) (90.42) (92.96) (95.50) (98.04) (100.58) (103.12) (105.66) (108.20) (110.74) (113.28) (115.82) (118.36) (120.90) (123.44) (125.98) (128.52) (131.06) (133.60) (136.14) (138.68) (141.22) (143.76) (146.30) (148.84) (151.38) (153.92) (156.46) (159.00) (161.54) (164.08) (166.62) (169.16) (171.70) (174.24) (176.78) (179.32) (181.86) (184.40) (186.94) (189.48) (192.02) (194.56) (197.10) .610 .710 .810 .910 1.010 1.110 1.210 1.310 1.410 1.510 1.610 1.710 1.810 1.910 2.010 2.110 2.210 2.310 2.410 2.510 2.610 2.710 2.810 2.910 3.010 3.110 3.210 3.310 3.410 3.510 3.610 3.710 3.810 3.910 4.010 4.110 4.210 4.310 4.410 4.510 4.610 4.710 4.810 4.910 5.010 5.110 5.210 5.310 5.410 5.510 5.610 5.710 5.810 5.910 6.010 6.110 (15.49) (18.03) (20.57) (23.11) (25.65) (28.19) (30.73) (33.27) (35.81) (38.35) (40.89) (43.43) (45.97) (48.51) (51.05) (53.59) (56.13) (58.67) (61.21) (63.75) (66.29) (68.83) (71.37) (73.91) (76.45) (78.99) (81.53) (84.07) (86.61) (89.15) (91.69) (94.23) (96.77) (99.31) (101.85) (104.39) (106.93) (109.47) (112.01) (114.55) (117.09) (119.63) (122.17) (124.71) (127.25) (129.79) (132.33) (134.87) (137.41) (139.95) (142.49) (145.03) (147.57) (150.11) (152.65) (155.19) .600 .700 .800 .900 1.000 1.100 1.200 1.300 1.400 1.500 1.600 1.700 1.800 1.900 2.000 2.100 2.200 2.300 2.400 2.500 2.600 2.700 2.800 2.900 3.000 3.100 3.200 3.300 3.400 3.500 3.600 3.700 3.800 3.900 4.000 4.100 4.200 4.300 4.400 4.500 4.600 4.700 4.800 4.900 5.000 5.100 5.200 5.300 5.400 5.500 5.600 5.700 5.800 5.900 6.000 6.100 6.200 6.300 6.400 6.500 6.600 6.700 6.800 6.900 7.000 7.100 7.200 7.300 7.400 7.500 7.600 (15.24) (17.78) (20.32) (22.86) (25.40) (27.94) (30.48) (33.02) (35.56) (38.10) (40.64) (43.18) (45.72) (48.26) (50.80) (53.34) (55.88) (58.42) (60.96) (63.50) (66.04) (68.58) (71.12) (73.66) (76.20) (78.74) (81.28) (83.82) (86.36) (88.90) (91.44) (93.98) (96.52) (99.06) (101.60) (104.14) (106.68) (109.22) (111.76) (114.30) (116.84) (119.38) (121.92) (124.46) (127.00) (129.54) (132.08) (134.62) (137.16) (139.70) (142.24) (144.78) (147.32) (149.86) (152.40) (154.94) (157.48) (160.02) (162.56) (165.10) (167.64) (170.18) (172.72) (175.26) (177.80) (180.34) (182.88) (185.42) (187.96) (190.50) (193.04) .400 .500 .600 .700 .800 .900 1.000 1.100 1.200 1.300 1.400 1.500 1.600 1.700 1.800 1.900 2.000 2.100 2.200 2.300 2.400 2.500 2.600 2.700 2.800 2.900 3.000 3.100 3.200 3.300 3.400 3.500 3.600 3.700 3.800 3.900 4.000 4.100 4.200 4.300 4.400 4.500 4.600 4.700 4.800 4.900 5.000 5.100 5.200 5.300 5.400 5.500 5.600 5.700 5.800 5.900 6.000 6.100 6.200 6.300 6.400 6.500 6.600 6.700 6.800 6.900 7.000 7.100 7.200 7.300 7.400 (10.16) (12.70) (15.24) (17.78) (20.32) (22.86) (25.40) (27.94) (30.48) (33.02) (35.56) (38.10) (40.64) (43.18) (45.72) (48.26) (50.80) (53.34) (55.88) (58.42) (60.96) (63.50) (66.04) (68.58) (71.12) (73.66) (76.20) (78.74) (81.28) (83.82) (86.36) (88.90) (91.44) (93.98) (96.52) (99.06) (101.60) (104.14) (106.68) (109.22) (111.76) (114.30) (116.84) (119.38) (121.92) (124.46) (127.00) (129.54) (132.08) (134.62) (137.16) (139.70) (142.24) (144.78) (147.32) (149.86) (152.40) (154.94) (157.48) (160.02) (162.56) (165.10) (167.64) (170.18) (172.72) (175.26) (177.80) (180.34) (182.88) (185.42) (187.96) Fax: (416) 754 - 3299 Page 73 MOUNTING OPTIONS - CARD EDGE CONNECTORS Standard Mounting Details CODE x01 - NO MOUNTING LUGS ● Applicable for 303, 305, 306, 307, 310, 315, 316, 317, 321, 325, 327, 333, 336, 337, 338, 340, 341, 342, 345, 346, 355, 356, 357, 379, 384, 387, 391, 392, 395 and 396 Series CODE x02, x04 & x09 - THROUGH MOUNTING HOLES Applicable Series 303, 305, 306, 307, 310, 315, 316,321, 333, 337, 338, 340, 341, 345,346, 355, 356, 357, 379, 384, 387,391, 395, 396 317, 323 325 327 336 342, 392 Code x02 "A" Dia. .128 (3.25) Code x04 "A" Dia. .156 (3.96) Code x09 "A" Dia. — .144 (3.66) — — .128 (3.25) .128(3.25) x .146 (3.71) Slot .156 (3.96) — — .156 (3.96) .156 (3.96) — .160 (4.06) .163 (4.14) .178 (4.52) — CODE x03 - FLOATING EYELETS Applicable Series 303, 305, 306, 307, 310, 315, 316, 317, 321, 323, 333, 336, 337, 338, 341, 345, 346, 355, 356, 357, 379, 384, 387, 391, 395, 396 342, 392 "A" .328 (8.33) .348 (8.84) CODE x07 & x08 - THREADED INSERTS ● Applicable for 303, 305, 306, 307, 310, 315, 316, 317, 321, 323, 325, 333, 336, 337, 338, 341, 342, 345, 346, 356, 357, 379, 384, 387, 391, 392, 395 and 396 Series ● See Code x12 for Side Mounting Threaded Inserts CODE x12 - SIDE MOUNTING HOLES Applicable Series 307, 333, 337, 345, 346, 357, 387, 395, 396 342, 392 "A" .125 (3.18) .135 (3.43) ● Series Listed Above based on Availability of 90 Degree Bend Contact Tails. Side Mounting Holes may also be Used for Other Card Edge Connectors with a Lug Height of .250 (6.35) or Greater. ● For Side Mounting with Threaded Inserts, Specify Code x17 for M3-0.5 Metric Threads or Code x18 for #4-40 Unified Threads. Page 68 Tel: (416) 754 - 3322 CARD EDGE CONNECTORS - MOUNTING OPTIONS Standard Mounting Details CODE x58 & x68 - OFFSET CARD GUIDES Applicable Series for Code x58 Guides 305, 306, 307, 315, 316, 337, 338, 355, 356, 357, 387 345, 395 346, 396 Applicable Series for Code x68 Guides 305, 306, 307, 315, 316, 337, 338, 355, 356, 357, 387 "A" .468(11.89) "B" "C" "D" 2.755(69.98) .125 (3.18) .423(10.74) .468(11.89) 2.755(69.98) .468(11.89) 2.755(69.98) .120 (3.05) .120 (3.05) .402(10.21) .398(10.11) "A" .344 (8.74) "B" "C" 2.505(63.63) .060 (1.52) "D" .242 (6.15) ● For Card Guides with .128 (3.25) Dia. Through Hole Inserts, Specify Code x52 or x62. ● For Card Guides with M3-0.5 Metric Threaded Inserts, Specify Code x57 or x67. ● For Field Assembly of Card Guides, Refer to Page 71. CODE x78 & x88 - IN-LINE CARD GUIDES Applicable Series for Code x78 Guides 305, 306, 307, 315, 316, 337, 338, 355, 356, 357, 387 317 345, 395 346, 396 Applicable Series for Code x88 Guides 345, 395 "B" "C" 1.550(39.37) .090 (2.29) 1.712(43.48) 2.750(69.85) 2.750(69.85) .110 (2.79) .083 (2.11) .091 (2.31) "B" 1.250(31.75) "C" .083 (2.11) ● In-Line Card Guides are Not Suitable for the Flush Mounting Lug Versions of 337, 387, 346 or 396 Series ● For Card Guides with .128 (3.25) Dia. Through Hole Inserts, Specify Code x72 or x82. ● For Card Guides with M3-0.5 Metric Threaded Inserts, Specify Code x77 or x87 ● For Field Assembly of Card Guides, Refer to Page 71. Fax: (416) 754 - 3299 Page 69
325-240-328 价格&库存
很抱歉,暂时无法提供与“325-240-328”相匹配的价格&库存,您可以联系我们找货
